NAND512W3A2S SLC NAND Flash
  • megaraider
    • Jul 2015
    • 307
    • Portugal
    Does anyone know a homemade or cheap programmer for SLC NAND flash, multiplexed mode, TSOP48 package?
    The one in particular: Intel/Numonix NAND512W3A2SN6 (2076h) [K9F1208U0A / K9F1208D0A (EC76h), equivalent] crossed my way.
    The TSOP48 to DIL48 adapter is already on the way,
    but can't find any cheap programmer supporting it (need to be able to read and write it).
    I must be missing something important because I do know this NAND flash was used in very early USB stick pen drives and,
    even more relevant, in game boxes (wii, xbox and playstation).
    Any thoughts?
    • 30911
    Re: NAND512W3A2S SLC NAND Flash
    if it was used in consoles then why not look at console flashers.
    • megaraider
      • Jul 2015
      • 307
      • Portugal
      That's what i did...!
      Seems to be one of those cases that you stumble upon when you don't need it, and can't find it when needed
      • Deeloc
        How to flash SSD 1tb WALRAM controller SM2259XT2G flash samsung NAND V6
        by Deeloc
        I have a 1tb WALRAM SSD (Photo)
        Controller SM2259XT2G (photo)
        Samsung memory (photo):
        Part Number K9DVGB8J1B DCK0
        Name V-NAND V6
        Type TLC
        The SSD itself is detected as 1gb, but is not initialized.
        There is a Sata to USB adapter
        A lot of SMI MPTool, did not flash it. compare flash fail (17)
        K9DVGB8J1B is not listed anywhere
        What to flash?​...
        06-05-2024, 08:32 AM
      • DoOm86
        Swap nand flash smartphone for data recovery
        by DoOm86
        Hello everyone.
        I would like to know more about the following topic:
        Nand flash on smartphone for data recovery.
        I have been reading of people swapping nand flash from a faulty mainboard to another in order to save the data.
        But I also read about encrypted data which to be read must been swap also cpu, or nfc or something else where is located the key to make the data being readable.
        How does it works? How do I know if data are encrypted or where is the key?
        I know there are also very expensive external socket where you can put the nand flash in...
        08-20-2023, 07:10 AM
      • what_1282105
        Thinkpad t480s, completely dead after BIOS flash using CH341A programmer
        by what_1282105
        Following this guide (https://www.reddit.com/r/thinkpad/co...g_and_flashing) i re-flashed my t480s BIOS using an external (CH341A) programmer. The flash didnt work, so i reverted back to my BIOS backup successfully. The BIOS in the chip and the BIOS backup file are identical according to windows' file compare. The revert, however, didnt work: the only thing the computer does is flash the power button 3 times when AC power is connected. I've tried unplugging the CMOS battery, holding the reset button and holding down the power button- no signs of life....
        02-14-2025, 07:27 PM
      • corrize
        Nikon D800 camera - flash don’t work and capacitor don’t charge
        by corrize
        Hello, I'm stuck in troubleshooting…
        The flash system works like that : when the (mechanic) flash button is pressed, the flash mecanically pop up, and a circuit buck boost elevate 7v (batt) to 200-300v (?) for charging the big capacitor. And when the photo shoot button is pressed, the capacitor is discharged in the xeon light.
        In the D800, there is a first « power board » close to the battery. 2 wires (batt 7v) goes to another little « flash board ». I measured 7v, so ok.
        When I press the flash button, it's detected by the system, flash icon appear on LDC display....
        10-01-2022, 10:02 AM
      • mijatovic86
        JVC LT-32VF52K - Boot Loop - Nand Flash Steps
        by mijatovic86
        I have an issue with JVC LT-32VF52K, that is chassis Vestel 17MB110.
        It just flashes Logo JVC and then red led flashes for 12-13 times.
        Tried with flashing SPI MX25L1606 but acts identically with it also.
        How can I try and flash the NAND using only USB ?
        Can it be done with USB flash drive and usb_auto_update_A1.txt file, and what should be the content of that file ?
        I did find a nand dump on elektroda.pl, just need to be sure how to flash it ? Its LED JVC LT-32VF52K_NAND.BIN around 540MB large
        11-11-2021, 04:20 PM
