Infineon TPM 1.2 Chip slb 9635 tt1.2 please help
  • The ENIGMA
    • May 2015
    • 47
    • Egypt
    is there any way to reprogram this chip
    or reset it to remove stored password keys
    there no even data sheet for it but I found it in a
    laptop board schematics
    HP elitebook 2540p
    it's number u34 and the SPI bios chip u35
    i'm afraid to do anything without an advice I could blown the chip with no chance to get this pc back to life
    PLEASEEEEEEEEE HELP
  • diif
    • Feb 2014
    • 6978
    • England
    Re: Infineon TPM 1.2 Chip slb 9635 tt1.2 please help
    To clear the TPM you need to enter the BIOS. The TPM only holds the bitlocker key.
    You will lose access to the files though if they have been encrypted by bitlocker.
    • The ENIGMA
      • May 2015
      • 47
      • Egypt
      the bios has an administrator password
      when i try to remove it by removing Cmos battry it locked out
      now i can't do anything with this laptop till i enter admin password
        • 31015
        passwords are usually stored in the flash,
        if you want to get rid of ithe tpm try shorting the crystal, some laptops wil run without it because they sell export models to some country's without the chip.
        • The ENIGMA
          • May 2015
          • 47
          • Egypt
          thanks Stj
          how can i short the TPM chip
          excuse my ignorance
          i'm afraid
          short which pin to the ground ??
          i've tried reflashing ,,, all bins availabe 3.0mb the backed up was 8.0mb
          i've tried ver f.09 f50 but no boot after programing
          seem it's business laptop with custome german bios
            • 31015
            on your own attached schem are 2 pins on the chip that connect to the crystal (13 & 14) - link the pins together and the chip wont run.
            • The ENIGMA
              • May 2015
              • 47
              • Egypt
              thanks STj
              I understand now that TPM chip has nothing to do with locked bios I removed it totally like you said laptop worked but still asking for passwords
              it's a BIOS chip matter I'll try to find the right clean software then reprogram it
              I got this wrong I thought this chip stores password
              thanks for your help your time
              now i'm looking for clean bios for Elitebook 2540p
              it's mainboard is COMPAL KAT10 LA-5251p Rev 1.0
              • The ENIGMA
                • May 2015
                • 47
                • Egypt
                you are right i thought this chip stores all passwords not only the bitlocker key
                I understand now thanks
                • adekunlekunle
                  • Nov 2015
                  • 6
                  • United Kingdom
                  do you have the tpm 1.2 file
                  pls help
                    • 31015
                    there is no file, the tpm is just a password encrypted eeprom that the bios stores keys inside.
                    • acedogblast
                      by acedogblast
                      11-02-2024, 05:13 PM
                      by SMDFlea
                      Bad...
                      09-02-2021, 04:40 PM
                    • BMCappelletti
                      Asus Chromebox CN62 - wrong chip put on BIOS reader
                      by BMCappelletti
                      Long story short:
                      - dad converted Asus Chromebox CN62 into Windows compatible, with mrchromebox BIOS, years and years ago
                      - gave the computer to his son a couple years later
                      - son now decided to revert it to Chrome OS, to sell it as original (re-writing BIOS with the backup one created by his dad)
                      - too lazy to remove the board from the case, thought a voltage regulator was the BIOS chip (you know... it has 8 legs)
                      (seems like the story was not that short)
                      He used alligator clips to read the chip. No luck reading it. Removed chip and placed on a SOC-8...
                      01-08-2025, 07:27 PM
                    • Troystain
                      Help EZP2023+ updated chip database for w25q256jveq?
                      by Troystain
                      Hello, anyone here have updated ezp2023+ chip database in .dat file format.
                      I need to add w25q256jveq chip but I do not know what data should I type.
                      I'm using the ezp chip dabase editor posted from here https://www.badcaps.net/forum/troubl...ro-programmers
                      The currenty unit model that I am trying to detect is HP elitebook 640 g9 which is currently locked on admin bios....
                      11-25-2024, 12:53 AM
                    • inck243
                      Acer e15-e5-576g-5762 bricked. Bios chip won't interface in AsProgrammer.
                      by inck243
                      Thanks for any help. The board version is DAZAARMB6E0 REV: E. The bios chip is winbond 25Q64JVSIQ1736. W25Q64JV is not available in AsProgrammer -- only BV CV FV or FW_1.8c. The chip won't interface with asProgrammer and a CH341A. When I have this chip on the board, the laptop will not post but when I plug it in to power, the blue LED lights up, also the orange when the battery is connected. When I push the power on button, keyboard backlight turns on and the fan starts briefely then turns off. But I can't do anything to program this bios chip so I bought another one.
                      The BIOS...
                      07-25-2024, 09:17 AM
