Dell inspiron 15.led light on,does not power on,just one funny sound every 3-4 secs.
  • Blacktek
    • Nov 2014
    • 250
    I removed everything hook up to the board and still does not boot up, power led stays on but does no go beyond that, nothing on the screen, just one blocky sound coming from speaker.
    i attached the schematic, maybe some of you guys can help me.
    so far i notice that the drain side of PQ702,PQ703,PQ700 line is shorted to ground.
  • dspok
    • Jan 2014
    • 553
    • Nepal
    Re: Dell inspiron 15.led light on,does not power on,just one funny sound every 3-4 se
    What type of sound?
    Did you go through bios beep codes?
    • amd999
      • Jun 2015
      • 5
      • india
      is this problem solved, i am also having same issue on dell 3521 i3 board, pls post here the solution
      • Blacktek
        • Nov 2014
        • 250
        no solution yet, still doing the same, im thinking it might be embedded graphics chip/processor.
        • Blacktek
          • Nov 2014
          • 250
          [QUOTE=dspok;567532]What type of sound?
          Did you go through bios beep codes?[/QUOTE
          it doesnt go to bios , not even the dell logo. and the sounds are not beep codes, its a single screeching noise coming from speakers....weirdly enough the laptop stays on the whole time, never shuts off.
          • amd999
            • Jun 2015
            • 5
            • india
            did u tried to flash the bios by removing the eprom chip and flasing by flaher/eprom programmer and putting it back on motherboard, many forums says that its a eprom bios error, a common issue with insyde UEFI BIOS program especially on dell 3521 series.
            • dspok
              • Jan 2014
              • 553
              • Nepal
              if it sounds like 'tek' 'tek' then try flashing BIOS.
              Generally 34XX and 35XX series have this problem.
              • Blacktek
                • Nov 2014
                • 250
                ok ill try flashing bios
                • Blacktek
                  • Nov 2014
                  • 250
                  This is exactly the sound its making but i wont allow it to even boot up from usb stick, it starts making that noise 5 seconds after i press the power button
                  • dspok
                    • Jan 2014
                    • 553
                    • Nepal
                    Use EEPROM programmer instead USB stick.
                    • Blacktek
                      • Nov 2014
                      • 250
                      can you recommend me one?
                      • samanthban
                        • Feb 2014
                        • 253
                        • Sri lanka
                        Any Idea about this tuk tuk sound
                        sigpic
                        • Djosla
                          • Dec 2012
                          • 246
                          • Montenegro
                          it is bios problem as stated...just reflash...
                          • samanthban
                            • Feb 2014
                            • 253
                            • Sri lanka
                            reflashed done with 2mb and 4 mb noluck
                            sigpic
                            • ktmmotocross
                              Boardkiller
                              • Feb 2014
                              • 3600
                              • slovakia
                              most of tuk-tuk sound is starting mosfet, but detecting short and goes off
                              • samanthban
                                • Feb 2014
                                • 253
                                • Sri lanka
                                Thank you very much
                                sigpic
                                • guruji
                                  • Oct 2012
                                  • 120
                                  • India
                                  first of all check for stdby voltages from the dc to dc check ac det and ac ok signal.if all okay the micom kb9012 need to program. as it is a common fault with these machines. should sort it
                                  • samanthban
                                    • Feb 2014
                                    • 253
                                    • Sri lanka
                                    Thanks for the reply .I believe that up to kbc is fine ,kbc releases resume reset too. I have no idea to program kbc Please tell me simply.ac ok signal releasing 3.3 v from pu100 thanks
                                    sigpic
                                    • ihackmobile
                                      • Nov 2015
                                      Has this issue been resolved? I have the same problem with a Dell 15-3521.
                                      • ChaosLegionnaire
                                        by ChaosLegionnaire
                                        09-13-2022, 09:02 AM
                                        DELL Inspiron 3650 Inspiron i5-6400 Specification for Upgrade or Repair
                                        This specification for the DELL Inspiron 3650 can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Inspiron 3650 boardview and Inspiron 3650 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for DELL...
                                        09-12-2024, 03:44 PM
                                        DELL Inspiron 3650 Inspiron i7-6700 Specification for Upgrade or Repair
                                        DELL Inspiron 3650 Inspiron 3000 i5-6400 Specification for Upgrade or Repair
                                        DELL Inspiron 3650 Inspiron 3000 i3-6100 Specification for Upgrade or Repair
