hp g62 (AX1) Working with battery not with adapter
  • samanthban
    • Feb 2014
    • 253
    • Sri lanka
    I got this yesterday Working with battery not with adapter hp g62 (AX1)
    checked flowing component
    when connect adapter voltage comes up to pq 52 (P0603BDG) n channel fet
    D - 18.5v
    S-6.25V
    G-6.25V
    charger ISL 6251 no out put of ACOK# and I had spare one with me replaced but no luck still same as it.
    charger ic voltages are
    1-5v
    2-2.14v
    3-1.1v
    4-4.4v
    5-0v
    6-0v
    7-0v
    8-2.3v
    9-0v
    10-1.5v
    11-1.5v
    12-0v
    13-0v
    14-0v
    15-5v
    16-5.8v
    17-5.8v
    18-6.25v
    19-6.25v
    20-6.25v
    21-6.25v
    22-6.25v
    23-0v
    24-18.5v
    didn't try to bypass pq52 yet
    pq 52 gate voltage is low any idea??
    sigpic
  • samanthban
    • Feb 2014
    • 253
    • Sri lanka
    Re: hp g62 (AX1) Working with battery not with adapter
    Any idea
    sigpic
    • dycc
      Vision
      • Nov 2011
      • 625
      • CΓ΄te d'Ivoire
      Pu2 pin 1 must be 19v
      pu2 pin 8 must be 28v
      check
      • samanthban
        • Feb 2014
        • 253
        • Sri lanka
        check
        Thanks for reply , I think you got the point exactly.
        Pu2-pin 1 -19v 0k
        pin 8-28v ok
        further I checked PR 227 ,one side 28v and other side 0.6 v .
        resistor Value is 20k(fluctuating) but it should be 150k. will replace it first and let you know
        sigpic
        • samanthban
          • Feb 2014
          • 253
          • Sri lanka
          replaced pq 227 but 6.25 v present but nothing has changed
          sigpic
          • nazrul145
            • Jan 2014
            • 333
            • BD
            are you solved this one?
            • dj_ricoh
              • 2073
              • uk
              EN is the Charge Enable input -0.3 ,+0.3v so 1.1v its high to enable charging(then its OK)
              VDD pin 1 its 5v for internal supply (so its OK)
              Pin 23 ACPRN needs to be max 7v.
              ACPRN(ACOK#) its low when ACIN(ACSET) pin 2 its higher the 1.2v
              you got 2.1v so its OK
              when ACIN its LOW 0v then ACOK# its high
              check pq9 until you reach KBC.
              check PR235 and see if its ok. maybe there it does not trigger
              • samanthban
                • Feb 2014
                • 253
                • Sri lanka
                [QUOTE=nazrul145;602851]are you solved this one?[/QUOTE
                Not yet my friend
                sigpic
                • samanthban
                  • Feb 2014
                  • 253
                  • Sri lanka
                  Thanks for your time dj_ricoh,
                  checked PR 235 -99k
                  pq 9
                  pin 1 - 0v
                  pin 2 -0v
                  pin 3- 5.6v
                  PR 81 - 0v
                  PD - 13 - NC
                  PC 92 - NC
                  SIO pin 72 _ 0v
                  sigpic
                  • meritosari
                    • Oct 2010
                    • 774
                    • Indonesia
                    what about PQ56? Have you check that it's OK?
                    • saularciga
                      • Feb 2014
                      • 55
                      • mexico
                      Remove PQ52 and make measure again, or change q52, may be bad PC 202, measure resistencia. In gate of PQ52 must be 25 -28v
                      • samanthban
                        • Feb 2014
                        • 253
                        • Sri lanka
                        solved!!! Faulty One was Pq 55 Thanks every one for supporting dycc,nazrul145,dj_ricoh,meritosari,saularciga
                        sigpic
                        • bajdik
                          Lenovo V310-15ISK DA0LV6MB6F0 working on battery only / adapter cause OCP S5_on
                          by bajdik
                          I have a Lenovo V310-15ISK. On battery works everything fine. Boot into the Windows. With original Lenovo 45W adapter charging battery (if is laptop shutted off).
                          When is laptop power on (on the battery), the adapter is not dected if is plugged in. If battery is not presented, it power on with adapter but after 2 seconds OCP S5_on power off the laptop.
                          Any idea what should be wrong?...
                          01-18-2024, 09:58 AM
                          DELL XPS 9365 Hybrid (2-in-1) 13 Specification for Upgrade or Repair
                          This specification for the DELL XPS 9365 Hybrid (2-in-1) can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 9365 boardview and 9365 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for DELL XPS 9365 Hybrid...
                          09-06-2024, 05:40 AM
                        • baddjavo
                          Working Asus r752lx, orange light when connect adapter, even without battery
                          by baddjavo
                          I have 17.3 inch asus laptop probably whit dead battery, so i decided to replace with new one. But not charging, on old battery show 0% and with new battery its 1%. Looks like that laptop detecting battery always. On battery connector its around 15v, 3v, 3v, gnd.
                          motherboard is : tmt YA-4A 19 94V-0 E114139, 1533-61-22
                          No schematics, no boardview, but i found BQ735 charging chip on mb.U can see voltages on picture.
                          I checked mosfets, not all, they looks fine.
                          If anyone can explain what here happening ......
                          07-31-2024, 08:51 PM
                          DELL XPS 9560 Notebook 15 Specification for Upgrade or Repair
                          This specification for the DELL XPS 9560 Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 9560 boardview and 9560 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for DELL XPS 9560 Notebook...
                          09-06-2024, 06:06 AM
