Ultrasonic cleaner mixture
  • predator0357
    • Jul 2014
    • 159
    • Israel
    hi,
    Any of you have a recommendation a PCB cleaning mixture that works best for you????
  • razor_amd
    • Sep 2013
    • 77
    • Serbia
    Re: Ultrasonic cleaner mixture
    I bought 20 liter ultrasonic cleaner I can clean whole laptop/desktop motherboards. This is the mixture I got from the seller, and they told me that this mixture is best for board cleaning:
    Must clean without applying heat!
    10 L - Isopropyl alcohol
    1 L - Apothecary gasoline
    100 mL - Acetone
    Also, you can use these detergents, Mix with distilled water in proportion 1:10. It's best to use heat with the detergents, about 50° Celsius is the right temperature to clean.
    http://www.renex.info/pokaz_kategorie.php?cid=400
    • predator0357
      • Jul 2014
      • 159
      • Israel
      100 mL - Acetone
      tnx
      • predator0357
        • Jul 2014
        • 159
        • Israel
        some more advises please:-)
        • passete
          Living=Sharing
          • Jun 2015
          • 487
          • France
          Originally posted by predator0357
          hi,
          Which machine model do you sugest for mobo's cleaning ?
          • atsio
            • Oct 2013
            • 819
            • Greece
            First clean board with nitro thinner and a toothpaste (allow nitro to flow under bga's) then use your ultrasonic with distilled water with a few spoonfuls of caustic soda for about five minutes at 60 degrees celsius. Finally rinse with distilled water blow board with air and place on top of preheater for half an hour bringing up the heat cradually at 140 degrees celsius on top of board. Much more cheaper and perfect result.
            • predator0357
              • Jul 2014
              • 159
              • Israel
              tnx 4 the advise:-)
              But i have a simple ultrasonic that have 2 options 35W and 50W and i don't know how much C in each option.
              Do u know any mixture that suits my ultrasonic cleaner?
              • passete
                Living=Sharing
                • Jun 2015
                • 487
                • France
                What is nitro ?
                And how do you aply the toothpaste, and mostly which kind of toothpaste ?
                Do you have a link for a video ?
                • razor_amd
                  • Sep 2013
                  • 77
                  • Serbia
                  First clean board with nitro thinner and a toothpaste (allow nitro to flow under bga's) then use your ultrasonic with distilled water with a few spoonfuls of caustic soda for about five minutes at 60 degrees celsius. Finally rinse with distilled water blow board with air and place on top of preheater for half an hour bringing up the heat gradually at 140 degrees celsius on top of board. Much more cheaper and perfect result.
                  Yes, the mixture is cheaper, but you have to heat up the ultrasonic heater, than you have to heat up board on the preheater, using electricity for both, and multiply that for every board. With the first mixture, there is no need to heat up the ultrasonic nor the need to dry the board. But yes it's expensive to fill the large container.
                  The second one I suggested is very cheap, even cheaper than yours.
                  The detergent is about 10€ a liter and can be found a lot cheaper, I got another detergent from a friend here I am paying about 20€ per 20 liter, and the mixture is made 0,5-1 liter detergent in 10 liter of water. So it basically cost me under 5€ to fill up the 18 liter ultrasonic cleaner. Than I only dip the board in that mixture for about 30min at 50-60 Celsius, afterwards I put it on the preheater for about an hour at 150 Celsius.
                  tnx 4 the advise:-)
                  You have small ultrasonic cleaner about 1Liter or smaller?
                  If so, than just use Isopropyl alcohol
                  • atsio
                    • Oct 2013
                    • 819
                    • Greece
                    What does the manual say about the two power positions?
                    • atsio
                      • Oct 2013
                      • 819
                      • Greece
                      First of all, all manufacturers of ultrasonic equipment warn users of not using flammable liquids in ultrasonics because cavitation produces heat.
                      Secondly caustic soda heats the water. Also when I want to heat the water I will heat it in a plastic container with a heating element (not wait the weak heating element of the ultrasonic to heat it) and then pour it in the ultrasonic.
                      Thirdly , you have to wait for the board to dry before you apply any power to it. If you want to wait, no problem, do not put it on preheater.
                      Nitro type thinner is based on Toluene and you can find them in hardware stores, search google, you can use gasoline but is too flammable and I am a smoker or you can try other types of lacquer thinners.
                      Any toothbrush with soft hair. Deep the toothbrush in the liquid and brush the board. On bga's pour a small amount of the thinner under the bga.
                      razor_amd if I understand you well you are placing the board in the ultrasonic for half an hour and the board survives?
                      • predator0357
                        • Jul 2014
                        • 159
                        • Israel
                        didn't buy it yet
                        • razor_amd
                          • Sep 2013
                          • 77
                          • Serbia
                          More than half of the boards that I receive to clean come back to life after cleaning the spilled stuff. I have couple of board I have cleaned multiple times and they work fine.
