Novatech Rasor Pro NOVATECH L55II0
  • Fast Alpha
    • Feb 2013
    • 245
    Re: Novatech Rasor Pro NOVATECH L55II0
    Pitch&Direction: 0.5mm forward Direction
    Pins&Length: 6P Length 10cm
    Pack of Qty(pcs): ???
    http://www.hse.gov.uk/pubns/indg305.pdf
    • diif
      • Feb 2014
      • 6978
      • England
      It's quantity. Do you want two for 99p or ten for £1.62
      It's forward direction as the contacts are on the same side. It's reverse if they are on different sides.
      Pitch is the distance between the centre of one contact and the next.
      • Fast Alpha
        • Feb 2013
        • 245
        Can I get this from farnell too, I am ordering other soldering parts to use.
        http://uk.farnell.com/electrolube/sm...12ml/dp/891186
        flux pen ^
        http://uk.farnell.com/chemtronics/60...3-0m/dp/860694
        braid^
        Or....
        http://uk.farnell.com/multicore-loct...9mm/dp/1115541
        http://uk.farnell.com/velleman-sa/st...ire/dp/2542946
        Stand for soldering iron^
        • diif
          • Feb 2014
          • 6978
          • England
          Originally posted by Fast Alpha
          Yes Farnell sell the flat cable £2.35 for one.
          Get the Chemtronics braid.
          • Fast Alpha
            • Feb 2013
            • 245
            http://uk.farnell.com/c/cable-wire-c...ffc-fpc-cables
            Which one do I get ??
            • diif
              • Feb 2014
              • 6978
              • England
              #26
              If you put in the pitch, the length and number of pins it will leave you with only two. One forward and one reverse.
              • Fast Alpha
                • Feb 2013
                • 245
                #27
                FFC/FPC Flexible Flat Cable Ribbon 4P/6P/8P Forward Direction Reverse 0.5mm 1mm
                I ordered 0.5mm pitch 6pins forward direction this but he sent me this.
                I show in pictures.
                It is not 6 pins on the cable but 8, I DID NOT ORDER 8 pins.
                I ordered 6.
                THIS WAS ON THE ORDER from ebay.
                Pack of Qty(pcs): 2
                Pins&Length: 6P Length 10CM
                Pitch&Direction: 0.5mm Forward Direction
                http://www.ebay.co.uk/itm/FFC-FPC-Fl...-/401338268878
                • diif
                  • Feb 2014
                  • 6978
                  • England
                  #28
                  Have you informed the seller ? mistakes happen, they'll just send the correct ones when you let them know.
                  • Fast Alpha
                    • Feb 2013
                    • 245
                    #29
                    another cable blue bit fell off the palmrest ribbon.
                    Here's photo's.
                    palmrest cable, 6 pins on the front part, 3mm wide.
                    170mm length.
                    • Fast Alpha
                      • Feb 2013
                      • 245
                      #30
                      How do I order two cables from Farnell not ebay.
                      palmrest cable, 6 pins on the front part, 3mm wide. 170mm length.
                      Also power ribbon cable.
                      3mm wide, 6 pins on the front part, 90mm length.
                      • diif
                        • Feb 2014
                        • 6978
                        • England
                        #31
                        What is happening to the cables for them to all need replacing ? Are you ripping them out of the connectors without releasing the clips ?
                        Stick the parameters in the Farnell website. You will have to go for a 20cm and 10cm cables. If its 3mm wide and has 6 cores then that would be 0.5mm pitch.
                        • Fast Alpha
                          • Feb 2013
                          • 245
                          #32
                          No I was carefully removing them, maybe once I pulled a bit.
                          Need linkage for farnell plz
                          • Fast Alpha
                            • Feb 2013
                            • 245
                            #33
                            Also what is a good flux pen to use ?
                            • Fast Alpha
                              • Feb 2013
                              • 245
                              #34
                              http://uk.farnell.com/w/c/cable-wire...t+Cable+Ribbon
                              Only sell these two cables. 6 core.
                              • diif
                                • Feb 2014
                                • 6978
                                • England
                                #35
                                You find the cables on Farnell and I'll confirm.
                                I use solder paste in a syringe with a needle but have used the Electrolube flux that farnell sell.
                                • Fast Alpha
                                  • Feb 2013
                                  • 245
                                  #36
                                  https://www.youtube.com/watch?v=-PmD6Jbpf2I
                                  shows you how to modify cables.
                                  • Fast Alpha
                                    • Feb 2013
                                    • 245
                                    #37
                                    Is this hot glue gun, how do I use it ??
                                    Or is there a cheaper one somewhere mate ?
                                    http://www.argos.co.uk/product/7004937
                                    • diif
                                      • Feb 2014
                                      • 6978
                                      • England
                                      #38
                                      Yes, it's a hot glue gun. It the small version as it uses 7mm glue sticks.
                                      There are cheaper versions available from Ali or ebay.
                                      For example http://www.ebay.co.uk/itm/HOT-MELT-G...-/321944164478 or one with 100 glue sticks. http://www.ebay.co.uk/itm/Hot-Melt-G...-/272676461896
                                      Plug it in, wait a few minutes for it to get hot and then squirt out the hot glue. Good for sticking some things but not others.
                                      • Fast Alpha
                                        • Feb 2013
                                        • 245
                                        #39
                                        Alright Diif I fixed the laptop, it powers on.
                                        Now I need to peel back some of the ribbon cable and stick the blue plastic bit some how.
                                        The touchpad needs another ribbon cable.
                                        Or could I fix the 6 pin connectors with the blue thing??
                                        I think I'll go to Hobby craft for the glue gun.
                                        Seems like a better deal than Ebay
                                        • Th3_uN1Qu3
                                          Believe in
                                          • Jul 2010
                                          • 6031
                                          #40
                                          The blue plastic bit can be stuck back on with a small amount of double sided tape. Some people use super glue but i don't recommend it as any spill will get you into trouble.
                                          A working TV? How boring!
