Macbook Pro 13 A1278 EMC2555
  • ciki
    • Aug 2014
    • 132
    • Ireland
    Hi Macbook wont turn on fan just on and off ,have green light on charger ,
  • highpulse
    i hate HP
    • May 2013
    • 1490
    • portugal
    Re: Macbook Pro 13 A1278 EMC2555
    try making a SMC AND/OR PRAM reset first of everything , then let us know , in case you dont know how to do it
    SMC reset require no power on board , no battery and dc attached to machine , for 40 second , during this time press a few times on off button .
    pram reset - press command + alt +p +r and keep pressing does keys while you press on off , keep the keys pressed , once you hear the reboot and second chime noise , release all keys .
    • ciki
      • Aug 2014
      • 132
      • Ireland
      It not work When I connect charger it constant on off but when is on battery when I press power button makes only 2 sec fan spinning and thats all,black screen no post no beep
      • dellxps15
        • Feb 2014
        • 1598
        • italy
        mainboard code ? 820-xxxx ?
        • ciki
          • Aug 2014
          • 132
          • Ireland
          Hi its 820-2879 Intel i7
          What Im was thinking that problem is one of the current sensing capacitor ,because its cut power just second after start
          • ciki
            • Aug 2014
            • 132
            • Ireland
            Sorry correction about logic is 820-2936-B
            • dellxps15
              • Feb 2014
              • 1598
              • italy
              voltages on bios pins ?
              • ciki
                • Aug 2014
                • 132
                • Ireland
                3.3v
                • highpulse
                  i hate HP
                  • May 2013
                  • 1490
                  • portugal
                  wich pins have 3.3 ?
                  • cvorke
                    • Oct 2012
                    • 26
                    • Solar system
                    I have the similar problem, same board...
                    It came with PPBUS_G3H shorted to GND at Q7035.
                    I have changed Q7035 ang got green light and fan as well.
                    But unfortunately I have no display, chime, anything...
                    Also tried to power on without RAM and it runs in same way, no beeps...
                    When I plug the charger with battery inserted, green light go off after couple of sec and no orange light came on. So I have SMC_BC_ACOK at U6901 without battery and not with battery connected.
                    I tried with changing U7000 - same...
                    On BIOS i have 3.3 at pins 1,2,3,7,8.
                    • duwane
                      MacBook Pro A1278 - No charger light, no PPBUS_G3H, SMC_BC_ACOK short when powered
                      by duwane
                      Hi All.
                      I have a very strange issue that I have been trying to fix for a few days now.
                      Model: MacBook Pro A1278
                      Logic board: 820-3115-B
                      Laptop history:
                      No visible liquid damage/corrosion, but found evidence of other rework (flux) so any signs of liquid may have been cleaned. The laptop went in for a battery replacement but wasn't working afterwards and was deemed unfixable (as told to me by previous owner). Not sure if this was by Apple, or another repair company. The flux found was found around ISL6259HRTZ, so can assume it was replaced...
                      05-15-2022, 05:22 PM
                    • pcbmaniac
                      MacBook A1278 (3115) No PPBUS_G3H Issue
                      by pcbmaniac
                      Subject: Help Needed: MacBook A1278 (3115) No PPBUS_G3H Issue
                      I'm working on a MacBook A1278 with the 3115 logic board and facing an issue with no PPBUS_G3H voltage. Here's what I've checked so far:
                      1. U7000 Measurements:
                        • Pin 3 has 0V, even though R7012 shows 16.5V from PPDCIN_S5_CHGR.
                      2. Resistors:
                        • I measured R7010 and R7011 with one leg disconnected, and both tested OK.
                      Based on these findings, I believe U7000 needs to be replaced. However, I have a related question:
                      • If I also decide to replace the SMC, do I need to order it pre-programmed,
                      12-02-2024, 04:12 PM
                    • sizar00740
                      macbook pro 13 inch a1278 820-2879
                      by sizar00740
                      please clear me this bios efi macbook macbook pro 13 inch a1278 820-2879...
                      07-30-2025, 10:21 AM
                    • echothegamer
                      Macbook A1466 dies when charger disconnected
                      by echothegamer
                      Hello all,
                      Working on my wife's 13' Macbook air. It's been in a box since she upgraded but I figured it could be good practice.
                      Details:
                      Macbook 13' A1466
                      Board (820-3209-A)
                      Battery OEM 7.3v 50Wh 6700 mAh (020-7379-A)
                      Pictures below of Boardview and schematic...
                      I don't know how to test the voltage on a MacBook battery. I just assumed it had an enable pin but the best I could read was 300 something mV poking around the battery connector.
                      It's an older model and it is very likely that battery has become...
                      10-28-2023, 12:00 PM
                    • envym
                      MacBook Pro 2018 with Activation Lock
                      by envym
                      Hi everyone!
                      I have a 2018 MacBook Pro (with Sequoia OS) that I've been using for years with no problem. I recently received an M2 MacBook Pro so I'm mostly using it and not the 2018 one, but since a friend of mine needs a computer, I thought I could restore my 2018 and give it brand-new-like to my friend.
                      I tried using the built-in tool to restore the MacBook (Settings > General > Transfer or restore > Delete) but it got stuck when trying to remove the Find Device configuration (it asked me for the password for my old Apple ID -now I use the same account but...
                      06-27-2025, 08:54 AM
