DELL XPS 1330 BURN-OUT Si4435BDY P-CHANNEL MOSFET
  • rldator
    • May 2015
    • 8
    • philippines
    I replaced the mark Resistor "R321, 240k ohms". Capacitor "C509" and I replaced the "U40" mosfet 3 times and when I plug the power adapter to the laptop it burn Si4435BDY Mosfet before i press the power button. Is it normal to have 19 volts present at the Drain Side of "U40"? +DCIN_SS. Kindly help me solve this problem? What is the causes of this problem?
  • ktmmotocross
    Boardkiller
    • Feb 2014
    • 3627
    • slovakia
    Re: DELL XPS 1330 BURN-OUT Si4435BDY P-CHANNEL MOSFET
    ofcourse u need to have 19V on +DCIN_SS, it is main power. if u have burned u40 , u must have some short after it. check resistance to ground
    • rldator
      • May 2015
      • 8
      • philippines
      Where would i start checking at the source side of u40?
      • rldator
        • May 2015
        • 8
        • philippines
        Mosfet U40 was removed when check the voltage at Mosfet. I check the Source side of the U40 Mosfet there is also 19 volts at the source side and 19 volts at the Drain Side. At the gate side there is 3.3 volts.
        • Agent24
          I see dead caps
          • Oct 2007
          • 5066
          • New Zealand
          Upload the whole schematic, can't do much with just one page...
          -David VanHorn
          • ktmmotocross
            Boardkiller
            • Feb 2014
            • 3627
            • slovakia
            u need to have 19V on pwrsrc.
            • rldator
              • May 2015
              • 8
              • philippines
              uploading full schematic diagram
