Acer 5742G dead after stress test
  • JohnSwe
    • Jul 2015
    • 10
    • Sweden
    Looking for advice..
    Acer Aspire 5742G started to power-off due to overheating.
    Now it wont start at all, external power or batt.
    It shows no lights when connecting power (no sign of battery charging).
    I guess something has fried around the power-circuit...
    The last thing I was doing was a small stress-test...
    (The external power is working with another Acer)
    Mb is "NEW 71 LA-5893P"
    Someone that can lead me on the way trying to find whats got fried?
  • dellxps15
    • Feb 2014
    • 1591
    • italy
    Re: Acer 5742G dead after stress test
    try flash back ec bios.
    • JohnSwe
      • Jul 2015
      • 10
      • Sweden
      How? It's stone dead...
      • Th3_uN1Qu3
        Believe in
        • Jul 2010
        • 6031
        You need to take the laptop apart and use a BIOS programmer to flash it.
        A working TV? How boring!
        • RJARRRPCGP
          • Jul 2004
          • 6304
          Sounds like a faulty VRM or CPU.
          ASRock B550 PG Velocita
          Ryzen 9 "Vermeer" 5900X
          Arc A770 16 GB
          eVGA Supernova G3 750W
          Alienware AW3423DWF OLED
          • Th3_uN1Qu3
            Believe in
            • Jul 2010
            • 6031
            Don't think so. A short on the CPU VRM would still have the board light up the battery charging LED.
            • sopik78
              • Nov 2013
              • 517
              • Czech Republic
              Agree with Unique, do flash bios and ec first, than we'll see. I had three these laptops with the same problem and flashing helped.
              • JohnSwe
                • Jul 2015
                • 10
                • Sweden
                Ok sounds doable...
                So I remove the bios and reprogram it using an external writer?
                Any tip on a good eeprom(?) writer?
                And where to find downloadable bios'es?
                • JohnSwe
                  • Jul 2015
                  • 10
                  • Sweden
                  So a faulty BIOS can make the charge-light not come on? Is not the charge circuit a more hw issue..?
                  • age80
                    • Jun 2013
                    • 55
                    • Greece
                    Here's the schematic in case it's not a BIOS problem
                    • sopik78
                      • Nov 2013
                      • 517
                      • Czech Republic
                      Try this dump, it worked well
                      I use EZP2010 external programmer, cheap chinese one and I am fully satisfied
                      • JohnSwe
                        • Jul 2015
                        • 10
                        • Sweden
                        Thanks!
                        Will any on these do for the programming:
                        http://www.ebay.com/itm/251369833299
                        http://www.aliexpress.com/item/FAST-...713696363.html
                        (Gonna take some weeks to get them to Sweden..)
                        So I flash both BIOS and EC, right?
                        BIOS = SPI ROM = U18 ?
                        EC = U31 ?
                        (Im gonna need a smaller soldering iron for this job.... Desoldering is PITA?)
                        Please correct me:
                        Content of bios_new71.rar is:
                        KBCA121A.rom = EC
                        NEW70121.fd = BIOS
                        Are there different BIOS dumps for different graphic cards on the mb?
                        • sparker1
                          • Sep 2011
                          • 343
                          A heat station is sometimes easier than a soldering iron. Mask off the area with heat resistant tape and de-solder with the heat station Re-solder the same way.
                          • sopik78
                            • Nov 2013
                            • 517
                            • Czech Republic
                            Originally posted by JohnSwe
                            Thanks!
                            Please correct me:
                            KBCA121A.rom = EC
                            NEW70121.fd = BIOS
                            Correct.
                            I used these dumps for nvidia model, but should work on ati as well
                            • Agent24
                              I see dead caps
                              • Oct 2007
                              • 4978
                              • New Zealand
                              With something like this, hot air is pretty much the only way.
                              -David VanHorn
                              • JohnSwe
                                • Jul 2015
                                • 10
                                • Sweden
                                Thanks again.. I also have the Nvidia so that should work then.
                                Is that CH341A programmer above ok?
                                Can someone confirm that I've got the right chips on the mb, U18 and U31 ?
                                • Agent24
                                  I see dead caps
                                  • Oct 2007
                                  • 4978
                                  • New Zealand
                                  That CH341A programmer lists MX25L3205 and MX25L1005 as supported, which according to the schematic, your board uses.
                                  You may wish to verify the chip part numbers on your own board too though, but if they are correct, it should work, assuming the software for such a cheap programmer is not full of bugs!
                                  How are you going to connect the ROMs to the programmer though? Unless there is an ICSP header, you probably need a 150 and 200 mil SOP8-DIP adaptor sockets for the programmer. Also some way to remove the chips without destroying the board. It can be done with a soldering iron if you are skilled and careful, but hot air is a much better idea.
                                  -David VanHorn
                                  • JohnSwe
                                    • Jul 2015
                                    • 10
                                    • Sweden
                                    Maybe something like this:
                                    http://www.aliexpress.com/item/Quali...219537667.html
                                    • Agent24
                                      I see dead caps
                                      • Oct 2007
                                      • 4978
                                      • New Zealand
                                      Yeah that would do it, although if the schematic is correct the main ROM is in a 200mil package so you would need both a 150mil and 200mil socket, one for each ROM.
                                      Personally I'd buy from eBay too, I'm sure there are good sellers on AliExpress but I don't trust it myself...
                                      -David VanHorn
                                      • megaraider
                                        • Jul 2015
                                        • 307
                                        • Portugal
                                        While you wait for the programmer try reseting all BIOS settings to default.
                                        Incorrect values (assigned or recorded, e.g. temperature, ...) might have been stored.
                                        To archive this you have to look for a 4 points jumper located very close to the RAM door / socket, labeled "RTCRST" & "SRTCRST".
                                        Short them all together.
                                        • Inforgalaxie
                                          Overheating in Stress Test
                                          by Inforgalaxie
                                          Hello i have a problem, i have a laptopt Dell E5570 that in stress test without the battery it works good and not turn off.
                                          But when i conect the battery and made a stress test the cpu temperature go to 95º and turn off. I also was testing with a new battery and the problem is the same in stress test turn off with big cpu temperature (95-100º). What can be this?
                                          12-13-2023, 03:24 AM
                                        • bripoll
                                          Acer Veriton N4670GT Dead
                                          by bripoll
                                          Hello, I have an Acer veriton n4670GT that, due to a fall to the ground, only started if I did a BIOS reset.
                                          The power button ar ok, and when power off windows, then if press power button, this power on, but goes to boot loop, like press power button forever
                                          It crossed my mind to try a BIOS update and when I finished it turned off and no longer starts in any way.
                                          I have a flash programmer, but the file you download from the Acer website has a .CAP extension, it is not a .BIN
                                          I have programmed it, but it still won't start, it is dead
                                          Before programming...
                                          11-23-2023, 02:56 PM
                                          09-06-2024, 05:27 AM
                                          Acer Swift Acer Swift 3 Ultraschlankes Notebook Notebook 3 Specification for Upgrade or Repair
                                          This specification for the Acer Swift Acer Swift 3 Ultraschlankes Notebook Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Acer Swift 3 Ultraschlankes Notebook boardview and Acer Swift 3 Ultraschlankes Notebook schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that...
                                          09-07-2024, 05:00 AM
                                          Acer Aspire Acer Aspire 7 Charcoal Black Notebook 7 Specification for Upgrade or Repair
                                          This specification for the Acer Aspire Acer Aspire 7 Charcoal Black Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Acer Aspire 7 Charcoal Black boardview and Acer Aspire 7 Charcoal Black schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties...
