Back light Flickering
  • nbanti
    • 56
    Hi dear all,
    I have samsung laptop. With power adapter, When i increase or decrease the Brightness it is working normally. But if i do it with battery power, Screen get flickering and some noise come from LCD. If i plug the adapter that time, Flickering and Noise stop and LCD Works fine. I have change the LCD. But problem is same.
    Please tell me what to do.
    Thanks all.
  • polytek
    • Dec 2013
    • 496
    • TUNISIA
    Re: Back light Flickering
    it's better to post the laptop model or the motherboard code, my advice is try to update the bios to the last version,try another battery, try another lcd cable
    • nbanti
      • 56
      Thank you for the reply.
      Laptop Model is 300E. And it is a Core i3 Laptop.
      Thank you.
        Lift Master Garage Door wall switch display / motion sensor controller display disappeared no back light
        This happened last Saturday and today I finally had time this morning before I went to work to replace two non brand capacitors
        I will let you be the judge weather or not these are bad or not according to the blue ESR meter that I am using
        I am comparing them to a brand new one that I installed
        The display came back on and the programming was not lost which I was surprised by I would have thought that when the display went blank that so did the memory as well
        I going to let it run for several days before I remount back on the wall next to the...
        09-05-2024, 06:48 PM
      • PNI E.
        tcl u65x9006 back light on but no picture sounf ok after 40 50 secs
        by PNI E.
        hi guys, i need your help again...i have tcl u65x9006. while i was watching it become darker like when a movie ends, little by little the image disappear. now if i turn on i have back light on, after like 1 min i have also sound but no picuture. the back light is on i take off one at time the ldvs but nothing change always no picture. i tried to cover with a piece of paper the pin of ldvs i cover like 7 8 pins but nothing worked. the tv stay with no picture. there is a tcon board.i checked the voltage there on the fuse i have 11,8 volts. there is caps in shorts on the exit of the tcon i have...
        02-20-2025, 08:36 AM
      • koby058
        vostro comes up with back light but no picture
        by koby058
        Hi people!!
        The owner said it showed bad picture once in a while (attached)
        I see that there is back light but no picture.
        I want to ask if it is possible to disable the NVIDIA GPU and use the intel one?
        Also attached schematic and BDV
        LINK to schematic & boardview - https://www.badcaps.net/forum/troubl...ll-vostro-5590...
        07-13-2025, 01:03 PM
      • howardc64
        by howardc64
        Problem
        08-04-2024, 10:36 PM
      • jdawg99
        LG 47LA620V Same LED Failing Back Light Issues
        by jdawg99
        Hi All,
        I need some help with this one please. I am attempting a repair on the backlight. TV turns on and flashes the LG logo so stripped it down and found one faulty LED. Replaced it and tested on an LED tester and the strip was good. Put it back onto the PSU and it lasted about 20 seconds before going out again. Same LED had blown. Changed it for another type of SMD one (same voltage) and it seemed fine. Put the TV back together but it was quite dim. Noticed it was in power save mode so turned it off and the screen was bright. Left it on for half an hour only to come back to the...
        04-23-2023, 01:04 PM
