Infineon TPM 1.2 Chip slb 9635 tt1.2 please help
  • The ENIGMA
    • May 2015
    • 47
    • Egypt
    is there any way to reprogram this chip
    or reset it to remove stored password keys
    there no even data sheet for it but I found it in a
    laptop board schematics
    HP elitebook 2540p
    it's number u34 and the SPI bios chip u35
    i'm afraid to do anything without an advice I could blown the chip with no chance to get this pc back to life
    PLEASEEEEEEEEE HELP
  • diif
    • Feb 2014
    • 6978
    • England
    Re: Infineon TPM 1.2 Chip slb 9635 tt1.2 please help
    To clear the TPM you need to enter the BIOS. The TPM only holds the bitlocker key.
    You will lose access to the files though if they have been encrypted by bitlocker.
    • The ENIGMA
      • May 2015
      • 47
      • Egypt
      the bios has an administrator password
      when i try to remove it by removing Cmos battry it locked out
      now i can't do anything with this laptop till i enter admin password
        • 31028
        passwords are usually stored in the flash,
        if you want to get rid of ithe tpm try shorting the crystal, some laptops wil run without it because they sell export models to some country's without the chip.
        • The ENIGMA
          • May 2015
          • 47
          • Egypt
          thanks Stj
          how can i short the TPM chip
          excuse my ignorance
          i'm afraid
          short which pin to the ground ??
          i've tried reflashing ,,, all bins availabe 3.0mb the backed up was 8.0mb
          i've tried ver f.09 f50 but no boot after programing
          seem it's business laptop with custome german bios
            • 31028
            on your own attached schem are 2 pins on the chip that connect to the crystal (13 & 14) - link the pins together and the chip wont run.
            • The ENIGMA
              • May 2015
              • 47
              • Egypt
              thanks STj
              I understand now that TPM chip has nothing to do with locked bios I removed it totally like you said laptop worked but still asking for passwords
              it's a BIOS chip matter I'll try to find the right clean software then reprogram it
              I got this wrong I thought this chip stores password
              thanks for your help your time
              now i'm looking for clean bios for Elitebook 2540p
              it's mainboard is COMPAL KAT10 LA-5251p Rev 1.0
              • The ENIGMA
                • May 2015
                • 47
                • Egypt
                you are right i thought this chip stores all passwords not only the bitlocker key
                I understand now thanks
                • adekunlekunle
                  • Nov 2015
                  • 6
                  • United Kingdom
                  do you have the tpm 1.2 file
                  pls help
                    • 31028
                    there is no file, the tpm is just a password encrypted eeprom that the bios stores keys inside.
