Laptop Lenovo turn off after 30 minutes.
  • Eleways
    • Oct 2014
    • 62
    • Italy
    Hi there
    I've a Laptop Lenovo Thinkpad edge, that works properly for about 25 minutes, then dies. I've clean fan and i've changed the termal paste on CPU and GPU. The temerature does not esceed 50°.
    I've tried to exchange CPU and 've reset the cmos. No success. Any idea?
    Many thanks for your help.
    Luca
  • Dgtech
    E. Technician
    • Apr 2009
    • 1462
    • Steeler
    Re: Laptop Lenovo turn off after 30 minutes.
    I cant think of anything other than what you already did. Same result with power supply or battery?
    • the-sky-blue
      • Dec 2013
      • 48
      • salfeet
      some time bios update may be can fix this problem
      • TossDon
        AKA Masood
        • Jun 2013
        • 26
        Change both temp sensors for CPU and GPU
        • ala_borbe
          aka Donald
          • 1625
          • Malta
          give details about configuration
          Im Back... sort of...
          • Eleways
            • Oct 2014
            • 62
            • Italy
            Lenovo Thinkpad Edge 15 type 0319.
            CPU Intel Core I3 M380 2.53Ghz
            4Gb DDR
            HDD 500Gb
            Sys Op. Windows 7 Pro 64 bit Service Pack 1
            The fan runs continuously, but the temperature does not exceed 50° (used HW monitor)
            I've uptated the Bios, without success.
            • ridamouh159
              • Nov 2014
              • 365
              • maroc
              problem is chip vga or ic concerning power 3.3v and 5v try to chang the ic
              and flashing the ENE BIOS
              if not the problem is in chip vga
              • Raheel
                • Sep 2015
                • Pakistan
                if your system is with intel chip and you sort that the temperature of heat sink is normal then it is sure short bios problem
                • RJARRRPCGP
                  • Jul 2004
                  • 6304
                  Still sounds like there may be a shorted thermal probe that hasn't been found.....
                  ASRock B550 PG Velocita
                  Ryzen 9 "Vermeer" 5900X
                  Arc A770 16 GB
                  eVGA Supernova G3 750W
                  Alienware AW3423DWF OLED
                  • m4a2t0t
                    • Mar 2013
                    • 279
                    Have you tried running in on AC power without the battery?
                    • RdeveLabs
                      MSI GF63 THIN 11UCX (MS-16R6) LAPTOP WON'T TURN ON AFTER RESTARTING
                      by RdeveLabs
                      To all the members here...
                      Let me tell you a little bit about what happened to my laptop (MSI GF63 THIN 11UCX model: MS-16R6) that “maybe” you know how to solve this problem.
                      So before this problem happened, my laptop was running smoothly. When I wanted to restart my laptop, it looked fine at first. But after I waited for this restart process to take a long time, until finally I panicked (because the restart process did not finish plus the laptop screen only showed a black screen), I immediately pressed and held the power button to force the laptop to turn off. But...
                      05-05-2025, 04:59 AM
                    • Evgenii999
                      Laptop Lenovo IdeaPad 3 15ITL05 doesn’t turn on.
                      by Evgenii999
                      I need your advice in diagnosing a motherboard issue on a Lenovo IdeaPad 3 15ITL05, motherboard HS45A/HS55A Rev 1.0 NM-D461 (2020-11-02).
                      Symptoms:
                      The laptop does not power on and does not respond to the power button.
                      Background:
                      According to the owner, her child was playing on the laptop when it suddenly shut down.
                      What has been done so far:
                      Original charger is missing; the non-original one was tested and found faulty (0 V output).
                      Using a lab power supply (20 V, 0.5 A) — no activity on the board, no LEDs, no standby voltages....
                      10-25-2025, 06:07 AM
                    • thxd43
                      Lenovo laptop does not turn on, what does this number mean in a BIOS chip?
                      by thxd43
                      Hello, first of all, excuse me, I am using the translator, English is not my native language.
                      I have a Lenovo ideapad 330S - 14IKB laptop.
                      The tablet did not recognize me when I connected it, so I checked the device manager and I realized that there were many with the exclamation mark, so one by one I began to update their drivers until the sign disappeared of admiration, I even updated the BIOS, and the laptop rebooted normally and worked, so far so good, but the tablet still did not recognize me, I read on the internet that it could be due to a...
                      02-23-2023, 08:37 PM
                    • g1150
                      Lenovo G565 Laptop , LCD not turn on, external terminak ok.
                      by g1150
                      Lenovo G565 Laptop onboard LCD Display does not turn on.
                      Only works with external Monitor.
                      I am trying to verify that the LCD signals from the motherboard are ok.
                      The LCD was working, but over time happened to not turn on more frequently.
                      Now dead.
                      Possibly the cable from MB to LCD is broken somewhere.
                      I just wonder how it is detected if external or internal monitor shall be activated ?
                      I found the following schematic on the net:
                      Problem 2:
                      The graphics chip ATI Mobility Radeon HD5470 seems defective.
                      On Win7...
                      05-07-2025, 11:51 AM
                      Lenovo Yoga Yoga 7i (16? Intel) 2 in 1 Laptop Notebook 700 Specification for Upgrade or Repair
                      This specification for the Lenovo Yoga Yoga 7i (16? Intel) 2 in 1 Laptop Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Yoga 7i (16? Intel) 2 in 1 Laptop boardview and Yoga 7i (16? Intel) 2 in 1 Laptop schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer...
                      09-07-2024, 05:00 AM
