Dell 3421
  • dmartins
    David M
    • Apr 2014
    • 197
    • Lisbon
    Dell 3421
    Hello ,
    I have a dell 3421 , the computer works but dont have image.
    I've flash bios but before the computer dont have power , so i backup bios .
    I start the computer and no image but when i measure some components the computer give image .
    What can it be ?
  • dmartins
    David M
    • Apr 2014
    • 197
    • Lisbon
    Re: Dell 3421
    Anyone to help ?
    Thnkx
    • LP_tekh
      • Oct 2015
      • 95
      • Laos
      Re: Dell 3421
      Cold solder for that component. lacks of ground contact.
      • Sameer khan
        • Dec 2018
        • 9
        • India
        Re: Dell 3421
        i need schematic of dell 3421 kindly share the schematic
        • mikeybass
          by mikeybass
          04-23-2025, 04:30 PM
        • Akhlz001
          by Akhlz001
          09-20-2025, 07:15 PM
        • mrrubik
          Dell Optiplex 7010 micro bad BIOS flash?
          by mrrubik
          Hi folks,
          I got a Dell Optiplex 7010 micro PC (Exact Model) with 8FC8 BIOS and locked out admin password. I attempted to remove the password by patching the BIOS via info from this thread: https://www.badcaps.net/forum/troubl...ssword-patcher
          After flashing the patched the BIOS, the PC is unresponsive with a solid AMBER power LED (not documented in manual anywhere)
          Steps I took:
          1. Read BIOS with CH341a, verified hash twice
          2. Patched
          12-23-2024, 04:11 PM
        • bmxlovah
          Dell Precision T7910 no bios, no post after applying SAS/RAID setup
          by bmxlovah
          My Dell Precision T7910 died after enabling onboard SAS controller and applying RAID settings. There were no hardware changes between working and not working state, only setup (via bios -> controller settings). After applying settings and reboot PC turns on, flash leds (normally) but there's no further action, it just stays on with no graphics and no keyboard led's on. There's no Dell logo, nothing. I've tried resetting bios by jumper, replacing cpu's, replacing ram, removed/replaced cmos battery, disconnecting all drives etc. I've also dumped .bins from mobo chips SLI1 (16...
          11-24-2022, 06:29 AM
        • trix11
          Dell Precision T1650 MT Workstation bricked after BIOS update
          by trix11
          I have a Dell Precision T1650 MT workstation (of the following spec.) that was bricked yesterday when attempting to update the BIOS from A27 to A28 per:
          - https://www.dell.com/support/home/en...-t1650/drivers > Dell Precision T1650 System BIOS
          - Dell Precision T1650 mid tower Workstation
          - Xeon E3-1225 V2
          - 32Gb PC3-12800E RAM
          - 4Tb SATA HDD
          - motherboard: Dell part: 0C3YXR CN-0C3YXR-72200-39C-01GR-A02
          I see now that others have experienced like issues e.g.:
          - https://www.dell.com/community/Prec...
          10-24-2022, 10:35 PM
