Dell e6320 touchpad not working
  • dj_ricoh
    • 2073
    • uk
    Hy guys!
    Got this awesome notebook(not) that I need to fix the mouse pad.
    Weird part is that the joystick on the keyboard does not work.
    I thought that maybe only the touch will be bad but I can't understand why both are not working.
    I have the beast at home and I will try to downgrade the bios. Maybe maybe .
    I'll try to see if there is activity on pads with scope.
    Maybe someone had similar problem like my one.
    My option are:
    1. Kbc bad
    2. Bios bad(I saw a13 on start)
    3.touchpad or joystick bad disable each other if they both connected.
    I need to try the 3rd option before you go any further.
    Any tips or info will be nice.
    Thank you guys.
    P.s. joystick its connected via keyboard foil and keyboard its working and USB mouse.
  • gcomputers
    • Apr 2013
    • 509
    • Albania
    Re: Dell e6320 touchpad not working
    test in the BIOS, the touchpad on this model is used in bios
    • dj_ricoh
      • 2073
      • uk
      It doesn't work in bios neder in windows setup.
      • dj_ricoh
        • 2073
        • uk
        Last night when I was probing with the scope on the pads I saw something cool.
        The fan was off. It's broken.
        This notebook got soldered cpu so I'm guessing where the problems started.
        I think I'll abandon it because the quak client forgot to mention and I'll make him pay.
        • dellxps15
          • Feb 2014
          • 1598
          • italy
          what cpu is it ? i3 i5 i7 ?
          • dj_ricoh
            • 2073
            • uk
            I think i5
            • dj_ricoh
              • 2073
              • uk
              OK.
              Had this notebook finish this week.
              There was so much dust inside that it went under the mouse pad connector.
              Killed the fan and I manage to do a dyi job and ressurect it.
              Mouse was up, fan was up and he pay a lot d
              IPA FTW
              • Bowline
                by Bowline
                06-11-2025, 10:13 AM
                Dell Latitude E6320 Schematic
                Dell Latitude E6320 Compal LA-6611P Schematic...
                10-04-2024, 07:50 AM
              • Akhlz001
                by Akhlz001
                09-20-2025, 07:15 PM
              • master3112
                by master3112
                07-29-2025, 01:55 PM
                Dell Thunderbolt Firmware
                by SMDFlea
                Dell thunderbolt firmware, extracted from dell firmware update exe. Padded to 1MB.
                Some models have a choice of 2 different firmwares, it depends on the dell SKU.
                The SKU is in brackets (****)
                EDIT: NVM65...
                01-26-2025, 06:22 AM
