Asus x550d.no power
  • lorins_core
    BlackSmith
    • Dec 2012
    • 552
    • Philippines
    Asus x550d.no power
    Have A Nice Day to All
    Can you help me to find the schematic diagram of this
    Asus X550D. have repair.
    I Promise if i Fix it. i Share this Tip and Tricks of this Laptop..
    TIA
  • lorins_core
    BlackSmith
    • Dec 2012
    • 552
    • Philippines
    Re: Asus x550d.no power
    anyone have this schematic diagram...
    Again... help me
    • sahamipoor
      • Nov 2016
      • 42
      • india
      only board view. for x750dp rev 2.0
      MOD Edit. Link to boardview - https://www.badcaps.net/forum/showth...ghlight=x750dp
      Reminder: rules and organization of this section - https://www.badcaps.net/forum/showthread.php?t=117483
      • GLISIT
        by GLISIT
        01-16-2025, 02:29 PM
      • ShadowAi
        ASUS TUF X570-PLUS doesn't power on: no VRM_EN signal.
        by ShadowAi
        Hello, I have an issue with the motherboard. Specifically, it doesn't power on, more precisely, the POST initialization doesn't occur.
        Let me start from the beginning, the motherboard suddenly stopped working one day. There are no beep signals from the speaker, and the debug LEDs are not lighting up. After inspecting it under a microscope and using thermal imaging, I didn't find anything that could be damaged.
        After that, I began voltage measurements, in which I noticed the absence of VDDQ, VDDP, VTT, and VPP lines. Later, I checked if there is an EN state on these lines,...
        03-15-2024, 10:46 AM
      • conghuyms
        Request for Help – ASUS G531GW Rev 1.6 – No Power On
        by conghuyms
        I need your support with an ASUS G531GW Rev 1.6 laptop.
        When I plug in the charger, the battery charging LED turns on, but the board does not power on when pressing the power button.
        Here’s what I’ve checked so far:
        • Motherboard has been removed for inspection.
        • 3V and 5V always-on rails are present (3V/5V_ALW).
        • 1.8V and 1.09V at the PCH are present.
        • I don’t have the boardview/schematic, so troubleshooting is limited.
        • I tried checking the power button signal from the
        07-20-2025, 09:14 PM
      • Duranitron
        Asus x512dk rev 2.1 power on problem
        by Duranitron
        When I reflash again the bios of hoaca388 the unit powers on and the unit lives!!! Hooray!! All voltage in the coil 3.3v, 5v and 6.7v indicate charging are all present. including the cpu voltage , EEPROM and GPU voltage the unit is now alive, normal screen booting to windows and log in screen until I power it off. Then the unit never goes on even when pressing the power button in the keyboard.. Voltage reading 19v main , 3.3v VCC in IT8225E-128 and EEPROM VCC 0 volt and the charging voltage 0 volt.
        Try to trace the power switch button goin to the power switch IC PU8803 (APL3533AQBI-TRG)...
        11-26-2024, 10:22 PM
