Apple 820-2915-A A1286 no power up
  • angel-boy
    • 550
    - first problem was graphic chip, after reballing , works great 2 days, after 2 days same problem , i replace graphic chip with second hand , but mainboard not starting , it`s charging the battery but no power.
    - i remove second hand chip , and put the original chip back , same problem
    where i need to look first ?
  • dellxps15
    • Feb 2014
    • 1588
    • italy
    Re: Apple 820-2915-A A1286 no power up
    with "no power up" u mean no fan spin nothing ? or just didnt chime and show display, but fan spin ok ?
    does it power on without vga coil ?
    • angel-boy
      • 550
      no power up = no fan spin no image, no power led . only battery charge.
      the graphic chip AMD 216 0809000 i remove it , i understand that should start without .
      • angel-boy
        • 550
        any help please. thanks
        • ivanxxx
          • Nov 2012
          • 10
          • Croatia
          Check the flat cable that connects charging port and motherboard, goes over the cooling fan, you might put it wrong way around, common mistake?
          • angel-boy
            • 550
            the laptop is charging , i check each cable, connected all good
            • ktmmotocross
              Boardkiller
              • Feb 2014
              • 3575
              • slovakia
              do u have s5 powers ok?
              • angel-boy
                • 550
                i will need first board view and schematic to check . as i say tell me where to check first
                • dellxps15
                  • Feb 2014
                  • 1588
                  • italy
                  if u remove vga coil does it power on ?
                  • angel-boy
                    • 550
                    still not starting.
                    • dellxps15
                      • Feb 2014
                      • 1588
                      • italy
                      check PM_PWRBTN_L, smc_onoff_l , if present and goes to 0 when pressing power botton.
                      • yorshh
                        • Aug 2011
                        I have the same problem with 820-2915. green light on the charger and charging battery if i plug a not full battery but not starting
                        pp342, 3.42
                        pp5v_s0 5v
                        pp5v_s3 0v ( is it present when the machine is off???)
                        ppbus_g3h 12v
                        • piernov
                          • Jan 2016
                          • 4435
                          • France
                          Apple fixes 820-2915 for free for the GPU issue, see: https://www.apple.com/support/macbookpro-videoissues/
                          Also S3 rails are not present when the computer is off (S3 means sleep, so there are present either when the computer is sleeping or when it is on). On older Macbook motherboard (pre-Haswell? not sure about that) you need to short the power button pads (taking care of not shorting any other pins) to turn the machine on.
                          • yorshh
                            • Aug 2011
                            done that. Not sure if it is a GPU problem. the laptop doesnt go from s0 state to s5
                            • Pascal Komlassan
                              • Jan 2017
                              • 806
                              • TOGO
                              please somebody can give me the bios dump of this machine??? thank's
                              i have the same problem my motherboard no power up
                              • Technician09
                                • Nov 2017
                                • klaten
                                Please disable GPU board code 820-2915....
                                • Tynan Dill
                                  by Tynan Dill
                                  Assuming...
                                  11-22-2024, 01:46 PM
                                • PantherDave
                                  by PantherDave
                                  Hi all!
                                  05-29-2024, 02:01 PM
                                • GLISIT
                                  by GLISIT
                                  01-16-2025, 02:29 PM
                                  03-31-2024, 02:12 PM
                                • flusher
                                  Apple MBP16" A2141 820-01700 PMIC power cycles no boot no shorts
                                  by flusher
                                  Bought myself a project thing. Apple MBP16" A2141 820-01700
                                  No shorts, no visible waterdamage.
                                  Dead. no history.
                                  All USBC ports do 20V and charging battery.
                                  If you plug battery/charger PPBUS is 12.6v and all power rails like RTC, 3v3, 5v etc are present. U7800 PMIC all voltages are present APART from PPVCCPRIMCORE_PRIM_REG (not sure if it has to be present at this stage?! resistance is 40 Ohm). SSD 2.5, 0.9, 1.8 are present on both wings. Charger meter shows 30ma or something like this on charged battery.
                                  But what PMIC does is that it power cycles(dropping to...
                                  02-21-2025, 03:12 PM
