acer one ZH9 model no power.
  • rickybucalan
    • May 2013
    • 322
    • philippines
    hello guys.
    need your help i got acer one ZH9 model netbook with no power
    but there is 5v and 3.3v alws.
    no shorted coil.
    what should i check next? tnx
  • kotnatan
    Banned
    • Apr 2014
    • 181
    • Ukraine
    Re: acer one ZH9 model no power.
    See diagram Quanta ZH9 - page 36-38
    • rickybucalan
      • May 2013
      • 322
      • philippines
      do you have it. can u pls send me here tnx
      • kotnatan
        Banned
        • Apr 2014
        • 181
        • Ukraine
        http://en.lmgtfy.com/?q=Quanta+ZH9+schematic
        • rickybucalan
          • May 2013
          • 322
          • philippines
          anyone have bios bin for this model. tnx
          • PantherDave
            by PantherDave
            Hi all!
            05-29-2024, 02:01 PM
          • Benchaton
            No Power : Acer Swift 7 Pro (Board model ZDL)
            by Benchaton
            Problem : When plugged into power the laptop shows no signs of life but a small periodic tick noise, no battery charging indicator.
            Observations :
            - The laptop makes a tick sound at regular intervals when plugged in via the charger.
            - The laptop negociates with the Power Delivery charger to 20V as expected but shuts back down to 0 then 5 at regular intervals (same as ticking noise)
            - 4 Ceramic capacitors have 1 Ohm resistance to ground on both poles (Anotated on the pictures)
            - After removal of the Battery Charging IC short is still...
            10-05-2025, 09:48 AM
          • GLISIT
            by GLISIT
            01-16-2025, 02:29 PM
          • pilgrimage
            Acer Predator Helios 300 Model: N20C3 PH315-53-71ZR No Power
            by pilgrimage
            Hello, my laptop was working smoothly, I was getting images via hdmi via the monitor. I ordered a new lcd panel because the LCD screen was broken. After replacing the LCD screen, when I wanted to turn on my laptop, my laptop was dead. Currently, there is no power, no light, no reaction on the laptop, do you think that in this case, could the GPU or CPU of my laptop be burnt? I read in some forums that this kind of error can occur if the LCD screen is replaced while the battery is installed. Unfortunately, when I replaced the LCD panel, my laptop was completely turned off but the battery was installed....
            02-01-2024, 02:21 PM
          • reessi
            HP - CE Series - DAG7ALMB8C0 REV.C - MODEL - G7AL-2G - Missing MAINON & SUSON - Turns on power LED & Charges
            by reessi
            I have re-soldered the loose pins on the RAM slot which is a common fault on these models..
            It charges and turns on the power LED but is missing several voltages like RAM and CPU do not come up which I believe is due to MAINON & SUSON being missing to turn these supplies on..
            What I am un-sure of is what is the ITC chip waiting for to send out these signals, what are the requirements?
            I have checked these lines in diode mode and they seam normal -> 600.
            I have checked to see if they come on for even a fraction of a second...
            07-15-2025, 09:14 AM
