Dell N5010 won't turn on - +1.05V_VTT output impedance suspect
  • ngth82
    • Jul 2015
    • 541
    Hi Guys -
    I'm looking at a Dell N5010 (Intel version). I did some research and this laptop appears to fail rather often.
    I found the schematics for the laptop and i'm checking the impedances on the output capacitors for each rail. Everything appears to be okay in impedance between the rail and ground (200+ kOhm) with the exception of +1.05V_VTT. This rail reads ~1.5 to 2.0 ohm on the large 330uF output caps (PTC4901 and PTC4902).
    I removed the output inductor (PL4901) to isolate if the issue is on the switching regulator side, or on the output side. With the inductor removed, the switching regulator side has an impedance around 1Mohm. The output side appears to be suspect. I continued by removing the PTC4901 and PTC4902. I was able to verify these two caps are not shorted. But the output plane still reads 1.5 to 2.0 ohm. For reference, my ohm meter registers 0.5ohm when there is a dead short between the two probes.
    What's the expected/nominal impedance on the +1.05V_VTT rail to gnd on a good board?
    Trying to figure out if i should continue checking the 0805 and smaller ceramic caps.
    Thanks!
    Thomas
    -Thomas
    I'm a hardware engineer focused on networking equipment for my day job. I void warranties and fix consumer electronics for fun.
  • ngth82
    • Jul 2015
    • 541
    Re: Dell N5010 won't turn on - +1.05V_VTT output impedance suspect
    Does anyone have a N5010 motherboard laying around that can help? Thank you.
    -Thomas
    • atsio
      • Oct 2013
      • 819
      • Greece
      Remove processor and check resistance again. If same resistance on +1.05V_VTT (probably you have the UMA version), replace the PCH.
      • ngth82
        • Jul 2015
        • 541
        Thanks. I already removed the processor a while ago. The resistance of the rail appears to be the same.
        I guess it's worth a shot at removing the PCH. I can reball if necessary.
        -Thomas
        • atsio
          • Oct 2013
          • 819
          • Greece
          Reball will not do anything when pch is shorted.
          • iqtoon
            • Mar 2021
            • iraq
            did u fix that problem ? i have the same issue
            • Dan254
              • Aug 2023
              • Kenya
              same issue here, please help
              • FrancescoV
                Onkyo HT-R390 no sound output, video output ok
                by FrancescoV
                Good morning everyone,
                I'm trying to repair an onkyo ht-r390 that has no sound output, despite the volume being at maximum, the rest seems to work; the video output signal (coming from an hdmi input) is present, but the audio is absent. Similar situation if I send an audio signal from any input I have no output.
                The firmware reported is the following:
                M:1.00/11107BLP
                D:?.??/????????
                O:1.00/11107AL
                The DSP firmware given the question marks seems corrupt.
                On the BCHDM-0678 - 25140678 - QPWBCHDM0678A0 board the chip that usually seems...
                05-11-2025, 02:59 AM
                NTE Electronics “NTE5251K” Zener Diode 9.1V @ 50W Do-5.5% Want to build a 9.1 output from a 9.6 lipo4 battery pack
                I have bought this Zener Diode for this project what size and wattage resistor value do I need to use to get near 50 watt output
                I bought this from an eBay seller but unfortunately they only had one
                I bought three from Vetco Electronics these are Sylvania ECG5185A 9.1@10w A to Stud what size and watt resistor do I need to use to get near 10 watt output
                I bought three of from them to also make battery packs with this output power limit in mind
                I want to use this battery pack and turn it into a 9.1 output battery pack output to eliminate using 9 volt battery...
                04-23-2025, 05:50 AM
                Corsair CX750M [Model 75-002019] - burned output toroid inductor
                by momaka
                Looks like I may need a little help from the PSU experts (or anyone really! ) I have a Corsair CX750M (Model 75-002019) that I picked up for free about 4 years ago. This is the PSU:
                So here’s what’s strange about this one: it appears to work normally (normal output voltages) and any PC is stable with it. However, after a while (typically 10-20 minutes, but time can vary depending on the load), there is a sweetish smell of burned magnet wire insulation emanating from the PSU. Upon opening the PSU after this happened (many times), I was able to confirm...
                09-19-2021, 08:44 PM
              • flibidy
                Magnum IA.100 Amplifier Switches on, No Output, Possible Input Side fault?
                by flibidy
                I have here a Magnum IA.100 which belongs to my parents.
                The unit powers on & when the relay kicks in, you get a pop from the speakers (this might sound weird but is usual behavior for this amp). However, you get nothing coming through it from any of the inputs & no pops and crackls from any of the controls.
                Because of the sound from the speaker when the amp turns on I have assumed that the output section probably works but I could be wrong & I'm not sure how to test that side of things further.
                What Ive done........
                01-01-2025, 01:26 PM
              • mecha1166
                Copper corrosion? Yamaha HS8S Audio 1 output only
                by mecha1166
                OAUD Yamaha HS8S Audio one output only.
                I have pulled the output board. Output txsistors are ok (only 2 main output). Everything measures the same on each side. Customer did not bring in speakers so I cannot go too deep. I did notice a greenish tint on the tip of the solder joints that connect to the COPPER output connectors. All 6 have a greenish tint at the tip - each side has 3 pins each. Anyone else have copper speaker output pins that corrode at the place on the PCB where they are soldered? I will try to add a photo. Thanks.
                08-04-2023, 02:55 PM
