HP Elitebook 8440p flashes led 9 times
  • Joun
    • Jul 2011
    • 191
    • Greece
    Hello everyone.
    I have this Elitebook which when I press power button it flashes its charging led 9 times and does nothing else..
    I have it connected to my lab power supply and it draws only 5-6 mA..
    The net is full with people with the same problem, but don't see any real solution .
    The schematics is here:
    https://cdn.badcaps-static.com/pdfs/...44e037c6e5.pdf if it is any help.
    Thank you.
  • dj_ricoh
    • 2073
    Re: HP Elitebook 8440p flashes led 9 times
    did you use a 6-8 amp original HP charger?
    • Joun
      • Jul 2011
      • 191
      • Greece
      Yes,it was brought to my with the original charger,the one that it was working from the begining..
      After that I power it up with my power supply so I can measure its current consumption.It behaves exactly the same on both cases.
      • dj_ricoh
        • 2073
        what voltage you have on the pin from adapter even the middle pin.
        • Joun
          • Jul 2011
          • 191
          • Greece
          It was the charger to blame after all..It was defective( dj_ricoh mentioned that but I didn't realise it had a problem)
          It didn't have any voltage(or whatever control signal) in center pin and the laptop looked like it had a bigger problem but it didn't.
          I just short circuited the central pin with the + and it is working fine now.
          The only problem is that the battery charges very slowly(at 200mA) but I guess it will need original charger for that to be fixed..
          • dj_ricoh
            • 2073
            Nice fix.
            I like those notebook.
            I got a envy m6 for 100£ it had bad hdd.
            • nimmay
              • Dec 2015
              • 82
              • Pakistan
              dear DJ
              hp 8440p intel
              how to fix this error
              Module error not functional
              CAPS & NUM 3 time blink
              i programmed bios but still same
              plz help
              • cybernova
                • May 2015
                • 34
                • IRAN
                Thank you bro
                • Snout
                  • Jul 2017
                  • 14
                  • Sweden
                  Holy sheet, that worked! I have a Dell charger (19,5V, 4,62A), with the same middle-pin arrangement, that works perfectly well with an old HP/Compaq TC4400 (the tablet-PC). I got the 9 orange blinks on THREE DIFFERENT LAPTOPS and finally tried your short-center-to-plus, and am currently starting up, charging battery, and running memtest on the first one. GREAT solution! *thumbs-up*
                  • piernov
                    • Jan 2016
                    • 4436
                    • France
                    That sounds like a very bad advice.
                    • RethoricalCheese
                      • Mar 2013
                      • 1518
                      • Estonia
                      Well, that middle pin in Dell chargers is not an analog signal (just a voltage value) like on HP but onewire digital signal. Shorting that pin to plus might kill your ID IC so you are unable to use that charger to charge a Dell laptop.
                      Just get a working HP charger.
                      • mcplslg123
                        • Jun 2015
                        • 7262
                        • india
                        I wonder why kbc didnt fried with this arrangement. Horrible advice.
                        • Snout
                          • Jul 2017
                          • 14
                          • Sweden
                          Yeah, a 1-wire chip like in Dell, HP,. and Macbook chargers, I'm aware of that, but had a spare old laptop to 'sacrifice' just to try it. I wouldn't advise this for _any_ machine, just saying it worked for me with a generic charger aswell, and the Elitebooks in question in particular. ... So, yes, there should be a warning attached 'try this at your own risk, you're likely to kill something in the lappy'.
                          Me, I'm just glad to have those extra three machines running without buying yet another 'reports genuine through a special line' power supply.
                          • piernov
                            • Jan 2016
                            • 4436
                            • France
                            HP don't use 1-wire. HP use a resistor between +19V and center pin. Bridging center pin to +19V means you send 19V directly trough the AD_ID line. There's a clamping diode, so the excess power gets sinked into the 3.3V rail, through the series resistor on the AD_ID line. On the other side is the EC. Many things can go wrong there… It also means the laptop will always think you're using the higher power AC adapter, even when using a 45W on a machine that requires 180W.
                            And as RethoricalCheese said, that will kill the 1-wire ROM inside the Dell brick as it expects 3.3V, not 19V.
                            More than a warning, it must be an absolute prohibition like "never try this things will go wrong".
                            • rtek1000
                              • Sep 2024
                              • BR
                              I would just like to supplement information based on an electronic diagram. I also had this symptom of flashing 9x, due to charger plug problem.
                              I found it interesting how HP controls the charger type, much simpler and more effective than Dell.
                              I didn't see the schematic for the Elitebook 8440p, but the HP Probook 440 G5 has an interesting schematic, maybe they are similar. And it does have limiters (transistors PQ3 and PQ5, limiting the maximum to 3.7V, even though there is 19V on the charger ID pin).
                              The ID pin is monitored on an analog input (ADP_A_ID signal), and there is another transistor, (ADP_ID_CHK signal), it should cause a 'load signal' (13k Ohms to GND) and then the line voltage should go down a little, to confirm the value of the resistor present there in the charger.
                              From schematic:
                              Click image for larger version  Name:	ID_PIN.png Views:	0 Size:	46.9 KB ID:	3460915
