Hp dv5
  • dmartins
    David M
    • Apr 2014
    • 197
    • Lisbon
    Hp dv5
    Hi ,
    My DV5-1210sp dont give image ,gives me a 1 time blink, i already change CPU but no result..
    Any suggestion ?
  • sopik78
    • Nov 2013
    • 517
    • Czech Republic
    Re: Hp dv5
    Reball NB AMD RS781, should work after that.
    • dmartins
      David M
      • Apr 2014
      • 197
      • Lisbon
      Re: Hp dv5
      What should i reball ?
      I dont have RS781
      • sopik78
        • Nov 2013
        • 517
        • Czech Republic
        Re: Hp dv5
        It means NB AMD 215-0674034
        • dmartins
          David M
          • Apr 2014
          • 197
          • Lisbon
          Re: Hp dv5
          Thanks Sopik78,
          I'll try and give feedback later!
          • ktmmotocross
            Boardkiller
            • Feb 2014
            • 3610
            • slovakia
            Re: Hp dv5
            that ati GPU is MOST common problem on this laptop. give 120c heat to it to see what ic have bad balls
            • dmartins
              David M
              • Apr 2014
              • 197
              • Lisbon
              Re: Hp dv5
              Yeah, i reball the NB and now the computer works ,
              Thanks a lot Sopik and KTM too
              • sopik78
                • Nov 2013
                • 517
                • Czech Republic
                Re: Hp dv5
                NOT GPU but the NB. GPUs Ati on these models have minor problems against that damned NBs.
                • ktmmotocross
                  Boardkiller
                  • Feb 2014
                  • 3610
                  • slovakia
                  Re: Hp dv5
                  that gpu 3470 is most failure gpu from ati. it is even very bad for reballing, because of its sensitive for heat.
                  that notebook would fail. just wait :-)
                  • alihomee
                    • Dec 2012
                    • 1577
                    • malaysia
                    Re: Hp dv5
                    agree with u
                    • Th3_uN1Qu3
                      Believe in
                      • Jul 2010
                      • 6031
                      Re: Hp dv5
                      I've done dozens of DV5 and DV6 and only 2 had bad GPUs. It was the northbridge almost every time. Sometimes it requires replacement as it either does not hold up or refuses to display video even after reballing.
                      A working TV? How boring!
                      • highpulse
                        i hate HP
                        • May 2013
                        • 1488
                        • portugal
                        Re: Hp dv5
                        IGP reballing is a waste of time .. entirely major part of they problems are situated on the internal bumpers , so there is no need of adding new balls under the chip ... the problem is internal so each time you heat it up , it works due the the internal part start making contact after heat cycle .
                        best way is to replace a problematic chip ... happy costumer , and good word for your lab !
                        • sopik78
                          • Nov 2013
                          • 517
                          • Czech Republic
                          Re: Hp dv5
                          The Unique: same experience, just 1 bad GPU HD34xx, but loads NBs
                          highpulse: IGP after reballing on DV5 works more than year usually, so it is not a waste of time, if customer don't want to pay double price
                          • cloo
                            Panasonic ZT60 plasma tv with strange behavior and 8 blink code
                            by cloo
                            I recently got my hands on a 60" Panasonic P60ZT60 plasma tv (european model) that has some strange issues along with an 8 blink code.
                            It know this tv is getting old but it was once considered one of the best plasmas ever made, and i think it is still holds on to that even by todays standards.
                            So, long story short. When i first got the tv it had a very bright washed out picture with very raised blacks in all picture modes and i couldn't find the cause in the picture setting menus.
                            After doing a factory reset this problem was gone and the picture was back to...
                            01-06-2025, 06:02 AM
                          • EazyBone
                            Un50cu7000 2 blink oddity *partially solved
                            by EazyBone
                            I write this to maybe help another with this TV.
                            So I aquired this TV a 2023 model. It started the 2 blink reboot problem which indicates bad panel. It was still under warranty and the repair man came by.
                            The Samsung repairman brought a brand new panel and switched my original boards to the new panel. The new panel then had the 2 blink error code. The repair guy said he has seen this and the MAIN board on this model will cause the 2 blink. He then replaced the main/power board (they are both connected) and put it back onto my original panel. Voila it worked.
                            03-18-2024, 10:24 PM
                          • Vebririon
                            panasonic TX-P50V10E 6 blink led problem
                            by Vebririon
                            I'm new here and trying to repair my Panasonic TX-P50V10E plasma TV, which is currently showing the 6 red blink error code.
                            Just for context: I'm used to building PCs and installing modchips in old consoles, but this is my first time trying to fix a TV. I'm French, and while my English is okay, I'm using ChatGPT to help translate and clarify my messages as much as possible — so please forgive any odd phrasing.
                            I'm also not very experienced with using a multimeter, but I'm very motivated and ready to follow instructions carefully and report...
                            05-17-2025, 10:16 AM
                          • nervx
                            Panasonic TH-42PZ800 8-blink error mystery
                            by nervx
                            Years ago my tv gave a 7 blink code which turned into 8 during diagnosis. I had ordered a replacement ss board but somehow the tv started working again and i never used the board. Now a week ago my tv flickered and shut off at random and gave the 8 blink error code. The same issue it had all those years ago. The only difference this time is that over the last few months there has been some purple and green tinge that comes and goes in more solid colors such as white.
                            Anyway i checked all the screws and replaced the ss board with a known good one and still got 8 blinks. I saw a...
                            04-08-2022, 05:19 AM
                          • pixelcap
                            Pioneer Kuro Pro 111FD 8 red blink error
                            by pixelcap
                            Pioneer Kuro Pro 111FD 8 blink red LED.
                            I have been trying to solve the power-down 8-blink red LED problem with my Pioneer.
                            So far I have replaced the power supply board, and the digital assembly board, I have reconnected the ribbons to all boards, ensuring the connections are good. Even though the problem is the 8 red light error and not the more common 8 blue light error code, I had Kcrownie,
                            based in North Carolina replace the chips that cause the 8 blue LED problem (the main board and audio board) the plasma is still powering...
                            10-06-2024, 11:26 PM
