5930G restarts when USB is inserted
  • Nightwalker
    • Oct 2012
    • 76
    • Greece
    Hello everyone
    Acer laptop, 5930G model, EIGER MB
    schematic attached
    Problem:
    When AC adapter is present, laptop shuts off and restarts, a few seconds after a USB device is inserted(at windows). If a USB is present from the beginning,laptop entering windows and same thing happens after 10 seconds(shut off-restarts). If a usb device is NOT present, laptop working ok.
    At battery mode no problem at all, with and without usb device present.
    I dissasemble it and remove all usb powered devices and problem remains.
    I give external 5V to usb device(cut internal 5V) and problem is the same.
    EXTRA INFO:
    If laptop is at AC mode, a shut down via windows or via power button acts like a restart.
    With battery only, working right, shut down is a shut down.
    Things already tried:
    Final BIOS version
    Different RAM modules, AC adapter,GPU and CPU, nothing change..
    All temps are below 45C
    Any ideas??
    • 31009
    Re: 5930G restarts when USB is inserted
    internal lithium clock/ram battery checked?
    • Nightwalker
      • Oct 2012
      • 76
      • Greece
      Hello stj, thanks for reply
      Yes, already checked, forgot to mention it ;-)
      • RJARRRPCGP
        • Jul 2004
        • 6304
        Sounds like the Windows kernel panicking...
        ASRock B550 PG Velocita
        Ryzen 9 "Vermeer" 5900X
        Arc A770 16 GB
        eVGA Supernova G3 750W
        Alienware AW3423DWF OLED
        • Nightwalker
          • Oct 2012
          • 76
          • Greece
          Hey RJARRRPCGP
          Interesting approach..
          If so, why this doesn't happen in battery mode also?? Different power settings?
          Maybe i'll give a try with a live cd to see what happens
          • highpulse
            i hate HP
            • May 2013
            • 1488
            • portugal
            nightwalker , f this is happening with dc power is problem on 19 volts line . if there is not a 19 volts line arriving to certainn components while the charger IC says its DC connected , that it might not have enough LDO power to suplly usb's making is to kernel panik . meanwhile in battery system now that power is less .. so therefore it wont be a problem . so first thing to chek is the integrity of the 19 volts line .
            • Djosla
              • Dec 2012
              • 246
              • Montenegro
              I belive that board has nec tokin capacitor...change it and it will solve your problem...
              • dmartins
                David M
                • Apr 2014
                • 197
                • Lisbon
                @Djosla is right , some months ago i change nec tokin in a 5930G and the computer is now OK.
                and the problem was +/- the same
                • Nightwalker
                  • Oct 2012
                  • 76
                  • Greece
                  Thanks everyone for your help and support, deeply appreciate it!!
                  Just replace the tolkin cap as you suggested with 4x330 tantalum and problem seems SOLVED!
                  Still cannot believe that a cap @VCC_CORE leads to that kind of problem...
                  Besides that, now a shutdown command works as it should be!
                  Thanks again guys!!
                  • dmartins
                    David M
                    • Apr 2014
                    • 197
                    • Lisbon
                    happy for another computer working!
                    • Djosla
                      • Dec 2012
                      • 246
                      • Montenegro
                      yeap no problem...
                      • Prosatanosz
                        Asus B85M-GAMER no hdmi output and random restarts
                        by Prosatanosz
                        Hi!
                        Asus B85M-GAMER absolute no hdmi output (not at start, not at Windows), and random restarts. Everything work, except hdmi and random restarts after 0.1-3 min. Restarts even in bios. On VGA Windows boots up fast, games and apps starts ok. Mem, psu, cpu changed, no luck. I need shematic, because i think the restarts caused by the hdmi failure.
                        10-19-2024, 05:27 AM
                      • Erikas Tarvydas
                        Lenovo legion 7 16achg6 board repair
                        by Erikas Tarvydas
                        I have a Lenovo Legion 7 with the following specs:
                        • RTX 3080
                        • Ryzen 9 5900HX
                        A problem started suddenly overnight. The next morning, the laptop wouldn't boot properly — the RGB lighting on keyboard turned on, fans spun for a brief moment, but the screen remained black, and the Caps Lock key didn't respond (no indicator light).
                        When running on battery power, the laptop would stay in this state for about 35 seconds before automatically shutting off. When plugged into AC power, it would keep restarting every 35 seconds. Holding the power button would shut it down, but...
                        06-16-2025, 12:41 AM
                      • valente222
                        HP 14 LA-A993P REV 1.0, identify ic? and not susp# present
                        by valente222
                        I have a Mb LA-A993P REV 1.0 computer, I am guiding myself with these two shared boards. ;
                        there are some ICs that are not the same, in this case those of the PU1501 (JD4TB) and PUH1 (NF4SA) images.
                        n, please identify.
                        330mA of consumption after 8 seconds turns off. +3VALW AND +5VALW present, EC_RSMRST# , LID_SW# , EC_ON# , ACIN# present.
                        SUSP# NOT PRESENT, which would be this the problem does not turn on sub-sources Any leakage?
                        I also notice that in the PLH2 coil that belongs to +1.05VS according to the drawings I am not sure,
                        06-27-2024, 06:11 PM
                      • air_chair256
                        Lenovo Yoga 9I 15IMH5, MB LC40CM Won't Turn On, 1V_VCCGT is not present
                        by air_chair256
                        I have a Lenovo MB LC40CM 19863-1 when press button is pushed the keyboard backlight turns on and off twice and the power button light keeps blinking and the fans spins for a few seconds and stops then again spins and stops (Three times) then laptop turns off. no image on screen. sometime when you leave it for few days it will turn on and work but once you restart it won't turn on.
                        Tried to reball RAM 1,2,3,4
                        Checked all voltages on big coils all present except 1V_VCCGT is not present I get 0V on this rail. is this voltage should be present once power button...
                        02-13-2024, 06:00 AM
                      • javieromex
                        Dell G15 5511 LA-K452P won't turn on
                        by javieromex
                        Hello, any help will be apprecited!
                        • Model: Dell G15 5511
                        • MB: LA-K452P
                        • Issue: Won't turn on at all, no leds, no keyboard light, no fan spin, nothing happens when pressing power button. NOTHING.
                        • Customer reported it was turned off and left plugged in during the night and thats it...
                        • No signs of liquid damage or burned components.
                        Link to Schematics -> https://www.badcaps.net/forum/troubl...la-k452p-gdp50
                        I have checked so far:
                        04-17-2025, 12:44 PM
