Help dell n5050 npce795pa0dx problem
  • naeemshahzad
    • Jan 2015
    • 129
    • uae
    Hi
    is any one know about npce795pa0dx
    how to read write internal EC flash ?
    model Dell n5050 kb chip npce795pa0dx is bad i change new one but notworking than i found npce795pa0dx have 128k memory inside
    now i have another n5050 which working fine i want read that chip but how i have no idea .
  • atsio
    • Oct 2013
    • 819
    • Greece
    Re: Help dell n5050 npce795pa0dx problem
    You do not need to flash the EC controller. PCH and EC share the spi flash ic. Your problem is somewhere else.
    • naeemshahzad
      • Jan 2015
      • 129
      • uae
      i already conformed and change ic from ok motherboard nothing else just npce795pa0dx not working .
      • and555
        • Apr 2016
        • 36
        • Indonesia
        hi naeemshahzad, is there a voltage on pin 19 ?, normally it's 3.3v.
        • naeemshahzad
          • Jan 2015
          • 129
          • uae
          bro from working board i checked ic in bad board working fine but buy from market
          dead nothing .
          • and555
            • Apr 2016
            • 36
            • Indonesia
            so, NPCE795PA0dX from market did'nt worked.
            in the market where you buy it?
            • naeemshahzad
              • Jan 2015
              • 129
              • uae
              computer street bur dubai .
              • Johnkill
                • Jan 2023
                • United Arab Emirates
                Please PM your contact no in Dubai
                • toti24
                  (NEED HELP)dell precision m4600 problem after bios flash (unbrick)
                  by toti24
                  dell precision m4600 laptop
                  i7 2760qm
                  8gb ram 750gb HDD
                  intel hd 3000 integraded and nvidia quadro 2000m
                  pleasea bear with me english isnt my language and ill try to be as clear as possible
                  note i live in mexico in a very small town..
                  thank you.
                  laptop got bricked (freeze at dell logo) i managed to unbrick it but now am facing a problem...... let me explain what and how it happened.
                  the brick happened when i was installing win 10 using usb.
                  used rufus and officia microsoft.iso
                  it finished copying files from usb...
                  03-06-2022, 08:39 PM
                • SDNarcia
                  Dell 15R-5521 keyboard problem (KBC?)
                  by SDNarcia
                  Hello, I have a Dell 15R-5521, with the problem that the Ctrl, Alt, Shitf and Num Lock keys do not work, I tested the keyboard with a keyboard tester and it is functional, I also got another new keyboard and the computer has the same problem with the same keys. Check continuity between the ZIF connector from the keyboard to the KBC and all pins are correct. I cleaned the ZIF connector and the KBC and I still have the same problem. I reinstalled windows just in case, and it didn't work. I updated the BIOS to the latest version A16 and there were no changes.
                  As additional information,...
                  07-20-2024, 10:47 PM
                • Achille15
                  Dell N5110 problem
                  by Achille15
                  so, I have this laptop Dell Inspiron N5110 with a heating problem on both CPU (I7-2680qm) and GPU (GT 525m), I tried many solutions, like changing thermal paste every month, using thermal pads on CPU and GPU, even using thermal pads on CPU nearby coils; but nothing worked, just minutes after booting the laptop shuts itself down so I thought it might be a short problem, so I decided to check what's going on, so I went online and some tutorial (general one) said to check inductors in order to find the shorted circuit, after checking (CPU removed), I found the culprit to be...
                  03-29-2025, 04:41 PM
                • masoksian
                  Dell latitude e7470 not turn on .power buton on off and Run Power problem
                  by masoksian
                  I am dealing with the problem of turning on and off my Dell e7470 notebook.
                  The battery charge light is solid white, I press the button, the power indicator and the light on the button are solid for 1-2 seconds and immediately turn off.
                  The system does not turn on, there is no post.
                  I removed the RAMs and changed them, changed the battery, RTC battery, AC adapter, removed them and waited, tried again, it does not turn on.
                  The problem continues in the same way.
                  I tried to turn on the Fn key, nothing came to the screen....
                  02-15-2025, 12:08 PM
                • MahmoudNasser
                  Dell 7480 problem with freezing during the Windows loading process
                  by MahmoudNasser
                  Hello everyone, I wish you a happy day.
                  I have a Dell Latitude 7480 laptop that has a problem with freezing during the Windows loading process. If it manages to boot up, it becomes very slow and doesn't load anything from the desktop.
                  Device Data
                  Model Dell Latitude 7480
                  CPU:i7-7600U
                  SN:7T58PL2
                  MP PartNumper:CAZ20 LA-E131P Rev:1.0 A00
                  Bios Chips:W25Q128BV
                  The attempts that have been made to solve the problem have not yielded any results.
                  1. Changing the M.2 and M.2 Nvme hard drives.
                  2. Trying...
                  07-09-2023, 05:04 AM
