hp g62 (AX1) Working with battery not with adapter
    I got this yesterday Working with battery not with adapter hp g62 (AX1)
    checked flowing component
    when connect adapter voltage comes up to pq 52 (P0603BDG) n channel fet
    D - 18.5v
    S-6.25V
    G-6.25V
    charger ISL 6251 no out put of ACOK# and I had spare one with me replaced but no luck still same as it.
    charger ic voltages are
    1-5v
    2-2.14v
    3-1.1v
    4-4.4v
    5-0v
    6-0v
    7-0v
    8-2.3v
    9-0v
    10-1.5v
    11-1.5v
    12-0v
    13-0v
    14-0v
    15-5v
    16-5.8v
    17-5.8v
    18-6.25v
    19-6.25v
    20-6.25v
    21-6.25v
    22-6.25v
    23-0v
    24-18.5v
    didn't try to bypass pq52 yet
    pq 52 gate voltage is low any idea??
    sigpic
    Re: hp g62 (AX1) Working with battery not with adapter
    Any idea
    sigpic
      Pu2 pin 1 must be 19v
      pu2 pin 8 must be 28v
      check
        check
        Thanks for reply , I think you got the point exactly.
        Pu2-pin 1 -19v 0k
        pin 8-28v ok
        further I checked PR 227 ,one side 28v and other side 0.6 v .
        resistor Value is 20k(fluctuating) but it should be 150k. will replace it first and let you know
        sigpic
          replaced pq 227 but 6.25 v present but nothing has changed
          sigpic
            are you solved this one?
              EN is the Charge Enable input -0.3 ,+0.3v so 1.1v its high to enable charging(then its OK)
              VDD pin 1 its 5v for internal supply (so its OK)
              Pin 23 ACPRN needs to be max 7v.
              ACPRN(ACOK#) its low when ACIN(ACSET) pin 2 its higher the 1.2v
              you got 2.1v so its OK
              when ACIN its LOW 0v then ACOK# its high
              check pq9 until you reach KBC.
              check PR235 and see if its ok. maybe there it does not trigger
                [QUOTE=nazrul145;602851]are you solved this one?[/QUOTE
                Not yet my friend
                sigpic
                  Thanks for your time dj_ricoh,
                  checked PR 235 -99k
                  pq 9
                  pin 1 - 0v
                  pin 2 -0v
                  pin 3- 5.6v
                  PR 81 - 0v
                  PD - 13 - NC
                  PC 92 - NC
                  SIO pin 72 _ 0v
                  sigpic
                    what about PQ56? Have you check that it's OK?
                      Remove PQ52 and make measure again, or change q52, may be bad PC 202, measure resistencia. In gate of PQ52 must be 25 -28v
                        solved!!! Faulty One was Pq 55 Thanks every one for supporting dycc,nazrul145,dj_ricoh,meritosari,saularciga
                        sigpic
