Toshiba L650 Black Screen
  • snowfun
    • Aug 2012
    • 21
    • Portugal
    I have a problem on toshiba L650 with intel I5 cpu, no image in lcd screen,vga or hdmi, no logo in bios apears, but everthing works fine ..keyboard,operation system,sound etc. I know its works because i listen the sound of windows and the keyboard . Only i don't see anything on screen (internal or external screen).
    I tested memory,reset bios with dessolder bat on MB..nothing, i remove battery.disconnect adapter and hold power button for 30sec but no luck...No image(black screen)
    Note: The Laptop was working well before turn off
    I don't no what causes this issue, please any ideas or anyone have a similar issue.
    Thanks.
  • Th3_uN1Qu3
    Believe in
    • Jul 2010
    • 6031
    • Romania
    Re: Toshiba L650 Black Screen
    Does this have the dedicated Radeon graphics, or integrated in the processor? If it has dedicated, most likely the Radeon GPU requires reballing. If it has integrated i would suspect the Intel PCH.
    A working TV? How boring!
    • snowfun
      • Aug 2012
      • 21
      • Portugal
      Thanks for your feedback. Yes have dedicated Radeon Graphics but everthing works fine, many laptops with GPU issue not working or shutdown, Have i a corrupetd bios ??
      • Life Goes On
        • May 2014
        • 264
        • Curacao
        That s little bit strange and specialy when you heard the sound from the windows, Did you check Cmos battery and also try it with other Cpu and Ram.
        The Night Drop Down, I Will Keep Try Until..., You Never know.
        Dushi Kòrsou, Nos Tei.
        • BCConnectionLLC
          • May 2015
          • 47
          If its booting then its a Display issue. I would start looking around the GPU and see what everything looks like. Maybe bad power rail or a faulty data line.
          Youll need a schematic for the board.
          • snowfun
            • Aug 2012
            • 21
            • Portugal
            The model is L635 and not L650, sorry by mystake
            Motherboard:Inventec Bremen-10G BM10G-6050A2338501-MB-A03
            Yes, I suspect the LCD panel because I hear the sound of windows,and keyboard works.My doubt is the VGA output and HDMI does not work.
            I have change ram, only not change de Cpu ( It is necessary?? the windows works)
            Thanks for the replys,someone will have the scheme of the board?
            • sopik78
              • Nov 2013
              • 517
              • Czech Republic
              Agree with Unique, it seems to be GPU, do reball first and we'll see.
              • dj_ricoh
                • 2073
                if you take the lvds cable out and connect the board to hdmi and does not output then yes!
                its GPU.
                Toshiba goes straight to HDMI/VGA port if no internal screen connected.
                It connects before BIOS finish to do the checks /post, before it starts to load the OS.
                • vedoza
                  • May 2015
                  • 37
                  • newyork
                  ******help satellite c855 power on or not working with display please help me
                  • turmix
                    AOC U34G3XM, new monitor, black screen with backlight on, possible shortcircuit during dissassembly
                    by turmix
                    Hello, I'm working on a new deskmod pc project and have a problem with my monitor, an AOC U34G3XM, well, I may have bricked it.
                    The monitor was dismanteled and the separate parts parts integrated in the desk. the screen panel alone is on the upper part, and main board/video board + power board on the back of the desk (not enough place on the cover to fit it)
                    At first everything was working smoothly, then I decided to change the connexion between the video board and the screen for a longer one. Still working fine
                    During another reassembly, I made a mistake, and...
                    01-29-2024, 03:48 AM
                  • DaniK
                    Acer Aspire E5-574-52RH - black screen
                    by DaniK
                    I have this strange behaviour with Acer Aspire E5-574-52RH, i5 6200U, intel graphics, DA0ZRWMB6G0 Rev G, model ZRW.
                    Laptop came in for a SSD upgrade, took everything apart to install the SSD.
                    Everything started after modifying BIOS settings to boot UEFI instead of Legacy.
                    Laptop works fine, i installed windows 10 and drivers/updates, everything works ok(when it works)
                    The black screen problem is random, maybe 5 out 10 times, laptop remains with the black screen, no image
                    Symptoms are:
                    - random black screen after displaying Acer logo...
                    02-21-2024, 06:27 AM
                  • Chrissygizmo
                    samsung galaxy ao2s very temperamental after screen replaced
                    by Chrissygizmo
                    Hi , I've recently replaced the screen in my Samsung galaxy ao2s, at first it wouldn't even turn on, it had the charging symbol on the screen when plugged in but the green circle wasn't going around to show it charging....
                    Ive eventually managed to get it on and working but it's very temperamental...
                    The battery icon always reads as 50% , when the phone goes into lock screen mode i sometimes can't get the screen back on unless I plug the charger in to get it to light up, also it keeps putting the camera app on.. u think it could be something to do with the side buttons. ...
                    05-26-2024, 12:05 AM
                  • Noursa
                    Lenovo Yoga C940-15IRH No primary Screen
                    by Noursa
                    Hello
                    I'am a beginner in electronics repair and i got some trouble to find what's goning on a computer. It is a lenovo yoga C940-15IRH laptop and the screen doesn't work anymore, but that work on an external one
                    the screen seams to be hard to unbuild properly so i want to test it by other way
                    how can i be sure if the signal is really send to the screen ? i did some check on screen connector on LCD1 got 19v and on MiC1 connector on the other side of the screen (dunno if it's for the screen itself or other thing) got a lot of 3.2v pin
                    did u got...
                    05-04-2024, 10:00 AM
                  • iZakre
                    HP Pavilion 15 bc400ns - Complete Black Screen - Only video on live usb
                    by iZakre
                    Hello everybody!
                    To put you in context I recently replaced the battery from my HP Pavilion 15 bc400ns with a used one, everything was going good. The same day, I decided to update the BIOS, everything went good. The thing occurred after I let the battery drain iddling on Windows 11 for the second time to calibrate it that the screen did not turn on again, the computer was on but the screen did not turn, like it would not wake from hibernation. I decided to restart the computer but got no video.
                    The thing is that I had installed TeamViewer and could log into the computer...
                    02-19-2023, 02:27 PM
