5930G restarts when USB is inserted
  • Nightwalker
    • Oct 2012
    • 76
    • Greece
    Hello everyone
    Acer laptop, 5930G model, EIGER MB
    schematic attached
    Problem:
    When AC adapter is present, laptop shuts off and restarts, a few seconds after a USB device is inserted(at windows). If a USB is present from the beginning,laptop entering windows and same thing happens after 10 seconds(shut off-restarts). If a usb device is NOT present, laptop working ok.
    At battery mode no problem at all, with and without usb device present.
    I dissasemble it and remove all usb powered devices and problem remains.
    I give external 5V to usb device(cut internal 5V) and problem is the same.
    EXTRA INFO:
    If laptop is at AC mode, a shut down via windows or via power button acts like a restart.
    With battery only, working right, shut down is a shut down.
    Things already tried:
    Final BIOS version
    Different RAM modules, AC adapter,GPU and CPU, nothing change..
    All temps are below 45C
    Any ideas??
    • 31254
    Re: 5930G restarts when USB is inserted
    internal lithium clock/ram battery checked?
    • Nightwalker
      • Oct 2012
      • 76
      • Greece
      Hello stj, thanks for reply
      Yes, already checked, forgot to mention it ;-)
      • RJARRRPCGP
        • Jul 2004
        • 6304
        Sounds like the Windows kernel panicking...
        ASRock B550 PG Velocita
        Ryzen 9 "Vermeer" 5900X
        Arc A770 16 GB
        eVGA Supernova G3 750W
        Alienware AW3423DWF OLED
        • Nightwalker
          • Oct 2012
          • 76
          • Greece
          Hey RJARRRPCGP
          Interesting approach..
          If so, why this doesn't happen in battery mode also?? Different power settings?
          Maybe i'll give a try with a live cd to see what happens
          • highpulse
            i hate HP
            • May 2013
            • 1490
            • portugal
            nightwalker , f this is happening with dc power is problem on 19 volts line . if there is not a 19 volts line arriving to certainn components while the charger IC says its DC connected , that it might not have enough LDO power to suplly usb's making is to kernel panik . meanwhile in battery system now that power is less .. so therefore it wont be a problem . so first thing to chek is the integrity of the 19 volts line .
            • Djosla
              • Dec 2012
              • 246
              • Montenegro
              I belive that board has nec tokin capacitor...change it and it will solve your problem...
              • dmartins
                David M
                • Apr 2014
                • 197
                • Lisbon
                @Djosla is right , some months ago i change nec tokin in a 5930G and the computer is now OK.
                and the problem was +/- the same
                • Nightwalker
                  • Oct 2012
                  • 76
                  • Greece
                  Thanks everyone for your help and support, deeply appreciate it!!
                  Just replace the tolkin cap as you suggested with 4x330 tantalum and problem seems SOLVED!
                  Still cannot believe that a cap @VCC_CORE leads to that kind of problem...
                  Besides that, now a shutdown command works as it should be!
                  Thanks again guys!!
                  • dmartins
                    David M
                    • Apr 2014
                    • 197
                    • Lisbon
                    happy for another computer working!
                    • Djosla
                      • Dec 2012
                      • 246
                      • Montenegro
                      yeap no problem...
