HP 630 shuts down after 33 seconds
  • ravi_1617
    YY Solutions
    • Jan 2012
    • 348
    • India
    HI
    P/N 01015EC00-535-G
    CHICAGO_CP_HPC
    When came had to be started few time 5-7 times than display comes worked fine.
    worked fine for 20- half an hour.
    when reflowed BD82HM55 worked fine for few days .again same... story
    so replace swapped HM55 from other board... than problem started display comes
    stays on for exactly 30 to 33 seconds. so I thought hm55 is defective. again swapped from other board this is also same thing shuts down after 33 seconds
    both the hm55 reballed with lead balls , could this be reason.
    any other clues
  • dj_ricoh
    • 2073
    Re: HP 630 shuts down after 33 seconds
    Originally posted by ravi_1617
    HI
    P/N 01015EC00-535-G
    CHICAGO_CP_HPC
    any other clues
    why do i think it is a BIOS issue?
    Reflash it.
    i had a 630 and yes, that HM chipset was the problem.
    i reflow the bastard and place a cooper plate because the chip was cooling from bottom case with a small aluminium plate.
    I place that cooper there and now its working well and strong.
    • ravi_1617
      YY Solutions
      • Jan 2012
      • 348
      • India
      I also did copper plate at the hm55
      I have to try bios
      • Djosla
        • Dec 2012
        • 246
        • Montenegro
        After replacing hm55 did you clean intel me region ?
        https://www.youtube.com/watch?v=rOnbdgqkP2M
        or post old bios dump then we wil make it...
        • highpulse
          i hate HP
          • May 2013
          • 1490
          • portugal
          guess heh didn't , and dj_ricoh , it has been more than prof , that cooper shimmer are bad and worst shit you can use on computers , instead of using this oldschool method , time to get rid of does ancient techniques and use good termal pad you have more termal condutivity with termal pads that cooper shimmer , not only to mention is more professional work :P
          • ravi_1617
            YY Solutions
            • Jan 2012
            • 348
            • India
            Hi
            Everything is fine after flashing 4 mb main bios.tested for 3 hr no problem.
            Thanks every one
            • ravi_1617
              YY Solutions
              • Jan 2012
              • 348
              • India
              Intel is not heating that much but i had given blue sheet heatsink between intel and body
              Aluminum
              • HUSSAIN8055
                • Oct 2015
                • 3
                • india
                Guy's I need Hp-630 -P/N 01015EC00-535-G ... '
                EC and MAIN Bios upload it
                Thnx
                • riko 656
                  Lenovo Legion Slim 5 16APH8 (RTX 4070) - Turns on for a few seconds then shuts off. BIOS issue.
                  by riko 656
                  I need help with my Lenovo Legion laptop. It turns on for a few seconds and then immediately shuts down. I believe this is a BIOS corruption issue.
                  Laptop Model:
                  • Model: Lenovo Legion Slim 5 16APH8
                  • GPU: NVIDIA GeForce RTX 4070
                  • Main BIOS chip size: 32MB
                  • VBIOS chip size: 16MB
                  Problem Description: The laptop was working perfectly. Now, when I press the power button, the keyboard lights up and the laptop powers on for just a few seconds, then it shuts itself off completely. After researching, I am convinced it's a corrupt BIOS.
                  What I Have Tried So Far:
                  1. I
                  11-04-2025, 05:14 AM
                • chaos-theory
                  Asrock z97x starts then shuts off after 4 seconds, sometimes more, no post
                  by chaos-theory
                  I have a really weird problem, this motherboard was working normally, someday it just started and all fans were running but didn't want to post, tried resetting bios, checking CPU and it was getting warm tried external gpu, flashed bios with programmer, but same problem.
                  Next day after several attempts the board goes into protection mode, no more staying on, I turn on the PSU fans starts directly turning, it used to not start until I press the pwr button, now it starts directly and fans spins, and shuts off after 3 seconds sometimes less, then won't start again unless I unplug the PSU and...
                  03-14-2025, 05:37 PM
                • riki_22
                  ASUS B5402CEA – Laptop powers on for a few seconds then shuts down
                  by riki_22
                  I’m working on an ASUS B5402CEA notebook.
                  B5402CEA_MB_R2.2
                  HA4YT LA-L861P
                  REV:1B
                  The board powers on, fan spins for a few seconds, then it shuts down by itself.
                  I suspect the BIOS might be corrupted.
                  Could someone please check and clean (repair) the attached BIOS dump?
                  I’ve also attached a few photos of the motherboard for reference.
                  Thanks in advance for your help!
                  11-03-2025, 04:38 AM
                • APOPAP
                  Panasonic National NV-M3 VHS Camera shuts down after some seconds
                  by APOPAP
                  Hello everybody,
                  First post here. I have been reading posts here for some time now, but today I made my first account and post.
                  The same question is also posted on another site, here it is:
                  Just found an old Panasonic National NV-M3 VHS Camera without the original charger but with a special bag with a led, switch and fuse that is designed for a lead-acid 12v 6Ah battery. It has two cables coming off the bag that leads to the camera terminals (Only + and - ). Pretty sturdy design I think.
                  I tried connecting it to a Computer PSU (12.7v) but I get battery error...
                  08-25-2025, 10:12 AM
                • tec3000
                  Sony LED 65X9005A shuts down after few seconds - looking for help
                  by tec3000
                  Hi community! Germany calling I am wondering if you guys can help me out. I have an issue with my Sony LED TV. I've been told this is a good place to ask. Thanks for anyone who will reply and offer advice. Appreciated!
                  I have a KD-65X9005A Sony 4k LED TV. For a few weeks I've got this problem where I turn on the TV and within a few seconds the TV starts getting darker until it shuts itself off and I get the 4 blinking error code. HOWEVER there is one exception: Whenever I switch to the i-Manual, a full screen on-screen instruction manual, the TV never turns off. I tested for hours!...
                  03-20-2024, 07:29 AM
