hp 6735b black screen
  • hazim
    • Mar 2016
    • 62
    • egypt
    i have hp 6735b amd laptop
    black screen broplem
    machine power up but no data
    i heat chep with hot gun but no result
    i flash bios with original one but no result
    inverter board and lcd ok
    power supply refer to .065 1.1 1.2 1.4 amp
    what can i do i need your help
  • Life Goes On
    • May 2014
    • 264
    • Curacao
    Re: hp 6735b black screen
    Try with extern monitor if you have image and you also can try with other Ram.
    The Night Drop Down, I Will Keep Try Until..., You Never know.
    Dushi Kòrsou, Nos Tei.
    • razor_amd
      • Sep 2013
      • 77
      • Serbia
      Check for voltage on CPU coils. If below 1,15V than it's the chipset problem 99%. Need to refllow, reball or exchange.
      • hazim
        • Mar 2016
        • 62
        • egypt
        thank's alot
        external monitor and new ram no result
        but i repeat check and measure
        find voltage on cpu 0.82 volt on coil 9 and coil 10
        as my friend RAZOR says but i reflow chipset with no result
        i will tray to Chang it thank's alot
        • HTR-Informatique
          Dell G3 15 3500 - Battery bug (black screen and flashing keyboard backlight)
          by HTR-Informatique
          YouTube video of the problem encountered: https://youtube.com/shorts/q7TLNv36LUo
          I am a pro and I have a problem that I have never seen despite my 7.5 years of experience on my own and my thousands of repairs, on a customer's Dell G3 15 3500.
          On this PC I have already changed the complete palmrest because the keyboard was no longer working properly.
          I also changed the screen because the PC fell and the screen was broken.
          I changed the battery with a new and original battery.
          I also had corrosion/oxidation on the...
          02-09-2025, 06:51 AM
        • howardc64
          by howardc64
          Problem
          08-04-2024, 10:36 PM
        • DaniK
          Acer Aspire E5-574-52RH - black screen
          by DaniK
          I have this strange behaviour with Acer Aspire E5-574-52RH, i5 6200U, intel graphics, DA0ZRWMB6G0 Rev G, model ZRW.
          Laptop came in for a SSD upgrade, took everything apart to install the SSD.
          Everything started after modifying BIOS settings to boot UEFI instead of Legacy.
          Laptop works fine, i installed windows 10 and drivers/updates, everything works ok(when it works)
          The black screen problem is random, maybe 5 out 10 times, laptop remains with the black screen, no image
          Symptoms are:
          - random black screen after displaying Acer logo...
          02-21-2024, 06:27 AM
        • turmix
          AOC U34G3XM, new monitor, black screen with backlight on, possible shortcircuit during dissassembly
          by turmix
          Hello, I'm working on a new deskmod pc project and have a problem with my monitor, an AOC U34G3XM, well, I may have bricked it.
          The monitor was dismanteled and the separate parts parts integrated in the desk. the screen panel alone is on the upper part, and main board/video board + power board on the back of the desk (not enough place on the cover to fit it)
          At first everything was working smoothly, then I decided to change the connexion between the video board and the screen for a longer one. Still working fine
          During another reassembly, I made a mistake, and...
          01-29-2024, 03:48 AM
        • m1ch43lzm
          by m1ch43lzm
          05-12-2025, 08:37 PM
