Sony Vaio SVF1521 (DA0HK9MB6D0) no power
  • Th3_uN1Qu3
    Believe in
    • Jul 2010
    • 6031
    I have this laptop acting very weird. 3.3v and 5v are present, charging LED comes on if battery is inserted. When pressing the power button, power LED comes on and stays on as long as the button is held down, then turns off. That's all it does. No power to the CPU, RAM or PCH and the fan does not spin.
    I have reflashed BIOS using a dump i found on 1bios.ru and it does the same. Any suggestion guys? Thanks.
    A working TV? How boring!
  • Djosla
    • Dec 2012
    • 246
    • Montenegro
    Re: Sony Vaio SVF1521 (DA0HK9MB6D0) no power
    try changing kbc if you have in spare...
    • Th3_uN1Qu3
      Believe in
      • Jul 2010
      • 6031
      What i have noticed is i do get power to the BIOS chip after i push the button but it's the only thing that changes. I do not get any communication on the BIOS. I don't have a KBC handy but will look for one.
      • gcomputers
        • Apr 2013
        • 509
        • Albania
        me happened with an vaio i5 (i dont remember the model) the same issue , flashed bios no change , for my luck i had a scrap identical motherboard , I took the chip bios replaced and solved work fine.
        • Th3_uN1Qu3
          Believe in
          • Jul 2010
          • 6031
          I have spare BIOS chips, will try.
          • ravi_1617
            YY Solutions
            • Jan 2012
            • 345
            • India
            Check lid closing sensor .
            • sebuncle
              • Jun 2010
              • 46
              • France
              Hi do you solved problem ?
              JOVY RE7500
              • sebuncle
                • Jun 2010
                • 46
                • France
                Hi
                change npce985la0dx .
                JOVY RE7500
                • tanveer920
                  • Jul 2015
                  • 32
                  • INDIA
                  bios problem i solve this programe bios chip and then ok
                  • farhad ali
                    • Feb 2016
                    • 9
                    • india
                    i have facing same problem..guys did u find the solution o this issue pls help me out.....
                    • sebuncle
                      • Jun 2010
                      • 46
                      • France
                      Hi
                      you must change NPCE985la0dx
                      JOVY RE7500
                      • Tynan Dill
                        by Tynan Dill
                        Assuming...
                        11-22-2024, 01:46 PM
                      • PantherDave
                        by PantherDave
                        Hi all!
                        05-29-2024, 02:01 PM
                      • GLISIT
                        by GLISIT
                        01-16-2025, 02:29 PM
                      • PopsCaps
                        Sony Bravia KDL-40V2500 that will not power on
                        by PopsCaps
                        I have a Sony Bravia KDL-40V2500 that will not power on. The indicator flashes red 3 times.
                        I do not hear any sound and I cannot see any backlight.
                        I have tried disconnecting every cable on each board one at a time to see if anything changes.
                        The only change is when I disconnect AC-DET cable on the Power Supply board or on the other end if I unplug the CN7009 connection on the B-Board and try to power on the TV the indicator will stay on solid green until I power off.
                        My friend ordered another used power supply board but it is also doing the red indicator flash 3 times...
                        03-25-2025, 11:23 AM
                        Sony VAIO VPCEE3J1E/WI E Specification for Upgrade or Repair
                        This specification for the Sony VAIO VPCEE3J1E/WI can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the VPCEE3J1E/WI boardview and VPCEE3J1E/WI schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for Sony VAIO...
                        09-06-2024, 05:27 AM
