Hp G6 with No Voltage on Hdd & Odo (DA0R52MB6E0)
  • passete
    Living=Sharing
    • Jun 2015
    • 487
    • France
    Hello, this is a HP G6-2324sf !
    The Laptop boots and ask for OS, I can enter on bios and both CD/DVD and HDD are Not detected.
    Everything works, usb slots, wifi (if I boot with windows portable), etc...
    I'm not an expert, but I think that the psu for the drives are dead, cause there are no voltage.
    Motherboard is : DA0R52MB6E0 Rev.E
    Anyone with the schematic could point where to test ?
    Thanks guys
  • passete
    Living=Sharing
    • Jun 2015
    • 487
    • France
    Re: Hp G6 with No Voltage on Hdd & Odo (DA0R52MB6E0)
    Anyone around with the schematics for this mobo ?
    Maybe with my limited knowledge I could pin point the faulty component.
    • megaraider
      • Jul 2015
      • 307
      • Portugal
      Should be equal or very similar,
      included only relevant pages.
      • passete
        Living=Sharing
        • Jun 2015
        • 487
        • France
        I'm not a very good schematics reader, if i understand it's the chip PU7 that i need to replace ?
        • wwwzzzxxx2002@yahoo.com.a
          • Feb 2021
          • Argentina
          Hello friends, did someone get a more complete diagram?, Because I have this same board and I can not solve a lack of video... thanks
          • Fernon@Repair
            Gigabyte Z490 Gaming X Motherboard No VCORE Voltage
            by Fernon@Repair
            i have Gigabyte Z490 Gaming X Motherboard .it has a power on no display fault .. no vcore voltage and debug led stuck CPU LED .
            VCCIO voltage ok
            VCCSA Voltage OK
            VCCPLL Voltage OK
            Ram Voltage ok
            RamVTT OK
            VPP 2.5 OK
            But No Core Voltage
            and i want to this vrm ic datasheet or pinout (ISL69269)
            anyone have this ic pinout voltages?...
            06-25-2025, 07:19 AM
          • electron_jj
            Panasonic TH-L42D25A checking the PSU output voltage
            by electron_jj
            Hi Everyone, I am new to this forum. I have a Panasonic LED TV which doesnt turn on and is blinking 4 times repeatedly when I turn on the switch. The TV does not respond to the remote control so I had to turn on using the physical switch on the side of the TV. When I turn on the switch the 4 x blinking starts and repeat itself until I turn off the TV. There is a black screen. I turned off the light in the room to check the panel and I think there is no backlight as far as I can tell.
            I have been inspecting and testing the capacitors and diodes in the power supply board to try to...
            08-29-2021, 08:13 AM
            Trip light 2400 watt line conditioner bought used issue with low voltage oscillation going on between relays
            by sam_sam_sam
            I found two capacitors on the board and one of the leads on one capacitor had bad soldering joint and the other joint connections not much better and there were several soldering joints that way to much flux around the joint redid several of them
            The capacitors were a non brand that I did not recognize they got replaced and now it does not oscillating between relay but what concerns me a little bit is when the voltage is a little bit low the output voltage is around 130 volts and then drops down to 115 volts this happens around 105 to 108 volts if remember correctly
            Now...
            06-09-2024, 10:57 AM
            ISL95831HRTZ ISL95831HRTZ-T ISL95831IRTZ ISL95831IRTZ-T Voltage Regulator Datasheet
            3+1 Voltage Regulator for IMVP-7/VR12 CPUs
            Compliant with IMVP-7/VR12, the ISL95831 provides a complete solution for microprocessor and graphic processor
            core power supply. It provides two Voltage Regulators (VRs) with three integrated gate drivers. The first VR can be
            configured as 3-, 2- or 1-phase VR while the second output is 1- phase VR, providing maximum flexibility. The two VRs share the
            serial control bus to communicate with the CPU and achieve lower cost and smaller board area compared with the two chip approach.
            Based on Intersil's Robust Ripple Regulator...
            11-05-2024, 03:24 PM
          • ruletero
            Acer a515-43 low battery charge voltage
            by ruletero
            Hi
            Acer A515-43
            LA-H801P
            Fail: Does not charge battery, has low voltaje on connector.
            Laptop didn't want to turn on, only charge led blinked.
            I found PQB5 (mosfet high battery charger) in short, voltaje in +12.6V_BATT was 19 v ...
            I changed it, changed PQB6 too and now battery charger voltage is 4.4V but battery is 3 cell, 11.25v, then is very low to charging.
            Laptop turns on without battery and works fine, but with battery turns on and turns off inmediately, I suspect battery bad but I don't know...
            10-24-2022, 02:31 PM
