Hp 9494nr laptop wont POST, power by itself without pressing power button
  • BG5
    • Sep 2015
    • US
    Hi guys,
    Here I have an HP HDX 9494nr Laptop made by Inventec that won't POST with all HDD/RAM out. I have found schematic attached.
    With battery out, I plug in AC adapter, the laptop turns on by itself(fans and lights) without ever pushing the power button.
    There is no picture on LCD display. Laptop turns off by itself after a few seconds. Sometimes it turns itself back on for a few seconds, then off again, in a loop.
    It does all this with never touching the power button, just plugging in AC adapter. I try to hold the power button to turn off the laptop, but no response, need to remove AC adapter to turn off.
    Does this behavior sound like short to ground problem? Power switch broken? Charging circuit?
    Has anyone had this experience before and can give advice?
    I Appreciate any help or ideas very much.
  • bicalov
    • Nov 2014
    • 294
    • Netherlands
    Re: Hp 9494nr laptop wont POST, power by itself without pressing power button
    Plug in AC adapter switch on is often a bios setting, not a problem, That is seperate from your other problems.
    • lorins_core
      BlackSmith
      • Dec 2012
      • 552
      • Philippines
      Originally posted by BG5
      Hi guys,
      try to clean or general cleaning. all need to dismantle . check the power the switch also.... may be short or check the mobo (Main Board) if they have corrosion.
      post the result
      try to
      • themosttogain
        HP Envy 13-BA1565na with intermittent power button
        by themosttogain
        Hope someone can give me some suggestions on this because i'm at my wits end with it...
        I have an Envy 13-BA1565na here with an Intel Core i7 i7-1165G7 CPU (board is a LA-J475P Rev 1.0) which has an intermittent power button issue. The power button is integrated into the keyboard, and I have ruled out the keyboard, BIOS and battery as being the issue.
        Basically, on mains power, the power button works fairly well. The first time you come to it after leving it sitting (either on charge or not on charge), it might take 2 or 3 presses of the button, but then the laptop boots...
        07-12-2024, 03:03 AM
      • Tynan Dill
        by Tynan Dill
        Assuming...
        11-22-2024, 01:46 PM
      • TimeRabbit07
        Asus FX517ZC charges but power button does nothing
        by TimeRabbit07
        Hi all!
        I've got an Asus FX517ZC on the bench at the moment and I just can't figure out what's going on with it.
        Here are its various numbers and identifiers:
        Model short: FX517Z
        Model long: FX517ZC-HN114W
        SN: NANRCX01S57842E
        CN: 3SDB 12M
        MFD: 2022-10
        Motherboard model: DA0NJLMBAE0 REV E
        Symptoms:
        The laptop's charge light comes on, but when the power on button is pressed nothing happens. No fan spin, no caps lock, no screen or keyboard backlight, nothing.
        History so far:
        The...
        09-04-2024, 05:48 PM
      • reessi
        Macbook Air - 2018 - A1932 - 820-01521-02 - Bootlooping if Power Button Connected
        by reessi
        With the power button connected it either boot loops with the apple logo or no display but the charging meter shows it looping on charging every few seconds.
        No corrosion any where!
        Tried a replacement power button off ebay and the same.
        Very occasionally it will work with the power button connected!
        Same results with or without the battery.
        Can it be a fault with the Audio board or the mainboard?
        The touch Id assembly connects through the Audio board first then to the Mainboard.
        Flex...
        06-26-2024, 03:31 PM
      • conghuyms
        Macbook air m1 can't access the recovery options by pressing and holding the power button
        by conghuyms
        I have an M1 MacBook Air (A2337) 2020 that came in for water damage and will not turn on. Upon opening it, I saw that the audio board was severely corroded. I disconnected it, and the device started working.
        After that, I dealt with the issues on the audio board by removing the capacitors that were shorted to ground, and the device started working. However, I encountered another problem: I can't access the recovery options by pressing and holding the power button. I'm not sure if it's a hardware issue or if the recovery partition has been lost. Currently, the system's time isn't updating,...
        10-14-2024, 06:43 AM
