Compaq CQ58 no display/4 blink FIXED!
  • Th3_uN1Qu3
    Believe in
    • Jul 2010
    • 6031
    • Romania
    Had this in yesterday, no display, 4 blinks on caps lock. It was very dirty inside to the point that the fan did not spin at all, so i thought the APU soldering had gone bad. Reballed the AMD E1-1200 APU, no change. Flashed BIOS, no change.
    I had a donor board with a known working E450 APU. It is an older generation, yes, but it is the same core (actually it's even more powerful than the E1-1200; that one was the successor to the E350). Same format and everything. I did not know whether it would work but it was the only one i had.
    Soldered in the E450 APU and had the same issue. Post card stopped on code F9, same as before. But at least the APU seemed to be compatible as it went thru the same sequence as the original one. Knowing this one was good, i looked further. A big surprise came when i unplugged the LVDS entirely and plugged the VGA in - the screen lit up and showed "Boot device not found". That's what the F9 code was for... Caps lock no longer blinking at this point.
    Took apart the display and tested with another LCD. Got video. . Put the original LCD back on... and got video on this one too. Guess what happened... the LVDS cable was a bit loose at the screen end, and that's what caused the 4 blink issue.
    Board booted to Windows just fine with the E450 APU and installed all needed drivers by itself, graphics work no problem. I'll be damned.
    So, i have learned two things today. First, you can replace E1 series APUs with the older E series. Second, never rule out simple causes to a complex-looking problem.
    Th3_uN1Qu3 out.
    A working TV? How boring!
  • polytek
    • Dec 2013
    • 496
    • TUNISIA
    Re: Compaq CQ58 no display/4 blink FIXED!
    very nice work, you are always here with a good news, i have faced a similar problem, with hp g6-1120ek.
    thanks a lot for sharing your experience with us.
    • highpulse
      i hate HP
      • May 2013
      • 1488
      • portugal
      agree totally nice one bro
      • KEVSPIT
        • Sep 2015
        • 62
        • Malta
        Well done Th3_uN1Qu3
        I have the same model CQ58 with a very strange problem. It does not boot and the POST card stops on random codes, ranging from 11 to 1C.
        Flashing the BIOS did not fix the issue. I am suspecting the EC.
        Any ideas? Will keep you informed.
        • dycc
          Vision
          • Nov 2011
          • 624
          • Côte d'Ivoire
          sometimes when you are cluttered of large machine like bga station , for a simple problem you can go very far
          nice work
          • polytek
            • Dec 2013
            • 496
            • TUNISIA
            same problem, with same laptop, found Q1311 defective, and ncp6132b
            • KEVSPIT
              • Sep 2015
              • 62
              • Malta
              What is the your motherboard part number?
              Mine is:
              010172W00-600-G
              NEWTON_BR_HPC
              MV_MB_V1
              • polytek
                • Dec 2013
                • 496
                • TUNISIA
                motherboad is: NEWTON_CR&HR_HPC MV_MB_V1
                • ala_borbe
                  aka Donald
                  • 1625
                  • Malta
                  congratz bro, and tnx for sharing
                  Im Back... sort of...
                  • Th3_uN1Qu3
                    Believe in
                    • Jul 2010
                    • 6031
                    • Romania
                    Thanks. Attached pictures. Tomorrow when i get back to work i will share working BIOS dump too if anyone needs it.
                    • KEVSPIT
                      • Sep 2015
                      • 62
                      • Malta
                      polytek, then they are not the same. I don't have those components on my board.
                      Th3_uN1Qu3, My motherboard is similar but not exact. You part number is 010172W00-J09-G while mine is 010172W00-600-G
                      I will post my BIOS when I fix the board and make sure it's the correct one. I just don't want to post a bad bin file
                      • sparker1
                        • Sep 2011
                        • 343
                        Love your work.
                        • FShahid
                          • Nov 2012
                          • 57
                          • United Kingdom
                          Thanks for sharing your experience and the solution. Great work!
                          • Levi
                            • May 2014
                            • 59
                            • Ghana
                            nice one there. indeed somtimes we overlook the simple solutions wen in the end they are the solution to our problem
                            • samanthban
                              • Feb 2014
                              • 253
                              • Sri lanka
                              Thanks for sharing..
                              sigpic
                                HP Compaq Compaq SG3-240ES Compaq SG3 220 Specification for Upgrade or Repair
                                This specification for the HP Compaq Compaq SG3-240ES can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Compaq Compaq SG3-240ES boardview and Compaq Compaq SG3-240ES schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet,...
                                09-12-2024, 03:44 PM
                                HP Compaq Elite Compaq 8000 Elite Convertible Minitower PC (ENERGY STAR) Compaq Elite 8000 E5500 Specification for Upgrade or Repair
                                This specification for the HP Compaq Elite Compaq 8000 Elite Convertible Minitower PC (ENERGY STAR) can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Compaq Elite Compaq 8000 Elite Convertible Minitower PC (ENERGY STAR) boardview and Compaq Elite Compaq 8000 Elite Convertible Minitower PC (ENERGY STAR) schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request...
                                HP Compaq Pro Počítač Compaq 6005 Pro (ENERGY STAR) v provedení microtower Compaq Pro 6005 B59 Specification for Upgrade or Repair
                                This specification for the HP Compaq Pro Počítač Compaq 6005 Pro (ENERGY STAR) v provedení microtower can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Compaq Pro Počítač Compaq 6005 Pro (ENERGY STAR) v provedení microtower boardview and Compaq Pro Počítač Compaq 6005 Pro (ENERGY STAR) v provedení microtower schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information....
                                09-12-2024, 03:36 PM
                                HP Compaq Compaq dc7900 Compaq Q9400 Specification for Upgrade or Repair
                                This specification for the HP Compaq Compaq dc7900 can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Compaq Compaq dc7900 boardview and Compaq Compaq dc7900 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or...
                                09-12-2024, 03:30 PM
                                HP Compaq Compaq SG3-331IT Compaq SG3 245 Specification for Upgrade or Repair
                                This specification for the HP Compaq Compaq SG3-331IT can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Compaq Compaq SG3-331IT boardview and Compaq Compaq SG3-331IT schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet,...
