la-3691p charging problem
  • rajeshkumar
    • Oct 2014
    • 44
    • india
    hiii frnd i have lenovo g410 laptop which mb charging problem im change chgr ic and check registence also change io. kbc not output apd id and iref signals if u have any idea plz reply
  • Life Goes On
    • May 2014
    • 264
    • Curacao
    Re: la-3691p charging problem
    If you have schematic post it, i will help.
    The Night Drop Down, I Will Keep Try Until..., You Never know.
    Dushi Kòrsou, Nos Tei.
    • cyberhack
      • Feb 2013
      • 466
      • Uk
      Here
      • Life Goes On
        • May 2014
        • 264
        • Curacao
        Page 40 s where you have to be, check PQ9 and PQ10 that they are oke.
        • Scoff
          HP Probook 470 G4 - Power and Charging Problem
          by Scoff
          Looking for some help with this one if anybody can assist please? I have an HP Probook 470 G4 Laptop which recently started to intermittently failing to turn on, with intermittent white LED light(charging LED) by the charging port when it should have been charging and showing an orange LED instead. Definitely some sort of gradual failure. Now the laptop fails to power on at all, no charging LED, no Power Button LED either - seemingly dead.
          Stripped down to the bare motherboard. The original HP battery, when disconnected from the motherboard, is reading 0.00v - possibly some sort of protection...
          07-03-2023, 09:28 AM
        • ahmarzo
          Hp laptop charging problem
          by ahmarzo
          Have hp laptop motherboard part no opp 17 diner skl/kbl 15289-2 with charging problem.the laptop shows plug in charging but percentage doen not increases.the schematic or boardview is not available.
          Charging ic is bq737 with voltages on pin no
          1&2 -19v
          34&5 -0v
          6 -2.56 v
          7- 0v
          8&9 -3.15v
          10 -0v
          11 -0.18v
          12 & 13 -13v
          14&15 -0v
          16 -6v
          17;18&19 -13v
          20 - 19v
          Voltages on battery connector are
          1&2. -13v
          3&4 -3.14 v
          5&6 -0v
          8&9 are ground...
          03-20-2025, 05:13 AM
        • roman728
          Lenovo E15 / NM-C421 Charging Problem
          by roman728
          Hello guys,
          I have a problem with charging circuit in this laptop. Unit came with no power at all (USB-C meter was cycling turning off and on). I discovered that when I unplug battery laptop works on charger only. So after few measurements I found shorted 1st dual mosfet AONY36324. Unfortunately i was not able to order exact this one, so i ordered AONY36352 which i believe is the similar one. Now the problem is, when i connect battery and charger USB-C meter is not cycling anymore, it starts charging (reading 20V@2,7A) but after few seconds it is going down to 20V@0,20A and laptop...
          02-20-2024, 03:40 AM
        • kity92
          Edifier x3 Earbuds Blue Light Problem (Charging Problem)
          by kity92
          I ordered a Bluetooth earbud one and half year ago, and right earbud broke. The light that should have been red when you put it in the charging case started to turn blue continuously(which means earbud is not charging) and after 1 week the earbud completely died. I disassembled right earbud because the warranty finished. I diagnosed the battery was dead, so I charged it with TP4056 and revived the battery.
          Right earbud is working now but I still didn't solve charging problem. I checked the charging box with a multimeter. There is 5V. I checked the headphone pins and they are working....
          01-13-2022, 01:49 PM
        • delphi_firebird
          Toshiba Qosmio X755 Charging problem
          by delphi_firebird
          Hello Guys,
          I received Toshiba Qosmio X755 that has a charging problem and I'm stuck trying to figure out the problem.
          - When battery is unplugged i works without any problem.
          - When I plug in the battery after plugging in the charger, it works correctly and the battery is charging.
          - When I plug in the charger after inserting the battery, it stops working. ( voltage dropped and consumed 8A, reaching the maximum capacity of my bench power supply for 5 seconds, and stop working after )
          Can you help me diagnose the problem? I have attached...
          10-16-2023, 03:04 AM