                          My ultrasonic cleaner is custom made. Ultrasonic power is 300W and the heater power is 1KW, so I get a quick heat of the cleaning fluid. Dimmensions are 500x400x100 mm (WxHxD)
                          • atsio
                            • Oct 2013
                            • 819
                            • Greece
                            You do not need more than 4 minutes to clean the board. 5 minutes I am using is to be on the safe side. Long exposure to ultrasonic waves may damage quartz's and dissolve some types of smt coils. I've researched for building my own but I discovered it was the same price and even cheaper buying a new one from German ebay. You just buy an extra 2500w heat element for 6 euro http://www.ebay.com/itm/361060725216...%3AMEBIDX%3AIT and you have and your quick heating. You can place it in the ultrasonic tank to heat the water but better to be on the safe side and heat it in a plastic container and then pour the water in the ultrasonic tank
                            • predator0357
                              • Jul 2014
                              • 159
                              • Israel
                              the mixture i know is 9:1 9ml of IPA 99.95 and 1ml acetone.
                              this mixture is ok?
                              • predator0357
                                • Jul 2014
                                • 159
                                • Israel
                                need more advises please.
                                more kinds of mixtures.
                                • Limplusonic
                                  • Oct 2016
                                  • China
                                  Add absolute alcohol to ultrasonic cleaner is suggested, and my friend said 15Liter Limplus ultrasonic cleaner has good effect, just 3~5minutes cleaning, he bought from here
                                  https://www.amazon.com/Limplus-Digit...asonic+cleaner
                                  • katfish
                                    • Jul 2016
                                    • 76
                                    Branson EC cleaner - http://www.all-spec.com/Catalog/Chem...0-955-914-6768
                                    I think its 100cc (or maybe ml??) to one gallon dist water. After a clean cycle, put the board in an alcohol bath to displace any water ... then dry in a low temp oven. Use with a proper ultrasonic cleaner ... not one of those cheap jewelry cleaners. Crest makes some nice cleaners ... albeit expensive.
                                    • itsthatidiotagain
                                      CDS‑200B ultrasonic cleaner - (other generic Chinese cleaners are somewhat similar)
                                      by itsthatidiotagain
                                      CDS‑200B ultrasonic cleaner - AKA James Ultra 7050 etc.
                                      There are many versions of cheap Chinese ultrasonic cleaners, and a fair few share this design, with a removable tank with handle. There are also fixed tank versions which look to use the same basic layout and presumably the same PCBs.
                                      I picked one up "spares or repair" on ebay, and the cleaner was dead, but the fuse wasn't blown.
                                      A quick diode check revealed D7 was shorted. D7 is a 12V 1/2 Watt Zener. I had one in my stash, so this was about as close to a "five minute repair" as...
                                      06-23-2025, 03:22 AM
                                    • tricky74
                                      Chinese no brand ultrasonic cleaner
                                      by tricky74
                                      I bought an ultrasonic cleaner from ebay and after a couple of years it blew one of the driver boards fuse and a couple of diodes. I replaced the parts and it worked for a while then died again. Since then I have thrown out the board and just use one. The unit had 2 drivers and the good one drives 1 transducer only. The fried board was driving 2 transducers. The unit works on 1 transducer but is weak in power. I am tempted to connect the 2 transducers that were driven by the dead board. And leave the single disconnected. Not sure if it there is a fault in them and will just kill the driver. As...
                                      07-01-2022, 06:20 PM
                                    • diif
                                      Ultrasonic cleaner but a bit faulty.
                                      by diif
                                      After a not very cool noise and the display dimming my ultrasonic cleaner powered off. The display and fan work, just nothing happens when I press the ultrasonic button.
                                      I think it's at least the triac that is at fault (on the small PCB), showing 57 ohms between pin 1 and 3 and possibly one of the relays (marked in red), I was hoping someone might advise. Thank you....
                                      09-01-2020, 07:04 PM
                                    • Evets
                                      Ultrasonic cleaning
                                      by Evets
                                      I've just bought an ultrasonic cleaner and wonder what the fluid of choice is? Isopropyl alcohol was my first thought.
                                      07-31-2024, 11:33 AM
                                    • rumi409
                                      LG OLED C1 Pixel Cleaning Made Picture Worse
                                      by rumi409
                                      ​​​​​​ Hi,
                                      I'm trying to resurrect a LG OLED C1 TV that has some panel banding. I used the TCON error bypass to get a picture. I was able to update the firmware as well. But when I performed a pixel cleaning to try to get the banding out, it made the image significantly worse. I tried to undo the effects of the pixel cleaning by performing a factory reset and IN_Stop, but that didn't work. Any way to reset pixel cleaning data?...
                                      11-15-2024, 01:09 AM
