Novatech Rasor Pro NOVATECH L55II0
    I got this Laptop made by Novatech.
    Rasor Pro Uniwill L55II0.
    The LCD screen is broken needs to be replaced. I know how to do it, where is good place to buy new or used?
    The battery power plug is broke, I have pictures of the motherboard.
    Let's look at he caps folks.
    What soldering station irons in the UK do you lot buy and from where?
    Any help is appreciated.
    http://www.hse.gov.uk/pubns/indg305.pdf
    Re: Novatech Rasor Pro NOVATECH L55II0
    I get my screens off from ebay.
    I use hot air to remove the charging sockets. Got a photo of the socket ?
      No I can buy this.
      Novatech 75Watt AC adaptor for use on Uniwill U50SI/L55II0/255II/259II/M30/X20
      This is what I meant.
      Where do you buy your screens from?
      Also what Soldering equipment do you use and how do you remove capacitors from motherboard.
        I was tough to get to that port, loads of screws.
          Yeah, those Uniwill laptops are messy as #!*(%. Any 15.6" CCFL screen will work for that one.
          A working TV? How boring!
            I took off the palmrest of the laptop, then I accidently took off a screw part. Then the silver metal came off, I need to stick it back down, it looked like sellotape underneath.
            I don't know how to put it back on, it was really difficult.
              Anyone ?
                Got the laptop to power on, but now theres a loud grinding sound?
                  Something catching in the fan ?
                    When I looked at the fan I pulled a bit on it, so there was no touching it. It looked like the out part was touching it when I spun it.
                    Also when I had the Laptop on it side there noise went away.
                    I put the cpu fan under a tap, there was a lot of dust on the blades.
                    So I will let it dry out over night.
                      Now folks if anyone will reply. I broke the power button ribbon cable to the motherboard.
                      How do I get a replacement cable??
                      It is a little cable with blue plastic bits on either ends.
                        What's the pitch, length and how many contacts ?
                          I also tugged on the other bit this.
                          How do I measure the cable and give you the correct information?
                          diif.
                            The cpu fan plastic bit broke off side, how do I secure it.
                              On the three wire fan connector ? a dab of hot glue.
                              A clearer picture of the FFC would help. You have a ruler ? measure the length and width and the amount of contacts.
                                I took pictures of it close up, with markings on it.
                                The ribbon cable.
                                  And the length and width ? Looks like 6 contacts.
                                    I took some photos, sorry it took so long but I got the length and width in photos.
                                      0.5mm pitch 6pins forward direction. 10cm should do.
                                      http://www.ebay.co.uk/itm/FFC-FPC-Fl...-/401338268878
                                        What is Pack of Qty(pcs) ???
