HP Inspiron 17- e193nr dead but it has power througout the board
  • Blacktek
    • Nov 2014
    • 250
    I got power everywhere? memory battery pins, power switch, Battery controller, but when i plug it in...theres NO orange/white led light.!?
  • Joseph cauchi
    jccomputers
    • Jan 2015
    • 89
    • Malta
    Re: HP Inspiron 17- e193nr dead but it has power througout the board
    Are you sure it is an HP inspiron?
    Inspiron is a Dell Laptop
    • Blacktek
      • Nov 2014
      • 250
      Re: HP pavilion 17- e193nr dead but it has power througout the board
      your right its an HP Pavilion
      • PlusCom
        • May 2013
        • 50
        • Greece
        Have you tried to flash bios?
        • Tynan Dill
          by Tynan Dill
          Assuming...
          11-22-2024, 01:46 PM
        • k370
          Yoga3 Pro-1370 Board NM-A321 DEAD no power at all
          by k370
          I have a NM-A321 board that is dead, with no power at all.
          When I received the laptop, the +5VPMIC line was shorted. Removing the PU3 (ISL95905) solved the short, so I ordered and replaced the ISL.
          With the new ISL, the short is gone, but still no voltages at all. I measured the following rails:
          • +3VALW
          • +5VAUX
          • 1.2VSUS_PWRGD
          • 3VALW_PGD
          • 1.05VAUX_PWRGD
          Additionally, the ISL95906 (PU3) is not getting any voltage on the VIN rail.
          The only place on the board where I find any voltage is on the first MOSFETs, specifically:...
          09-23-2024, 11:57 AM
        • Destroyer-Br
          [HELP] Acer AN515-55 (LA-J871P Rev: 1B) – Board won't power on after GPU investigation – Suspecting Super I/O or PCH
          by Destroyer-Br
          I'm working on an Acer Nitro 5 unit with the following specs:
          • Motherboard: LA-J871P Rev: 1B
          • Model: Acer AN515-55-59MT
          • S/N: NHQ7JAL00403906A973400
          • SNID: 03902728734
          Initial Issue
          The laptop initially presented graphic issues and driver failure (Code 43) for the GPU.
          After preventive maintenance (cleaning, thermal paste, etc.), it powered on normally. We disassembled it again to inspect the GPU, reassembled...
          04-17-2025, 08:18 PM
        • Dani_2024
          by Dani_2024
          10-28-2024, 05:06 PM
        • corrize
          Nikon D5 – dead, power board issue ?
          by corrize
          Hello, the DSLR has heavyly fallen. It is dead : no sign of life and display nothing.
          When it worked, it always displayed a card present state on LCD display, even when the battery is empty it display a empty battery symbol.
          I found a dead fuse, I replaced it and a mosfet burnt, I changed it and another fuse burned. Nothing burned after. And I can't find any short circuit anywhere, it's weird.
          Now, I try to understand how it works.
          There is two boards (the little one on pictures has no component) : the first is a « power board » : managing...
          04-03-2023, 09:13 AM
