hp g6 no keyboard and touch pad working.
  • highpulse
    i hate HP
    • May 2013
    • 1489
    • portugal
    we received it from another store for we can fix it , wth this diagnose , keyboard was replaced , same issue occured , , we notice that some water damage was near the button of the track pad , but not on the mainboard , it connect to the CN6 i cheked schematic to see were cn6 connecct and it does connect to the KBC , i tryed connecting only keyboard , same issue .... flashed bios , same issue ... replaced KBC , still same issue .
    any clues will be welcome.
  • highpulse
    i hate HP
    • May 2013
    • 1489
    • portugal
    Re: hp g6 no keyboard and touch pad working.
    schematic
    • highpulse
      i hate HP
      • May 2013
      • 1489
      • portugal
      well simple im stupefacted ... SB AMD problem .... WTF !!==!=!
      if the problem would be , i cant read USB or external keyboard with problems ... ok i would be on SB ...but internal and touchpad ...SB problem ?? thats odd !
      fixed.
      • ala_borbe
        aka Donald
        • 1625
        • Malta
        problems with ati chips get more and more bizarre from day to day
        especially those RS880, i had so many different symptoms but always the same problem...
        nice to here you fixed it
        Im Back... sort of...
        • ktmmotocross
          Boardkiller
          • Feb 2014
          • 3627
          • slovakia
          chips is not a problem. problem is that fck lead-free balls.
          • highpulse
            i hate HP
            • May 2013
            • 1489
            • portugal
            well somethimes can be the balls , but major i think its insyde the internal DIE
            but weell another fixed , altough new client , but still odd
            • elmark
              HP 15-cw1002ua strange keyboard issue
              by elmark
              HP Pavilion 15-CW1002UA
              S/N 5CD0251CBC
              P/N 7KE54EA
              Hello guys!
              I have a strange issue with my laptop keyboard and I'm lost trying to detect what's wrong - the KB9028Q-C or the keyboard itself.
              It powers on OK and has no other issues except the following:
              • CAPS LOCK does not work at all
              • Fn button toggles Flight Mode
              • When I press 't' or '5', it produces 't5', and when I press 'y' or '6', it produces 'y6'
              • (with SHIFT pressed: 't%' and 'y^' respectively)
              I initially thought it was a keyboard malfunction (internal short, etc.),
              but when I press and hold...
              06-27-2025, 01:10 AM
            • ahmarzo
              MacBook Air a 1466 keyboard and touch not working
              by ahmarzo
              Have a MacBook Air a 1466 with part no 820-00165-a with keyboard and touchpad not working.have tried another working keyboard and touchpad.have check the cable to board and it's good
              The voltage on connector j4800 is following
              Pin no 1-3.3v
              Pin no 10 3.3v
              Pin no 14 - 5v
              Pin no 15-20 all pins have 3.3v
              Have reballed the ic u 5000. And tried another ssd with working os .
              10-18-2025, 10:40 AM
            • fichamba
              MSI GL75 Leopard keyboard (almost) not working - HELP
              by fichamba
              Hello everybody:
              Let me put all the laptop's info before describing the problem:
              BRAND: MSI
              MODEL No.: MS-17E7
              SKU: GL75 Leopard 10SEK-261XES-BB71075H16GXXDXX
              MoBo: MS-17E71 VER. 1.0
              This laptop arrived to fix the broken left hinge, due to a hit. The hinge was repaired, and when I went to check it out, everything worked well, but I observed certain artifacts (mainly random lines) in the screen.So I decided to remove the screen bezel again, and I saw certain damage to the main LCD harness.
              This time I also observed that the right...
              10-09-2024, 04:53 PM
            • hopkok
              Lenovo Legion 16ITHg6 NM-D721, keyboard not working, LEDs too
              by hopkok
              Hi masters, I need your help.
              I am working on Lenovo Legion 16ITHg6
              Motherboard number NM-D721, no BV, no schematic but I am attaching very closes ones.
              INPORTANT: My motherboard version is with IT8258 IC, that is controlling keyboard and RGB LEDs.
              My problem is on UI142, +3VALW_AG is not stable, floating from 0V to 3,3V.
              AGKB_PWR_EN_N signal is floating too (that is why+3VALW_AG not stable).
              Power LED is not working as well, power button working well.
              UI26 ??? is there any firmware too? Powered by +3VALW_AG.
              Motherboard...
              05-04-2025, 09:35 AM
            • SuperAman
              Keyboard replacement not working issues with Win 10/11 (2) different laptops
              by SuperAman
              I have had an issue that I've never come across in all my years of laptop repairs and it has happened twice in the last couple of weeks. The issue occurred on 2 laptops.
              1. The first laptop a Lenovo Yoga 7 convertible 14 inch 13th gen i7. This laptop came in working, customer wanted to replace the top keyboard assembly for cosmetic reasons so I replaced the keyobard assembly and put their touchpad in it. After booting into windows it would not work, so I assumed I needed to update it or something. Since they didn't give me the Admin account, as it was a company laptop and the...
              08-31-2024, 07:30 PM
