LA-A091P power issue
  • rookieme
    • Oct 2014
    • 399
    • Greece
    Re: LA-A091P power issue
    As you have them removed connect some wire at the power rail and at the ground and connect a AA battery [1,5V properly +/-] so the short will heat up quickly in order to find it.
    Don't connect anything that exceeds the 3V of the power rail.
    • GLISIT
      by GLISIT
      01-16-2025, 02:29 PM
    • justice171
      Acer Spin 1 SP111-33 Power-On Issue (Troubleshooting Assistance)
      by justice171
      I am seeking guidance on an Acer Spin 1 SP111-33 that does not turn on when pressing the power button.
      Below are the observations and troubleshooting steps I have taken so far: Observations and Tests:
      1. Verified that all critical voltages are present:
        • 3.3V and 5V are always present if DC is plugged.
        • 1.8V on the BIOS chip is present.
      2. Checked the power button functionality:
        • When pressed, the voltage drops to 0V, indicating the button is functional.
      3. Inspected the flex cable connecting the USB, audio, and power button to JUB1:
        • Confirmed connectivity is intact, ruling out issues
      11-26-2024, 12:39 AM
    • claws77
      lenovo flex 5 14itl05 power sequence issue
      by claws77
      hi guys, my motherboard will not start no matter what
      when connected to ac power, the battery does get charge, led indicator glows red when discharged and turns white as it is fully charged.
      but rest nothing happens no sign of life.
      this laptop has one preexisting usbc power issue - so i use DCIN jack for charging my laptop.
      with this issue my laptop was unable to power ON only sometimes i just had to wait some time.
      but now nothing happens no matter how much i wait/ charge/ press and hold power button.
      i have no knowledge of motherboards ....
      10-20-2024, 02:48 PM
    • yaya3gmax
      Laptop Power Issue – Works on Battery, Fails on Adapter Load
      by yaya3gmax
      Dell laptop (E7440, uses the notorious CD3301B power controller + MEC5075 EC + BQ24715 charger IC)
      Symptoms:
      • Laptop works normally on a pre-charged battery.
      • Battery does not charge when adapter is connected.
      • Without battery:
        • Laptop powers on from DC adapter, passes CPU/RAM init checks, then cuts DC power abruptly.(seems to shutdown one of the mosfets in the charger path). Then the loop continues indefinitely
        • Speakers “pop” when power cut occurs indicating harsh sutdown.
        • If RAM is removed, the system shows RAM missing blink error code indefinitely without cutting DC power
      08-21-2025, 07:16 AM
    • SuperJames
      Dell G3 17 3779 Weird power cycling and shutdown/restart issue
      by SuperJames
      This one's a weird one, and still unsolved despite it having gone back to Dell once.
      Specs
      i7-8750H, GTX 1060 Max Q, 500GB SSD & Seagate 7mm 1TB HDD. 17.3 IPS screen. This has the fingerprint reader in the power button.
      Backstory
      I bought this from eBay, from a wallpapering shop. £650 in 2020 which was a good price considering it's a gaming laptop. Physically it's in perfect shape, apart from the hinge mounts on the palmrest failing in the time I've had it (I have a new palmrest for it). The usual thin plastic crap modern build quality!...
      10-23-2023, 04:09 PM
