Lenovo T520 Battery Question !
  • cheebster
    • May 2008
    • 373
    Hello ! I have this lenovo t520 battery here, it's brand new (lenovo says 2 cycles in the battery utility). Bought it on ebay, got refunded since it didn't work, and seller told me to keep it.
    However, i wondered prior to recycling it, opened it up, and battery has 9.5v from black to red. However, output of the charging pcb is 0.5V.
    So there's just, something wrong on the pcb.. Here's a picture of it, i can't figure out by myself what's wrong. It's rather simple, a few ic's but i cannot find something obvious. Any help would be really great !!!
    Thanks, Vincent
  • ala_borbe
    aka Donald
    • 1625
    • Malta
    Re: Lenovo T520 Battery Question !
    battery have firmwares, similar to bios, which sometimes goes bad to...
    Im Back... sort of...
    • cheebster
      • May 2008
      • 373
      Ok ! I see 2 MT8103 which seems to be mosfets and some other chip, a SH79F329AX. Which IC would be the culprit ? Can't find anything about these being a bios or eeprom or anything close.. And there's nothing else on the board ?
      • ferah831208
        by ferah831208
        03-18-2025, 01:18 AM
      • Bowline
        by Bowline
        06-11-2025, 10:13 AM
      • Grafnus
        Lenovo ThinkPad P15 Gen2 Battery Mosfet Replacement
        by Grafnus
        Hey there,
        first time posting here. I have been lurking a bit trying to find a solution but with little to no avail.
        So I have a Lenovo ThinkPad P15 Gen2. When I got it (for free) it was turning on but not charging because the battery was unplugged. When I plug the battery in, the Laptop won't boot at all.
        Specs:
        • Type: Lenovo ThinkPad P15 Gen2 20YQ-001KGE
        • CPU, GPU, RAM work fine (not involved in the Problem)
        So the first thought was to toss the battery and get a new one, as clearly the BMS is throwing errors or something.
        Now I noticed...
        08-06-2025, 11:54 AM
      • code share
        Lenovo P43s won't boot with internal battery connected – looking for help diagnosing battery issue
        by code share
        I'm having an issue with my Lenovo ThinkPad P43s. The laptop does not power on when the internal battery is connected, but it works fine on AC power alone (battery disconnected). Once the battery is reconnected, the system becomes completely unresponsive — no lights, no fan spin, nothing.
        Here's what I've tried so far:
        • Power/EC reset (held power button for 60 seconds with battery and AC disconnected)
        • Booted successfully on AC power only with the battery disconnected
        • Visual inspection of the battery — no swelling, burn marks, or connector damage
        • Battery
        04-21-2025, 12:50 PM
      • mrkmpn
        Lenovo Yoga C930-13IKB EYG70 NM-B741 Battery not detected.
        by mrkmpn
        Hello, I have a customer that brought this laptop in after replacing his battery. He said his original battery charge was not lasting long, and after replacing the battery with one purchased from iFixit, the charging worked for about 30 minutes and then stopped, and the battery is no longer detected by windows.
        This laptop powers on when the AC adapter is connected, and my USB-C multimeter shows current being used with both ports, but the charging light does not come on, and in Windows the battery icon shows an X as if there is no battery present. If I disconnect the AC adapter,...
        03-13-2024, 01:54 PM
