i mac A1312 start up loading then auto shutdown
  • AltraqComputer
    • Sep 2015
    • 10
    • philippines
    good day, to all,
    i have here here now a iMac A1312 with auto shutdown issue while loading to startup, i check the led code led #1 ,#2 , #3 , #4 all is working good when pressing power button. then display appear and sound and loading status appear into 30 to 40 % then shutdown power. can anyone share ideas before i proceed isolating the issue. thank a lot everyone have a good day.
  • FShahid
    • Nov 2012
    • 57
    Re: i mac A1312 start up loading then auto shutdown
    It is trying to resume from hibernate file but that seems corrupted or something, so it switches off. ie. software related issue.
    • lorins_core
      BlackSmith
      • Dec 2012
      • 552
      • Philippines
      Originally posted by AltraqComputer
      good day, to all,
      can you Try To Change the new tested Charger Adaptor. may be have thermal issue. try to clean the fan and installed new thermal compounds...
      • tamzgha
        • Jan 2016
        • spain
        iMac A1312 try to copy your data then reformat if still have the problem see CPU thermal compounds if still your pwer supply is the problem
        • kacangpolo
          Asus X415EA Auto start when shutdown ( Laptop cannot shutdown with baterai only )
          by kacangpolo
          I have problem with my laptop, with code board X415EA 2.0,
          laptop cannot shutdown with baterai only, if i plug the adaptor, laptop can shutdown, but when the adaptor was unplug, laptop wake up
          I did :
          1. Flash Bios
          2. RTC_RST 3.3V
          3. LID_SW 3.3V
          4. WLAN_WAKE# 3.3V
          08-26-2025, 04:42 AM
        • IamPritesh
          Help - Auto starts after 1 minute of shutdown - Dell vegas/turis 15341-1
          by IamPritesh
          I have two such machines which is having this issue. After shutdown the system starts on its own in a minute. It does not start immediately. It takes around 20-40 seconds before it starts again on its own. This is driving me crazy and not sure where to start ..
          Some very important points :
          • Laptop does not auto starts after shutdown if adapter is connected.
          • It will only auto start after shutdown if the laptop is in BATTERY only mode.
          • I have tried replacing batteries with a known
          • if I shutdown the laptop with adapter connected and lets say remove the adapter after 5-10
          09-24-2021, 05:01 AM
        • прямо
          FSP Blue Storm Pro - Auto Protect Shutdown
          by прямо
          I received the PSU today. A quick check revealed a shorted 12V output rail, which is caused by a half dead dual Schottky rectifier. I replaced it, and was able to turn on the PSU but very briefly for a few seconds before the protection kicks in and shut it off.
          I'm not sure what is wrong.
          All output rails seem ok, with 3.3V maybe a bit higher at 3.6V
          Interesting to note, my light bulb is shining brightly while the PSU is running, like there is a short, instead of blinking rapidly as usual when there is an active PFC circuit involved.
          PSON...
          02-17-2024, 06:19 AM
        • janos666
          Pioneer LX5090 - 2x Red blink after auto-shutdown
          by janos666
          I was trying to reset the Pulse Meter and re-adjust the Panel-1/2 settings in the SM on an exceptionally old Pioneer LX5090 (51k power-on hours according to it's SM). I did this many times on much less aged specimens (with 10-20k hours) without issues. After following the usual workflow, I noticed the darkest gray shade showed up black with bright sparkles. I tried to adjust some other parameters but it didn't disappear. Then I went on and restored the old values of the parameters I don't usually touch (although I did this from memory, so I might have made an error). After that, I started going...
          03-26-2023, 11:20 AM
        • bembeno
          hp 15 G3 auto turnon after shutdown
          by bembeno
          the laptop works good but it turnon automaticaly after shutdown i replaced the windows and tried to replace the cmos battery i also updated the Bios but still the same
          03-22-2023, 10:29 AM
