Is (ALC3227) compatible with (ALC3223) ?
  • laptop market
    • Sep 2012
    • 122
    • mansoura
    Is (ALC3227)chip compatible with (ALC3223)chip ?
  • storm12
    • Feb 2018
    • 8
    • United Kingdom
    Re: Is (ALC3227) compatible with (ALC3223) ?
    Same question here, or does anyone know what other chip is compatible with ALC3227?
    • bushmann
      • Feb 2014
      • 147
      • Slovakia
      ALC 3227 work fine all pin are same, but not work me digital mic from camera.
      I don`t know why, may be is damaged.
      • bushmann
        • Feb 2014
        • 147
        • Slovakia
        If I use original ALC3223, digital mic work fine .
        • BOSCHNJAK
          by BOSCHNJAK
          ABOUT ME INTRODUCTION FILE
          2
          024 BEV, BIH, SARAJEVO START PROJECT: ELECTRIC VEHICLE TOYOTA 4 RUNNER CONVERSION http://www.bev.ba/TOYOTA4RUNNER/index.html
          2023 BEV, BIH, SARAJEVO START PROJECT: SECRETS AND MANUFACTURING PLANS (AS MY REPLICA) OF THE LIBERTY ENGINE 2.0.
          2022 BEV, PROJECT ?
          2021 BEV, PROJECT ?
          2020 BEV,BiH, Sarajevo: PROJECT IS: HOW TO SWITCH OFF PERMANENT MAGNET FIELD and HOW TO SWITCH ON PERMANENT MAGNET FIELD?
          2019 BEV, Croatia, Ston:, Broce: PROJECT - PROJEKT ELEKTRIČNI GLISER http://www.bev.ba/ELEKTRICNIVANBRODSKIMOTOR/indexHR.htm...
          12-28-2023, 02:09 PM
        • hollox123
          ASUS ROG Strix G713QR - Keyboard, backlight and side LEDs don't work
          by hollox123
          Hello, I have an "ASUS ROG Strix G713QR" laptop, and for approx. 3 months I have the following problems:
          1. Laptop keyboard doesn't work
          2. The backlight on the laptop keyboard doesn't work
          3. The x2 side LEDs (red) on the laptop don't work
          The power button works, the touchpad works, and all the USB, HDMI, Ethernet, etc. ports work.
          I already tried to reinstall all the drivers and reinstall Windows. So I don't know what to try anymore that is software-related.
          But I am strongly aiming that it is somehow a BIOS-related problem,...
          05-11-2025, 08:05 AM
        • Byte_76
          Requesting assistance with 486 motherboard repair
          by Byte_76
          I have a seemingly rare 486 motherboard which shows no signs of life.
          The Motherboard is marked with the labels B887 / 8 / 9 AI, which seems to be a Mecer branded board.
          With an AT power supply hooked up, the power supply turns on but the board does not post, there is no beep and there is nothing displayed on the post analyser card, whether it's plugged into a PCI slot or an ISA slot.
          I found a thread on Vogons of someone else who had the same board in working condition.
          What I've tried so far: (In each case, the symptoms remain unchanged as...
          04-12-2025, 06:43 AM
        • goodpsusearch
          Sony STR-DE445 did I get a faulty IC?
          by goodpsusearch
          Hello, I got this AVR for cheap and tried to fix it as a fun and learning project.
          First the audio video receiver would turn on but had no sound at all, but no "PROTECT" message.
          So, I opened the metal case and noticed some marks showing that some liquid has been spilled on the amp. Those water marks were found on the main board and the digital board.
          I disassembled everything, then checked every single cap on every board of the amp and recapped when needed.
          Also fixed A LOT of cold solder joints and also done some modifications,...
          04-15-2023, 04:16 PM
        • titomno2
          Gaming Laptop Zephyrus S17 TFT not detected every time !
          by titomno2
          Hi guys,
          I post my problem here because I think it could be a capacitor related issue (Asus support on this particular subject is non-existing).
          So the computer is a Zephyrus-S17-GX735LXS-26T and the strange behavior is seen.
          On cold start most of the time the internal screen is detected and a picture it works fine until shutdown, sleep or deep sleep.
          Then the screen won't work for a long period of time.
          If I wait 1 or 2 hours it work again most of the time.
          When it doesn't work the batterie indicator blink 3 times white stop and the same schematic is repeated...
          01-19-2025, 08:27 AM
