Blown capacitor? on acer 7739
  • rippergr
    • May 2014
    • 345
    • Ελλάδα
    Hello all,
    I have an acer 7739 laptop which stroke by lightning. When I put the ac adaptor it doesnt work and short the adaptor. I check the + and - on jack and it is short to ground.
    I found a blown capacitor(I think it's capacitor) but I don't know what exactly is to change it and I cannot find it on schematics.
    I attached pictures and schematics but I dont know if the schematics are correct.
  • newtothis
    • Mar 2013
    • 1556
    • england
    Re: Blown capacitor? on acer 7739
    Firstly while I download the schems for it... Give it a clean up and see what is written on the top.... I can see some writing suggesting its a resistor.
    Also remove the component and see if you lose the short
    • dellxps15
      • Feb 2014
      • 1590
      • italy
      for me
      C575
      1500p/3KV_1808
      as it's the only one big category 1808. all other are 0402 or 0603 or 0805.
      • rippergr
        • May 2014
        • 345
        • Ελλάδα
        I try clean it but it totally messed up (maybe its a resistor). I also removed it but the short still remains
        • dj_ricoh
          • 2073
          • uk
          Same schematic? Toshiba c855 with acer?
          • rippergr
            • May 2014
            • 345
            • Ελλάδα
            Its a hannstar e89382 so I think it's the same.
            • rippergr
              • May 2014
              • 345
              • Ελλάδα
              Can someone tell me how can I trace the short to ground? How to start?
              • rippergr
                • May 2014
                • 345
                • Ελλάδα
                I removed a mosfet near the power jack wich seemed suspicious. When I measure it on circuit it shoes circuit in both sides. When I remove it the short circuit to ground dissapeared so I am thinking the problem is that mosfet. It's a FDS4435BZ. I am waiting for another to change it but I still can't find what is the component that blow off.
                • rippergr
                  • May 2014
                  • 345
                  • Ελλάδα
                  I think that this schematics are not for this laptop. It maybe the same model but I can't find anything matching. Can someone give me correct schematics for this laptop? It's the worst laptop motherboard I have ever seen. There is not one component name typed on motherboard you must guess all components.
                  • meritosari
                    • Oct 2010
                    • 774
                    • Indonesia
                    schematic:
                    • rippergr
                      • May 2014
                      • 345
                      • Ελλάδα
                      Thanks meritosari for the schematics, although some pages are blank like 63 which is the dc power and others. Has anyone repair such motherboard , there is no text near the components so I can trace or identify them. Is there any way to find the blown component?
                      • meritosari
                        • Oct 2010
                        • 774
                        • Indonesia
                        i've found image from russian forum:
                        its really difficult work on asus or asrock/pegatron cause board have no pcb marking, except you have the boardview. sadly can't find anything on web about that
                        • reizal
                          • Oct 2014
                          • 111
                          • aceh
                          Acer Aspire 7739 Pergatron AIC70 Schematics
                          Hidup yang benar2 membosankan.. hek that bak mita peng
                          • rippergr
                            • May 2014
                            • 345
                            • Ελλάδα
                            Thanks reizal , this is the same schematics meritosari gave me.
                            This is the most crap motherboard I have ever seen. It's ottaly blank except some jp and conn markings.
                            • rippergr
                              • May 2014
                              • 345
                              • Ελλάδα
                              Merisotary that's great picture you gave me. its exactly the spot I have the problem. so the missing component is a zero ohm link.
                              Thanks again.
                              • rippergr
                                • May 2014
                                • 345
                                • Ελλάδα
                                I changed mosfet and the zero ohm link but the laptop is still dead.
                                Any ideas what to check next?
                                PS. The short to ground that I had now dissapeared.
                                • meritosari
                                  • Oct 2010
                                  • 774
                                  • Indonesia
                                  19v, 5v and 3.3v already steady?
                                  • rippergr
                                    • May 2014
                                    • 345
                                    • Ελλάδα
                                    in which chip should I measure those voltages?
                                    • rippergr
                                      • May 2014
                                      • 345
                                      • Ελλάδα
                                      Anyone has any ideas?
                                      • meritosari
                                        • Oct 2010
                                        • 774
                                        • Indonesia
                                        what voltage you got ?(i attached image)
                                        and power button had 3.3v? or bios pin8 had 3.3v?
                                        • MeetingIncapable
                                          Blown capacitor repair on MSI Radeon RX 5700 XT MECH OC
                                          by MeetingIncapable
                                          I am new to repairing computer electronics, so excuse any mistakes I make.
                                          A friend of mine had a broken graphics card (MSI Radeon RX 5700 XT MECH OC) and gave it to me. It does not power on or show any signs of life.
                                          I identified what looks like the remains of a blown capacitor at the bottom of the board (see picture).
                                          I wanted to replace the capacitor, but I have two questions:
                                          • Does this repair have a chance of working? or is a blown capacitor a sign something else is wrong?
                                          • How do I determine the rating/value of this capacitor? or something
                                          05-04-2024, 09:56 AM
                                        • NuclearSpartan
                                          Samsung C32HG70 - Blown Ceramic Capacitor (CP813)
                                          by NuclearSpartan
                                          I'm new to this, so I apologize for not providing enough details. Is there anything else I need to mention? I'm trying to learn more about electronic/board repairs and hopefully fix my own.
                                          The only visible issue on my board is one capacitor, CP813, which appears to be labeled R 221k 2kV (possibly obsolete to B 221k 2kV now). My monitor hadn't shown any prior issues, although it is a few years old. Just before the capacitor popped, there was a high-pitched squeal for 2–3 seconds.
                                          I don't see any other visible damage anywhere else on the board....
                                          11-14-2024, 02:32 PM
                                          09-06-2024, 05:27 AM
                                          Acer Swift Acer Swift 3 Ultraschlankes Notebook Notebook 3 Specification for Upgrade or Repair
                                          This specification for the Acer Swift Acer Swift 3 Ultraschlankes Notebook Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Acer Swift 3 Ultraschlankes Notebook boardview and Acer Swift 3 Ultraschlankes Notebook schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that...
                                          09-07-2024, 05:00 AM
                                          Acer Aspire Acer Aspire 7 Charcoal Black Notebook 7 Specification for Upgrade or Repair
                                          This specification for the Acer Aspire Acer Aspire 7 Charcoal Black Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Acer Aspire 7 Charcoal Black boardview and Acer Aspire 7 Charcoal Black schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties...
