HP G6-1150EW(Intel) motherboard problem.
  • tsiga
    • Jan 2014
    • 76
    • ott
    HI!
    I have HP G6-1150EW (DA0R13MB6E1 Rev.E).
    When i switched on its immediately shut down(1sec). Power led is blink once, the fan spin up then stop.
    I flashed main bios and ec bios but unchanged.
    I changed memory and processor not work.
    Does anyone have ideas?
  • goodguy91
    • Aug 2015
    • 80
    • Finland
    Re: HP G6-1150EW(Intel) motherboard problem.
    i had g7-1118so... shuttdown after few sec.. reflowed northbridge and gpu 220c and it start working. It makes no sence to me though why would it fix it.
    Was ec bios on another chip in this board? bios file size on chip was smaller than bin from hp site or dumps i found. but problem wasnt that for me anyway just want to know.
    • lucaszmn
      by lucaszmn
      Problem:
      Initial Findings:
      • I concluded that the
      08-12-2025, 03:01 PM
    • AquaMan Ua
      by AquaMan Ua
      05-17-2025, 09:40 AM
    • to5it0
      Need Clean BIOS/EC Bin File for Lenovo ThinkPad Yoga 11e 2H1703-27220F Rev. A Marked as U2501 on the motherboard.
      by to5it0
      Need Clean BIOS/EC Bin File for Lenovo ThinkPad Yoga 11e - Stuck with 0275 Error CMS
      I am attempting a repair on a Lenovo ThinkPad Yoga 11e that is currently stuck at boot with the error: "0275 error CMS" even after setup new bios battery and will not allow me to enter the BIOS/Setup.
      This is a critical issue that I believe requires flashing the BIOS chip directly using a programmer (e.g., CH341A/RT809H), as standard software updates or resets are not possible.
      I have opened the laptop and identified the main BIOS chip...
      10-24-2025, 01:35 AM
    • traxformania
      TONGFANG "GM7TG7P" Bios Password Problem?
      by traxformania
      I tried :
      -I removed the BIOS battery and main battery. Waited for a long time but it didn't work. They already stated in the user manual that the password will not be reset even if the batteries...
      11-15-2023, 07:32 AM
    • cihanpc
      OEM H55 i7 620Lm MOTHERBOARD BIOS PROBLEM
      by cihanpc
      OEM h55 i7 620lm motherboard does not display image. I don't know if it is a bios problem. Is the bios normal?...
      07-03-2024, 08:03 AM
