Samsung NP3530EC
  • Dronny
    • Sep 2015
    • 8
    • England
    Samsung NP3530EC
    Hi, I hope someone can help with my problem. I have replaced a DC jack on a Samsung NP3530EC, something I have done a few times on this model alone. This time however the laptop wouldn't turn on or charge, its at this point I noted two very tiny components burned out close to the jack. When I touched them with tweezers they just fell off the board! I have quite a few faulty motherboards from various laptops hanging around that could be used to donor components, however I would really like to know what the components were and if replacement is possible.
    Picture attached.
    PS I am reasonable with a soldering iron.
    Thanks in advance
  • Dronny
    • Sep 2015
    • 8
    • England
    Re: Samsung NP3530EC
    Hi, could anyone please offer any advice to what components were that burnt out. I have attached a picture of the same model of board without damage if that may help with identification.
    • DSpawnZ
      • May 2009
      • 20
      • Argentina
      Hi. I will check later if I have the same board at hand. They look like capacitors.
      Regards
      • highpulse
        i hate HP
        • May 2013
        • 1488
        • portugal
        ths components are , coils , you can make a bypass between to sides , or simple put another coil .
        • highpulse
          i hate HP
          • May 2013
          • 1488
          • portugal
          but you must remove both you got here in this moments , since they are not good . remove from another board or simply make a bridge between to sides ... you will have outher circuit protection further along the 19volts rails , so dont worry to much if you dont find the coil itself to replace .
          • Dronny
            • Sep 2015
            • 8
            • England
            Thank you so very much for your advice. it is appreciated. Thanks to you all.
            • ktmmotocross
              Boardkiller
              • Feb 2014
              • 3582
              • slovakia
              it is capacitors. coils are big near. u dont need it.
              • highpulse
                i hate HP
                • May 2013
                • 1488
                • portugal
                ktm now , does 2 right side of the dc jack are coils , small coils
                they look like capacitors but they aren't
                • highpulse
                  i hate HP
                  • May 2013
                  • 1488
                  • portugal
                  my bad i didnt notice first picture , the broken ones , are capacitor , just remove then t usually does 2 coils right near does capacitor , usually also get damaged . so you must have 19 volts on both sides of does coils . if they dont have voltage (this are the ones i mention you can bridge ) the small ones you CAN?T bridge them or else you short 19 volts line to gnd |
                  • Dronny
                    • Sep 2015
                    • 8
                    • England
                    Thanks for all the help. This is what i did, i found a replacement for the small component on the left and soldered it on and the same for the other, however i then ended up with the positive and negative showing contnuity and nothing working, anyway quite by accident really with a little bit of a clumbsy hand with the soldering iron i knocked off the component to the right and despite there been nothing bridging the gap i now have a fully functional motherboard that charges and now boots normaly. ??? Any ideas why.
                    • bicalov
                      • Nov 2014
                      • 294
                      • Netherlands
                      Must have been a shorted capacitor. Often the system works ok without replacing them, because the are only there minimize interference etc.
                        09-07-2024, 05:50 AM
                      • cheeky2
                        Samsung BN44-00262A H37F1-9SS power supply help finding blown value components!
                        by cheeky2
                        This Samsung combined power supply and inverter was replaced a while ago from a Samsung 37inch LE37B530P7W TV. However I would like to repair this one.
                        I have replaced the Mosfets Q1820 and Q1821 ( FDPF7N50U) which were both blown and the fuse FM802S. The schematic for this power supply that is attached doesn't relate to this power supply as the driving transistors and diodes are D1830, D1831, D1832, D1833, Q1811 & Q1810 are nowhere on the schematic!
                        Does anyone know what the components for D1830, D1831, D1832, D1833, Q1811 & Q1810 should be? I ask as I did change the Mosfets...
                        06-15-2025, 05:12 AM
                        09-06-2024, 11:40 PM
                        09-06-2024, 08:40 PM
