Need help laptop battery ic charger
  • ITSYSTEMSALBANIA
    • Mar 2015
    • 37
    • Albania
    Hi
    I have an emachines e725 the battery charging ic is damaged the part number is BQ24751A i have another ic that is similar to this ic part number is BQ24740.Can i replace BQ24751A with BQ24740.
  • ITSYSTEMSALBANIA
    • Mar 2015
    • 37
    • Albania
    Re: Need help laptop battery ic charger
    Anybody ?
    • ktmmotocross
      Boardkiller
      • Feb 2014
      • 3627
      • slovakia
      find datasheets and compare
      • dj_ricoh
        • 2073
        they are not the same
        the first thing that is not the same is IADSLP( battery discharge learnining) pin 8 and ACOP
        • polytek
          • Dec 2013
          • 496
          • TUNISIA
          740 is not compatible with 751a
          see datasheet,
          for more information about ic charger, see pdf.
          • juandres666
            • Feb 2021
            • Ecuador
            hello, how do you know BQ24751A is damaged? Thanks
              NVDC charger configuration...
              11-05-2024, 03:28 PM
              ISL6257HRZ ISL6257HRZ-T Laptop Battery Charger Datasheet
              Highly Integrated Narrow VDC Battery Charger for Notebook Computers
              The ISL6257HRZ ISL6257HRZ-T is a highly integrated battery charger controller
              for Li-Ion/Li-Ion polymer batteries. ISL6257 is designed for
              Narrow VDC applications where the system power source is
              either the battery pack or the regulated output of the charger.
              This makes the max voltage to the system equal to the max
              battery voltage instead of the max adapter voltage. Operating
              at lower system voltage can improve...
              11-05-2024, 04:43 PM
            • serious_electron
              Strange! Acer laptop not powering on but charging the battery (orange light on when charger and battery plugged in).
              by serious_electron
              Hello Everyone!
              I have an Acer Aspire A315-42 laptop. I generally leave it on for long time by closing down its lid (so it enters the sleep mode). Recently, it rained quite heavily in out area. And the humidity and moisture seem to be high. So one late evening, after I opened the lid and turned on the laptop, it did power on as the blue light turned on but after it booted to the desktop screen, just 5-10 seconds after both the screen and blue light went out and laptop shut down (the blue power light turned orange). And after 2-4 seconds that orange light went off and the laptop died.
              06-28-2025, 02:57 PM
              Texas Instruments bq24745 bq24745RHDR bq24745RHDT Battery Charger IC for Laptop Computers Datasheet
              The bq24745 bq24745RHDR bq24745RHDT is a high-efficiency, synchronous battery charger with an integrated input-current comparator, offering low component count for space-constrained, multi-chemistry battery-charging applications. The input-current, charge-current, and charge-voltage DACs allow very high regulation accuracies that can be easily programmed by the system power-management microcontroller using the SMBus interface. The bq24745 charges two, three, or four series Li+ cells, and is available in a 28-pin, 5-mm x 5 mm QFN package.
              The bq24745 features dynamic power management...
              10-23-2024, 02:50 AM
            • flat-earther
              how to prevent a connected charger from draining battery when not charging?
              by flat-earther
              I have an RC radio handset(Taranis QX7) which doesn't have internal battery charger which means I had to remove the battery every time I needed to charge it.
              So to improve it, I added a 15W USB-C charger board(link) inside and soldered it to the same connector on the PCB where the battery plugs into, great, now I can simply charge it with a USB-C cable.
              but the problem I found is that after the radio sat for two weeks without being used the 2S 18650 battery that I'm using was at 4.2V!
              So the battery is backfeeding the charger and being drained.
              How can I prevent...
              08-07-2025, 01:04 PM
