Dell n5010 can be converted from graphic version to non graphic
Re: Dell n5010 can be converted from graphic version to non graphic
Graphics ram removal is optional though advised to remove to reduce power consumption but still as i said is not mandatory. So you need to look at vcc circuit/Bios corruption. Might me ME region issued with bios or even looking at dying PCH.Comment
Hi, can you explain, why you markered "D point" on (9) picture, without any notes what to do there?Comment
Hello! I did the convertion successfully and i have image but my problem is that i have a little distortion on the screen like small red and black dots like shadows! Do you know what it can be?Comment
Dear all
Kindly I request photos for both side of dell n5010 motherboard which I can see all elements and all writing thanks for your kind supports
I have dell N5010 laptop, i have got problem in ATI graphic card and I want to use intel instead of ATI
What is the best way to perform such task
Best regards
Dear all
Kindly I ask all of you
1- if some one have N5010 motherboard circuit after modified to non graphic, please share it
2-I saw in net some one converted from graphic version to non graphic but without jumper
if some one try such method please advice
best regards
Dear vektro
Thanks for your kind reply, Kindly explain to me (such method only work for display and not for HDMI or VGA output)
regardsComment
best regards
recently i converted an N5010 board using Dr. Bios way.
It works only for laptop's display, not HDMI's or VGA's outputs.
Now i am trying to resolve this too.
Check the attachment.Comment
Hello ,
I have a similar problem. A blank screen appears, but the windowa starts normally. Where can the problem be? Can the video card not work but the windows 10 will start normally?
When I press D + power button the display turns on and I have a red, blue, green, white screen ... diagnosis mode
attach a photo
The problem is visible in this video clip.
https://youtu.be/z6Dx2qPdML8
When I touch IC Voltaging CPU Core declined by 100mV and the display/picture changes. Do you have an idea where to look the problem. Can it be burned CPU? Thanks!Best regards!Attached FilesComment
can i have a complete step by step and procedure how to convert graphics to uma of dell n5010?thanks
where is the pdf sir where i can downloard it?thanksComment
Please give me attached files
Thanks broComment
worked for me thank you.Comment
I did the conversion but the laptop has black screen. The laptop Posts fine and detects whether the screen is connected or not by generating 5 beeps. The PCH generates PCH_LCDVDD_EN but it does not generate PCH_VGA_BLEN. The screen has neither data nor backlight. Does anyone know what is wrong?Last edited by caspian; 05-20-2020, 02:21 AM.Comment
Post clear photos of your mb-both sides.Comment
I did the conversion according to the photos of Post#110. I double checked all the new components and they were correct.
All voltage rails are present. Graphics-ralated voltage rails are provided to PCH. The Bios can detect presence/absence of RAM but it stops when it tries to start the Integrated Graphics. That is why the screen has neither data nor backlight. Then, the laptop does nothing but stays on while the fan speed is controlled properly.
Compared to the time of Discrete graphics, now that PCH has the GFX_Core voltage, it gets about 20 degrees hotter.
I have tested both the UMA and the Discrete versions of Bios and EC firmware in the following thread but no signal changed:
https://www.badcaps.net/forum/showthread.php?t=84754
Now I do not know whether the problem originates from wrong vBios or defective PCH. what is your guess?
Note: I wonder why none of the successful technicians in this thread mentioned any Bios reprogramming. Maybe, the original Discrete version of Bios contain both vbios of ATI and Intel graphics. Am I wrong?Last edited by caspian; 05-23-2020, 11:55 AM.Comment
by BowlineMy question pertains to understanding the control circuity inside a Dell PT434 type battery used in Dell E6400, E6410 and other Dell notebooks?
I have tried multiple different Dell power adapters. My Dell... -
by minaedwardHi all
I have a dell n5010 that shows black screen after the dell logo and freezes
But when I remove the keyboard it works fine and boot the windows
The keyboard is working as I can press F1 and F2 and inter the bios settings and change it
But after the dell logo it causes the laptop to freeze
Any ideas why ? -
by sahamipoorhello...
the Dell XPS L502x ( Model P11F ) [ DAGM6CMB8D0 rev.D ..3 of lines output LVDS from PCH has short ohm(0 -70) than LCD displat turn ON but is white !!!
i decide to change LVDS ports to Lcd from EXT_LCD graphic Studio Discrete to No need it LVDS lines of PCH use...
according to ΩSchematic ,I changed any resistor and... Config_0 and Config_1 EC...but:
1- EXT_LCD_PWM no voltage to enable pwm
2-EXT_LVDS_VDDEN no High to Enable LCD_vcc
and screen is turn off and fan is high Speed!!
Question:
I need to Use Discrete graphic nvidia EXT_LCD ports... -
by master3112I would like to share my experience about charging issues with Dell power supplies with the tech community. I am working on a Dell Inspiron 5590, Mainboard 18778-1 with charging problems. The device can be switched on and works so far, only the message appears at startup:
The power supply unit is not recognized in the Bios and the charging process is set to "idle". I use original Dell battery, type...-
by F R 2568Hello all,
this is my first post, so if I make mistakes please do not hesitate to point them out, thank you in advance.
I got a Dell Latitude 5420 (Service Tag: 7RFM6D3, Motherboard: GDF40 LA-491P Rev.: 2.0 (A01)) which does not start and I want to repair it. These are the symptoms:
If the laptop is only connected to the AC adapter (battery removed):
When I press the power button, the keyboard backlight and the display backlight are turning on. Caps key light is lightning, but key does not respond to pressing it.
The power/battery... - Loading...
