Hp dv6z-7200 - constant flashing CAPS LOCK
  • itoffshore
    • Oct 2015
    • 5
    I cleaned out the fans & tried upgrading the APU to an A10-5750M but now with either this APU or the original A10-4600M the CAPS LOCK flashes constantly:
    https://www.youtube.com/watch?v=nm4E6zWFrCg
    This is supposedly a power problem but there is enough power to the board for it to overheat & switch off when wrapped in towels.
    I've tried a hard reset & bios recovery without success.
    I wondered if an HP UEFI BIOS will brick a machine if unsupported hardware is added ? (& if I can reflash it with a USB Programmer & Test Clip).
    Or is it more likely that the discrete graphics needs to be reballed ? (the laptop was previously overheating badly & shutting off before I cleaned it out).
    Or could it be some other problem ?
    http://www.mediafire.com/download/n8...-mobo-pics.zip
  • dellxps15
    • Feb 2014
    • 1598
    • italy
    Re: Hp dv6z-7200 - constant flashing CAPS LOCK
    i would reball northbridge
    image size is invisible...
    • itoffshore
      • Oct 2015
      • 5
      Original pictures http://www.mediafire.com/download/n8...-mobo-pics.zip
      • RJARRRPCGP
        • Jul 2004
        • 6304
        Is it an AMD? If so, likely a CPU problem.
        At least that's what the blink code seemed to indicate on a CQ-61. (Athlon II) (2009-2014, IIRC) (RIP)
        It looks like HP's AMD laptops are prone to overheating and BSOD'ing at stock core clocks!
        And that was before failing with a repeated slow LED blink. HP's version of the RROD.
        (BTW, it's never supposed to BSOD at stock, period!) (Even with high core temps!)
        (Other laptops are more likely to throttle, IIRC!)
        ASRock B550 PG Velocita
        Ryzen 9 "Vermeer" 5900X
        Arc A770 16 GB
        eVGA Supernova G3 750W
        Alienware AW3423DWF OLED
        • Th3_uN1Qu3
          Believe in
          • Jul 2010
          • 6031
          I don't think i've seen a single CPU fail in these. It's always the chipsets. Besides, he already said he tried 2 processors.
          A working TV? How boring!
          • itoffshore
            • Oct 2015
            • 5
            I can buy a new motherboard on aliexpress for $150 or send the laptop to have the video card reballed properly for approx GBP 50 (there were artifacts on the screen previously so it may be the discrete video card that is the problem).
            Could there be other problems caused by overheating besides the video & it would be as economic to buy a new motherboard & sell the broken one on Ebay ?
            • Th3_uN1Qu3
              Believe in
              • Jul 2010
              • 6031
              You did not mention the discrete GPU before. Yes it is very possible that the GPU is at fault not the processor.
              I would send the board for reballing if they are trusted, AMD chips tend to hold up well after reballing, we have very few returns.
              • itoffshore
                • Oct 2015
                • 5
                I was not able to repair the DV6Z-7200 mobo & bought a new DV6Z-7000 mobo (hp 682183-001) with a later gen video card (AMD 7730M vs 7690M originally).
                Are HP laptops known to soft brick if you try installing a non standard CPU (AMD A10-5750M Richland) - rather than the A10-4600M Trinity it came with originally ?
                Some people have been successful upgrading a Trinity ---> Richland with the HP G6's / Pavillion.
                • karim_hassan777
                  • Oct 2015
                  • 15
                  • Egypt
                  hi guys i have a power problem with a similiar one to this HP pavilion dv6-7010us
                  with motherboard Kroyer/Yeats 1.0 mb 11277-2 48.4sv01.021 can any one give the datasheet of it ?
