Trouble finding short on 3V rail
  • p1muserfan
    • Apr 2014
    • 184
    I'm having a hard time finding the short on the 3v rail of this board. Pin 7 of PU1 with PL4 removed (p. 32) is measuring short, so that would be +3VPCU. With my power supply set to 3v and 2a I measured 0v and 2a when I put the probe on the PL4 pad. PC35 got hot really quick, removed it. Now measuring 3v and 1.5a so is there still a short? I also made a list of things on the 3v rail and its pretty big, so is there something that usually is the problem? Nothing else seems to be getting hot. KBC is already removed. Any suggestions where to zero in on would be great
  • fddizon
    • Sep 2011
    • 555
    • Philippines
    Re: Trouble finding short on 3V rail
    Measure PL4 to ground with no power on the board.
    if low resistance, then still have a short. if you can meaure 3v then no short anymore on that rail
    • Victor Moreira Silva
      Acer Nitro 5 LA-L181p power LED turns on by 5 secs (Short on PCH rail?)
      by Victor Moreira Silva
      I'm trying to repair my old Acer Nitro 5 (AN517-54-55T5). I've already bought a new laptop, so this is more of a learning project. For the experience, with no high expectations of success.
      Well, my decice specs are the following:
      Model: Acer Nitro 5 AN517-54-55T5
      CPU: Intel Core i5-11400H
      GPU: NVIDIA GeForce GTX 1650
      Motherboard: GH51G LA-L181P Rev:1c
      The symptom:
      When pressing the power button, the power LED lights up for about 5 seconds and then turns off. Initially, the issue was intermittent: sometimes...
      05-26-2025, 10:49 AM
    • grimacelord
      Xbox One S - 12V Rail Short - Q9F1 Keeps Blowing
      by grimacelord
      Have an Xbox One S here that has a short on the 12V power rail. There is no power, beep, or partial fan spin when connecting power cable.
      After diagnosing with thermal camera, Q9F1 MOSFET (NTTFS4C50N) is getting hot. When I remove this MOSFET, the short on the 12V rail disappears.
      I first replaced Q9F1 with one from a donor board and then partially reassembled the Xbox to test. When I plugged the power cord in, I got a partial fan spin and I thought I had fixed it, but unfortunately, the Xbox still did not power on. So I then disassembled the Xbox...
      10-24-2024, 12:31 PM
    • nagkiller
      Asus Geforce Cerberus GTX1050TI-O4G-DIS short circuit in the FBVDDQ rail
      by nagkiller
      Hello everyone!
      This grafic card came for repair, but when I connected it to the motherboard, the board would not start (short circuit in the 12V rail).
      After removing some PLs to isolate the short in the 12V rail, I got to PML1/PML2, according to the BoardView reference.
      Even injecting a voltage of 1V0 and a current of 3A in the FBVDDQ rail, for example, the voltage drops to 0V20 and none of the components heat up.
      The attached boardview file is very similar to this grafic card, which I am basing the repair on.
      I would like some...
      05-10-2025, 09:19 AM
    • joshAU
      Acer AN515-55-528T FH52M LA-J891P - Short ciruit after PQW1 MOSFET on +1.35VSDGPU rail.
      by joshAU
      Hi all.
      This notebook was showing no signs of life.
      I removed the FH52M LA-J891P mainboard and found that there was 19V at the DC jack.
      However there was zero volts on the two PRB2 and PRB46 resistors immediately after the two polarity protection MOSFETs (PQB11 & PQB12).
      If I remove the PQW1 MOSFET, the 19V rail starts working, and I can turn on the unit - at least I get the fans, and the power light comes on, when I simulate the power button being pressed. No display.
      I tried replacing the MOSFET with a new one, but again no voltage on the...
      05-29-2024, 12:33 AM
    • techrepairheide
      Gaming laptop Clevo NH79EP with short on 5VS-rail
      by techrepairheide
      first of all I want to apologize for my bad English, but I try to give my best.
      Customer brought me a laptop, which is charging the battery (when the dc-jack is connected) but don't power up when the power-button was pressed down. Only the white LED lights up, and you can hear a short noise in same interval when power-button was pressed and hold for longer timer. The customer changed already battery and dc-power-adapter.
      For this laptop the correct shematic is the service manual "Clevo NH50ER NH57ER NH50EPS NH57EPS - 6-71-NH5S0-D02 Schematic"....
      10-13-2024, 02:49 PM
