Laptop charger
  • eknas
    • Nov 2014
    • 10
    • Spain
    Laptop charger
    Hi, I replaced the big cap, (120uF, 400V) on an ASUS 90W charger (model: adp-90cd DB), (Datasheet: ) and still did not work, I got 0V at the output and the led does not bright.
    I used the polimeter and looked for fuses. As the datasheet shows, there is one called F2, but I did not find it on the circuit. I found instead the F1 component shown at the picture. I made some tests and the caps CX1 and CX2 have 0V when the charger is switched.
    My question is, would be that F2 component at the pic, the F1 fuse in the datasheet that is causing the failure? I apologize for this question but I don't know what is the F2 component at the pic..
    master hoarder
    • May 2008
    • 12175
    Re: Laptop charger
    Before replacing any components on a laptop power adapter that outputs 0 Volts, first check if the power cord (+) and (-) leads are shorted. This is a very common problem. Pictures of the laptop power adapter would also be helpful.
    • eknas
      • Nov 2014
      • 10
      • Spain
      Re: Laptop charger
      Hi, thank you for your answer. I have tested the power cord and the leads are not shorted. I finally found out that the F1 is a fuse that is open.
      Another question is I don't have a 120uF 420V cap to replace it (the original has a 14ohm ESR so i need to replace it), I have a recicled 100uF 420V instead.., do you think it will do the job or should I wait until monday to go to the store?
      • Th3_uN1Qu3
        Believe in
        • Jul 2010
        • 6031
        Re: Laptop charger
        100uF will be fine. But if the fuse has blown chances are the primary MOSFET and the controller have also died.
        A working TV? How boring!
        • flat-earther
          ASUS X54H laptop thinks it's always charging even with charger unplugged
          by flat-earther
          The charging indicator light on my ASUS X54H laptop is always on even when the charger is disconnected.
          Windows also shows ''Plugged in'' when charger is not connected.
          This problem started year ago gradually, when unplugging the charger the charging light took several seconds to disappear, then minutes, and now almost always on even when unplugged for an entire day.
          Strangely, before sometimes immediately when plugging in the charger the charging light went away, and later came back with it connected.
          If I let battery run out and say it has 3% Windows will...
          06-24-2025, 09:32 AM
        • serious_electron
          Strange! Acer laptop not powering on but charging the battery (orange light on when charger and battery plugged in).
          by serious_electron
          Hello Everyone!
          I have an Acer Aspire A315-42 laptop. I generally leave it on for long time by closing down its lid (so it enters the sleep mode). Recently, it rained quite heavily in out area. And the humidity and moisture seem to be high. So one late evening, after I opened the lid and turned on the laptop, it did power on as the blue light turned on but after it booted to the desktop screen, just 5-10 seconds after both the screen and blue light went out and laptop shut down (the blue power light turned orange). And after 2-4 seconds that orange light went off and the laptop died.
          06-28-2025, 02:57 PM
          ISL6257HRZ ISL6257HRZ-T Laptop Battery Charger Datasheet
          Highly Integrated Narrow VDC Battery Charger for Notebook Computers
          The ISL6257HRZ ISL6257HRZ-T is a highly integrated battery charger controller
          for Li-Ion/Li-Ion polymer batteries. ISL6257 is designed for
          Narrow VDC applications where the system power source is
          either the battery pack or the regulated output of the charger.
          This makes the max voltage to the system equal to the max
          battery voltage instead of the max adapter voltage. Operating
          at lower system voltage can improve...
          11-05-2024, 04:43 PM
          NVDC charger configuration...
          11-05-2024, 03:28 PM
          Microsoft Surface Laptop 3 13.5-inch i5/8GB/256GB SSD Laptop Platinum Notebook Specification for Upgrade or Repair
          This specification for the Microsoft Surface Laptop 3 13.5-inch i5/8GB/256GB SSD Laptop Platinum Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Surface Laptop 3 13.5-inch i5/8GB/256GB SSD Laptop Platinum boardview and Surface Laptop 3 13.5-inch i5/8GB/256GB SSD Laptop Platinum schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from...
          09-06-2024, 09:30 PM
