19V problem, Please i need help from expart.
  • nazrul145
    • Jan 2014
    • 337
    • BD
    Dear friend, i have problem with this motherboard. It has no power from adapter.
    I have check PQ25 pin4 has 18.8V, But no Pin3 +pwrsrc =4.6v, and pin1=5V.
    I have check pr173. Its input=28v but output=5v.
    I think PQ25 pin1 voltage needs high for output 19v.
    Please i want hep from expert.
    Pleease help me, Thanks advance.
  • nazrul145
    • Jan 2014
    • 337
    • BD
    Re: 19V problem, Please i need help from expart.
    Schematic here.
    • dycc
      Vision
      • Nov 2011
      • 625
      • Côte d'Ivoire
      PQ3 mosfet p channel is the problem . remove it and you must get 19v on pin 3 pq25(without pq3). if all is OK replace PQ3 with a good working p channel mosfet
      • khaahk
        • Dec 2013
        • 781
        • Estonia
        Check these values also:
        PU3 pin 1 VIN
        PU3 pin 9 ACAV
        PQ27 pin2 ACOK#
        • nazrul145
          • Jan 2014
          • 337
          • BD
          Thanks lot everyone speacially dycc. Problem was PQ3 and replaced now ok.
          • theone111
            by theone111
            3. Problem: TV shuts down
            07-22-2024, 10:36 AM
          • Zeonalbasta
            Thinkpad X1 Carbon "LMQ-1MB 12298-2 48.4LY26.021" VCC3M problem
            by Zeonalbasta
            i have a problem with thinkpad X1 carbon gen 2 "LMQ-1MB 12298-2 48.4LY26.021"
            The laptop was turned off because the MOSFET was not transmitting voltage. After checking it turned out that the gate pin on the MOSFET was the problem, because it was producing an inappropriate voltage. and it was discovered that the problem was with the Think engine, so I decided to reprint each pin, and finally the mosfet could work properly. However, there is another problem, even though the voltage has been supplied to the laptop, it still won't turn on, there isn't even an LED indicator. After double...
            09-13-2024, 01:17 PM
          • Gibon378
            Problem with stopping audio and video for no reason
            by Gibon378
            PC Specs:
            • CPU: Ryzen 5 1600
            • GPU: GTX 1080 Palit JetStream
            • MOBO: ASRock ab350 PRO4
            • RAM: Crucial Ballistix Sport 2x8GB 3000MHz (XMP 2.0)
            • PSU: XFX 650W (don't remember what model)
            • OS SSD: ADATA SP920
            • OS: Windows 10 21H2
            Problem description:
            Hi. I have a problem that has been going on for some time (2-3 years). It's hard to explain what it really is. Sometimes, my computer stops playing music, stops videos (starts buffering on youtube), there is no sound in games and when I minimize the game window and return to the game there is a black screen with window borders...
            11-19-2022, 09:41 AM
          • perzyk23
            Lenovo T580 - LCD Panel problem - error 0288
            by perzyk23
            Good morning,
            I have a problem with Lenovo T580, which after error code 0288 suggests a problem with the display. I checked the display and it works on another laptop. I replaced the display cable with a new one. I programmed another BIOS (downloaded from this forum) and I still have the problem of a dead display - there is an image via HDMI, and the system does not detect the built-in LCD at all. The problem appears to be hardware. What can I check to confirm or disprove this? I found many threads on the Internet related to this problem 0288, but without specific solutions. Please advise....
            10-25-2024, 12:42 AM
          • SDNarcia
            Dell 15R-5521 keyboard problem (KBC?)
            by SDNarcia
            Hello, I have a Dell 15R-5521, with the problem that the Ctrl, Alt, Shitf and Num Lock keys do not work, I tested the keyboard with a keyboard tester and it is functional, I also got another new keyboard and the computer has the same problem with the same keys. Check continuity between the ZIF connector from the keyboard to the KBC and all pins are correct. I cleaned the ZIF connector and the KBC and I still have the same problem. I reinstalled windows just in case, and it didn't work. I updated the BIOS to the latest version A16 and there were no changes.
            As additional information,...
            07-20-2024, 10:47 PM
