LA-A091P power issue
  • rookieme
    • Oct 2014
    • 396
    • Greece
    Hi team,
    at this board I'm having no power issue.
    I have 19V at the output of PQ301 but 0V at output of PQ302.
    I'm not sure what to check.
    Both of them share the same gate (19V) and are in working condition.
  • angel-boy
    • 550
    Re: LA-A091P power issue
    check pq304 and 303, you dont receive the gate for pq301 and 302 ( 4pin)
    Is posible to have a short after 301, and that`s why power missing.
    You chan short pq301, and measure pq302 out , if is 0v, short before pq301 and after pq302
    • rookieme
      • Oct 2014
      • 396
      • Greece
      I have already checked pq303 & pq304 and they have no short.
      In fact I have removed pq304 and had the same result.
      I see no short, current flows from pq301 but not from pq302.
      What voltage should pq302 have at the gate in order to let the current flow?
      • meritosari
        • Oct 2010
        • 774
        • Indonesia
        + 7-9v
        • rookieme
          • Oct 2014
          • 396
          • Greece
          I get 19V there...
          • meritosari
            • Oct 2010
            • 774
            • Indonesia
            -voltage acdet and acok?
            -voltage PQ303 PQ304 PQ307?
            • samanthban
              • Feb 2014
              • 253
              • Sri lanka
              you need negative voltage to open the fet check pq 307 pin 5
              sigpic
              • rookieme
                • Oct 2014
                • 396
                • Greece
                ACOK 4,3V
                ACDET 3,2V
                PQ307 pin6 13,1 V pin2 ~0V
                PQ303 pin2 13,1 V pin1 17,5V
                PQ304 pin2 17,5 V pin1 19,7 V pin3 19,7V
                • rookieme
                  • Oct 2014
                  • 396
                  • Greece
                  PQ307 pin5 ~0V, pin3 16V
                  • samanthban
                    • Feb 2014
                    • 253
                    • Sri lanka
                    Ok.. check pq 308 voltage
                    sigpic
                    • rookieme
                      • Oct 2014
                      • 396
                      • Greece
                      PQ308 pin2 4,2 V pin1 ~0V
                      • samanthban
                        • Feb 2014
                        • 253
                        • Sri lanka
                        I think this is the culprit check this transistor.
                        sigpic
                        • fddizon
                          • Sep 2011
                          • 555
                          • Philippines
                          check PQ302 pin 5678 against ground
                          (this will Bypass protection circuit)
                          if there is no short, lift pin 4 of FET PQ302. signal will pass.
                          if DC bench is available use it as the source
                          if no dc bench
                          Note: make a quick insert of the adapter and check parts that will heat up. quickly remove if smoke will come up
                          with this method, you will quickly find the shorted component.
                          • rookieme
                            • Oct 2014
                            • 396
                            • Greece
                            if no dc bench
                            That is correct, I have a short after the PQ302.
                            Previously I have done a reballing at GPU and I think that a component didn't survive the heat, it's not the GPU [I removed it again].
                            I'll make some measures before connecting power.
                            • rookieme
                              • Oct 2014
                              • 396
                              • Greece
                              Finaly it was a bad cap, I used a AA power cell 1,5V that managed to make the cap boiling hot.
                              Thank you all for your time.
                              • angel-boy
                                • 550
                                i told you this from begining ))
                                i did not tell you to check for short, i told you to make a short ( create ) you must unit the pq301 ( 8.7.6.5 pins ) with ( pq302 8.7.6.5 pins )
                                • rookieme
                                  • Oct 2014
                                  • 396
                                  • Greece
                                  Sometimes I'm a bit rookie
                                  • angel-boy
                                    • 550
                                    is important that mainboard work now.
                                    • samanthban
                                      • Feb 2014
                                      • 253
                                      • Sri lanka
                                      if no dc bench
                                      very nice thanks for sharing
                                      sigpic
                                      • abbas_govani
                                        • Jul 2013
                                        • 89
                                        • India
                                        Hi guys,
                                        i have a problem with this board,
                                        pu401 is getting heated. i checked there is 8 ohms on pc414 witch is +3vlp.
                                        i removed thi ic and capacitor too but the resistance is same. can any one have any idea to rectify this problem.
                                        thanks in advance.
                                        • GLISIT
                                          by GLISIT
                                          01-16-2025, 02:29 PM
                                        • justice171
                                          Acer Spin 1 SP111-33 Power-On Issue (Troubleshooting Assistance)
                                          by justice171
                                          I am seeking guidance on an Acer Spin 1 SP111-33 that does not turn on when pressing the power button.
                                          Below are the observations and troubleshooting steps I have taken so far: Observations and Tests:
                                          1. Verified that all critical voltages are present:
                                            • 3.3V and 5V are always present if DC is plugged.
                                            • 1.8V on the BIOS chip is present.
                                          2. Checked the power button functionality:
                                            • When pressed, the voltage drops to 0V, indicating the button is functional.
                                          3. Inspected the flex cable connecting the USB, audio, and power button to JUB1:
                                            • Confirmed connectivity is intact, ruling out issues
                                          11-26-2024, 12:39 AM
                                        • claws77
                                          lenovo flex 5 14itl05 power sequence issue
                                          by claws77
                                          hi guys, my motherboard will not start no matter what
                                          when connected to ac power, the battery does get charge, led indicator glows red when discharged and turns white as it is fully charged.
                                          but rest nothing happens no sign of life.
                                          this laptop has one preexisting usbc power issue - so i use DCIN jack for charging my laptop.
                                          with this issue my laptop was unable to power ON only sometimes i just had to wait some time.
                                          but now nothing happens no matter how much i wait/ charge/ press and hold power button.
                                          i have no knowledge of motherboards ....
                                          10-20-2024, 02:48 PM
                                        • SuperJames
                                          Dell G3 17 3779 Weird power cycling and shutdown/restart issue
                                          by SuperJames
                                          This one's a weird one, and still unsolved despite it having gone back to Dell once.
                                          Specs
                                          i7-8750H, GTX 1060 Max Q, 500GB SSD & Seagate 7mm 1TB HDD. 17.3 IPS screen. This has the fingerprint reader in the power button.
                                          Backstory
                                          I bought this from eBay, from a wallpapering shop. £650 in 2020 which was a good price considering it's a gaming laptop. Physically it's in perfect shape, apart from the hinge mounts on the palmrest failing in the time I've had it (I have a new palmrest for it). The usual thin plastic crap modern build quality!...
                                          10-23-2023, 04:09 PM
                                        • Soulzink
                                          Samsug washing machine. Power supply DC41-00189a board issue
                                          by Soulzink
                                          I am trying to fix a samsung washinmachine power supply main board.
                                          I already replaced it with another one to fix the machine but i want to try understand the issue with the old board.
                                          Therefore i hope to be able to get some help to explain what to check in order to troubleshoot.
                                          The power supply board reference is the following: DC41-00189a
                                          I have followed one thread (https://www.badcaps.net/forum/troubl...ingmachine-rel...
                                          04-19-2025, 06:26 AM
