LA-A996P shorted 3.3v coil
  • gcomputers
    • Apr 2013
    • 509
    • Albania
    hi i m working with this hp 15
    Come with black screen and some time blinking the led near jack audio.
    Flashed bios first
    Replaced cpu EM2100... with new
    After i checked (that need the first troubleshoot) missing 3.3-5v from coils , but this voltage come after power on laptop, is stable3.3-5v.
    the coil of 3,3v is shorted with gnd , removed it apply power on shorted side with psu and find Realtek 8166EH too hot removed it and short is gone.
    ??????????????But the same no display ???????????????????????????????????????
    ENE chip have 3,3v on some pins BUT i don't have schematic .
    ANY SUGGESTION BEFORE CLOSING IT. (REPLACE ENE OR NO)
  • dellxps15
    • Feb 2014
    • 1598
    • italy
    Re: LA-A996P shorted 3.3v coil
    ene 9012 need usb programmer.... before replace that, check if all voltages are present.
    • gcomputers
      • Apr 2013
      • 509
      • Albania
      Thanks for reply ,i have 2 eprom (ezp2010 & minipro) but i never programmed this ene.
      ENE measurements :
      1-0v
      2-0
      3-037mv
      4-0
      5-037mv
      6-037mv
      8-037mv
      9-3.3v
      10-037
      11-0
      12-0
      13-0
      14-037
      15-0
      16-0
      17-0.9v
      18-3.2v
      19-0.9v
      20-0
      21-0
      22-3.3v
      23-24-25=0
      26-1.05v
      27-1.1v
      28-29=0
      30-100mv
      31-034mv
      32-0
      33-3.3v
      34-0.8v
      35-0
      36-0.7v
      37-3.3v
      38-39-------53=380mv
      54-1v
      55-3.3v
      56------63=3.3v
      64-1.1v
      65-015mv
      66-0.5v
      67-0
      68-0
      69-380mv
      70-0
      71-0.8v
      72-380mv
      73-0
      74-0
      75-380mv
      76-330mv
      77-3.3v
      78-3.3v
      79-80=0
      81-82=380mv
      83-0
      84-380mv
      85-3.3v
      86-030mv
      87-88=0
      89-370mv
      90-0
      91-300mv
      92-0
      93-3.3v
      94-95=0
      96-3.3v
      97-140mv
      98-1.2v
      99-3.3v
      100-0
      101-0
      102-0
      103-330mv
      104-0
      105-0
      106-0.7v
      107-108=0
      109-3v
      110-3.3v
      111-3.3v
      112-113=0
      114-3.3v
      115-3.3v
      116-0
      117-3.3v
      118-043mv
      119-043mv
      120-121-123=0
      124-1.7v
      125-3.3v
      126-044mv
      127-128=0
      • and555
        • Apr 2016
        • 36
        • Indonesia
        how many times the led is blinking ?
        • gcomputers
          • Apr 2013
          • 509
          • Albania
          sometime blink continuously.sometime not blink.
          • highpulse
            i hate HP
            • May 2013
            • 1489
            • portugal
            well got exact same board , no video , got a overaLL AMP consume of 0.33 amp ,
            cheked all coils , all coils on s0 have correct voltage , nothing seems bad , flashed bios , same issue , flashed EC SIO same issue , noticed that lcdvdd is not present , and it come from UG1 , pin3 enable come from APU , so bit thinking if i replaced APU , and after if might not work !!! GRRR , all DP_ENVDD AND +DP_ENVDD BOTH ARE 0 without it , there will be no enable therefore no lcdvdd ..
            • tysovyc
              • Mar 2017
              • 11
              • zimbabwe
              Got the same problem the if i connect hdd it shows activity on the led but no display. Anyone got a solution
              • reessi
                Acer Alienware Nitro 5 (GH51G LA-L181P Rev: 1C) & Dell Alienware M15 (GDP50 LA-k452P Rev:1) - Both Shorted PCH (SRKMA)!
                by reessi
                Hello:
                I have both these laptops that appeared to have the same fault so I thought I would have a go at replacing the PCH as something to learn, they both are using the same PCH.
                I started on the ACER:
                Up on connecting power no signs of life but current is consumed from the bench power supply and the PCH is hot.
                All the caps on the top of the PCH are showing 0 ohms and the 3.3v rail is shorted.
                I followed the videos from Sorin, Electronics Repair School on Youtube heating from the bottom to install. I practised on around 10 scrap...
                10-29-2024, 11:31 AM
              • Yanleb
                Panasonic TC-P50S1 shorted TXNSC1EDUU (TNPA4782AB) SC Board
                by Yanleb
                Hi every one. I just want to share the successful repair of my shorted Panasonic TNPA4782AB SC board.
                I don't usually do it but so many parts were shorted that I decided to buy the ShopJimmy repair kit instead of sourcing each components individually. Here is the list of components the kit contained, with a remark indicating if I needed that part or not :
                D608, good
                D618 RF101L4S, good (See warning 1 below)
                D619 RF101L4S, good (See warning 1 below)
                D865 RF101L4S, shorted (See warning 1 below)
                IC464 Inverter HA MC74HC1G14, shorted...
                03-09-2020, 12:00 AM
              • modtool
                HP Victus 15-FA1025NL , board DAG3PAMB8D0 REV:D, shorted CPU DrMOS and n-mos
                by modtool
                Hi to all,
                the owner of this machine gave it to me after having opened it to take off the dust from the inside, telling me that after that it didn't start anymore.
                I found that one of the DrMOS (AOZ5016QI) on the CPUCORE was shorted between VIN and VSWH, and that one of the two n-mos connected to the power jack was shorted aswell.
                I unsoldered the two shorted components and verified that there were no other short circuits, then decided to power the mainboard, firstly with the lab power supply, then with its original HP 200w charger, but the behaviour is the same, the board starts...
                04-01-2025, 08:22 AM
              • AppleLover123
                Acer Nitro 5 comes on then goes off
                by AppleLover123
                Hey guys,
                i've got this laptop from a friend who gave it to me in a dead state.
                The laptop wasn't working at all so i've began my search on the 19V power rail.
                It was shorted to ground so i injected voltage and the only thing getting hot was my ground clip from my power supply.
                I found that the +1.05V Rail for the Chipset was shorted. i removed the coil and it was shorted on the power delivery side.
                The pch seems fine bc the rail has over 50 ohms after i removed the coil.
                Still nothing was getting hot so i suggested the chip must...
                10-09-2025, 04:51 PM
              • barry101
                Apple 820-3662 VCore shorted to ground.
                by barry101
                Hi, Would appreciate some help.
                I have an Apple Late 2013 15" A1398 MacBook Pro with Logic Board 820-3662.
                Get charger light but no fan spin or chime. No liquid damage.
                Found PPBUS and VCORE both shorted to ground. Other rails were ok.
                Removed VCORE MOSFETS U7310, U7320 and U7330. Found U7330 was in fact shorted.
                With the 3 MOSFETS removed, get PPBUS and fan spin. VCORE is still hard shorted to ground (0 ohms).
                Attempted voltage insertion on VCORE to locate short using bench supply set at 1.0 VDC and 4.95 Amps (max current for my...
                06-24-2025, 07:34 AM
